seamusep3 Posted February 9, 2014 Share Posted February 9, 2014 Is there a definitive "how to lower 4th gen" post? I've searched and read a ton off comments. I'm looking for right at or just below stock legacy height -are upper perches needed and if so which ones. -If jdm legacy wagon springs are recommended where does one find them -are usdm legacy struts and springs worth it or should I go to aftermarket? - I'm not looking at tracking this car, I want a lower center of gravity and a overall tighter handling car. Not to mention eat up some of that fender gap. Link to comment Share on other sites More sharing options...
c-lo Posted February 9, 2014 Share Posted February 9, 2014 welcome. it's right under your nose http://legacygt.com/forums/showthread.php/official-lowered-outback-thread-180375.html 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
seamusep3 Posted February 9, 2014 Author Share Posted February 9, 2014 Thanks for the welcome and link c-lo.i was hoping for a generation specific post with specifics. I've combed through the provided already and there are a lot of suggest using front upper control arms some don't before I order parts and start install I just was hoping for definitive info. Link to comment Share on other sites More sharing options...
Manik1770 Posted February 27, 2014 Share Posted February 27, 2014 Hey Seamusep3, If you're looking to lower your '12 check out this post (sorry to throw to an outside site) http://www.subaruoutback.org/forums/104-gen-4-2010-2014/53480-my-2013-bbp-sap-3-6r-purchase-experience-plus-more.html OP posted a step by step to his lowering and gives part numbers. If you plan on running stock legacy suspension you can switch out the upper arms to get rid of in the rear. I went a little lower on mine so the legacy arms weren't as worthwhile as I would have liked them to be. Hope this helps. Link to comment Share on other sites More sharing options...
