BrenTuning Posted March 17, 2014 Share Posted March 17, 2014 Hey everyone, There's not a whole lot of information out there on the 5th generation Legacy GT, after tuning many of these we wanted to share what these cars can do with the factory turbo. First we have an all stock example. We baselined it both with the OEM map and Cobb's Stage1. Then we went to work and added our ProTune. http://www.brentuning.com/dyno/graph.php?gb=0&hp=1&torque=1&afr=1&rpm=1&sl=1&sln=1&sat=0&cb=0&dgr=1&smm=0&sg=1&runid1=533&rgb1=000000255&runid2=534&rgb2=204000000&runid3=535&rgb3=000153000 Up next we had a "Stage2" car come in. Which consisted of a Invidia turbo back exhaust and a RacerX chargepipe. http://www.brentuning.com/dyno/graph.php?gb=0&hp=1&torque=1&afr=1&rpm=1&sl=1&sln=1&sat=0&cb=0&dgr=1&smm=0&sg=1&runid1=522&rgb1=000000255&runid2=534&rgb2=204000000&runid3=535&rgb3=000153000 And finally, we have the fully bolted combination. This car had an Invidia turbo back exhaust and RacerX TMIC. Let it be noted that this car was done on the DynaPack's we used to rent compared to our Mustang dyno that the first two cars were done on. So peak numbers are higher on this one. But the important part is still here, the delta. http://www.brentuning.com/dyno/graph.php?gb=0&hp=1&torque=1&afr=1&rpm=1&sl=1&sln=1&sat=0&cb=0&dgr=1&smm=0&sg=1&runid1=337&rgb1=000000255&runid2=338&rgb2=204000000 Contact us today to setup your tuning appointment. We offer E-Tuning, Road Tuning, and Dyno Tuning. As well as part installs! Link to comment Share on other sites More sharing options...
Hepy117 Posted March 17, 2014 Share Posted March 17, 2014 I'd love to see a stage 1+ the racerx tmic. Will have to post it up if you ever get that combo Link to comment Share on other sites More sharing options...
BrenTuning Posted March 17, 2014 Author Share Posted March 17, 2014 I'd love to see a stage 1+ the racerx tmic. Will have to post it up if you ever get that combo If we have a customer come in with a setup like that, of course! Link to comment Share on other sites More sharing options...
