Baklarz Posted February 16, 2014 Share Posted February 16, 2014 Just a little info first I bought a 1998 legacy gt wagon with blown head gaskets and had been in storage for 2 years and i decided to give it life again so it has all new head gaskets, water, pump, timing belt, spark plugs, ball joints, pads, rotors, ebrake shoes, fuel filter, oil filter, coolent, power steering fluid, oil, air filter, 3 brake calipers, brake fuild, full gasket kit, pcv valve, tires, wiper blades, inner tie rod and thermostat. After all of this it now has a hard time starting but once it's warmed up it doesn't have this issue. When I am trying to start it from cold it won't even fire till I give it some gas and you have to pump it like it was carbureted but once it starts it idles like a dream drives like a dream the only thing left to do is fix the exhaust manifold there is a hole at the first bend that has been wrapped I don't know if that could be apart of the problem just wondering if anyone has any ideas ? Link to comment Share on other sites More sharing options...
Osei Posted February 16, 2014 Share Posted February 16, 2014 Guessing here. Loose IAC hose or not fully seated plug for IAC. Also check connectors for cam and crank sensors. O. Link to comment Share on other sites More sharing options...
