cryo Posted August 5, 2014 Author Share Posted August 5, 2014 bump for helping others out. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
PhillyWilly Posted September 8, 2014 Share Posted September 8, 2014 Do I need to buy a new hose to remove the restrictor pill when installing an EBCS? Or can I just remove it from the stock hose? Link to comment Share on other sites More sharing options...
Rhitter Posted September 9, 2014 Share Posted September 9, 2014 Do I need to buy a new hose to remove the restrictor pill when installing an EBCS? Or can I just remove it from the stock hose? Depends on the EBCS probably. I just installed the GS one and it had all new hoses. I completely pulled off the old hoses and used theirs in place. My OBXT build Link to comment Share on other sites More sharing options...
cryo Posted September 9, 2014 Author Share Posted September 9, 2014 Phillywilly- Almost all EBCS's on the market have you remove the restrictor pill because of how it operates. You will be running new lines to the turbo and WG so its not a big deal anyway. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
PhillyWilly Posted September 9, 2014 Share Posted September 9, 2014 I picked up a used Grimspeed. Sounds like I need to pickup some new lines? Replacing vf46 with vf52. Dave, will be contacting you soon for the tune. Link to comment Share on other sites More sharing options...
cryo Posted September 18, 2014 Author Share Posted September 18, 2014 Hello there, Yup you will need to run one line strait to the wastegate,one to the turbo nipple and one to the turbo inlet. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
cryo Posted September 24, 2014 Author Share Posted September 24, 2014 I am trying to put something cool together and was hoping any customer tuned by Cryotune Performance could help out. I would like to get the nicest picture you have of your car sent to Cryotuneperformance@yahoo.com. I Know some of you have sent pic's already so that's not needed unless you have an updated picture that looks more professional or a better back drop. These could include pictures on the road/dyno/mountains/park/ etc. Thanks and hope to get quite a few together Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
Hannya Posted October 31, 2014 Share Posted October 31, 2014 Bump for learning purposes. Link to comment Share on other sites More sharing options...
cryo Posted January 18, 2015 Author Share Posted January 18, 2015 Bump for ease of reading for the new people. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
joeleodee Posted February 21, 2015 Share Posted February 21, 2015 Quick question. I'm running Grimmspeed hybrid boost control with a Tial MRV EWG. I have a the springs in the EWG at 14.5 psi and I'm just beginning to retune boost. My BCS is all the way open so technically, I should be seeing peak boost of around 14.5psi. However, I'm seeing peak boost at about 15.5-16 psi. Could this be an issue with the MBC, or are the springs not always accurate? Link to comment Share on other sites More sharing options...
LatentWagen Posted February 22, 2015 Share Posted February 22, 2015 The weather can affect your MBC spring (and therefore, your boost), so a tweak here and there is necessary to keep things in a tight range. When I ran an MBC on my WRX, I would have to adjust every Winter and Spring, or boost might vary up to a couple PSI. That much is easily enough to knock your tune out of shape... LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
joeleodee Posted February 22, 2015 Share Posted February 22, 2015 So are you suggesting that my boost is hitting a little higher than the mechanical limit of the spring due to colder temperatures and not necessarily to a possible variance in the advertised spring rate? Link to comment Share on other sites More sharing options...
LatentWagen Posted February 22, 2015 Share Posted February 22, 2015 I'm suggesting that the "mechanical limit," as you put it, of a spring can be affected by temperature. Colder temps make metals more brittle, thereby increasing the rate. Warmer temps do the opposite. I saw this firsthand with my setup, but I was only using an MBC, not a hybrid setup. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
joeleodee Posted February 22, 2015 Share Posted February 22, 2015 Got it. Thanks. I wasn't trying to be argumentative so I hope I didn't come across that way. Just seeking clarity. Link to comment Share on other sites More sharing options...
LatentWagen Posted February 24, 2015 Share Posted February 24, 2015 It didn't come across that way at all. Did my "bunny ears" belie my sincerity? LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
cryo Posted June 19, 2015 Author Share Posted June 19, 2015 bump up to the top for those needing this easily accessible. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
cryo Posted October 13, 2015 Author Share Posted October 13, 2015 Bump to the top for new owners Thanks Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
ashwinearl Posted October 27, 2015 Share Posted October 27, 2015 I need a similar article on Fuel Pumps and you? When do you upgrade and why in relation to a turbo upgrade (JMP modified internal VF40 not a bigger one) but not fuel injector upgrade. Link to comment Share on other sites More sharing options...
cryo Posted November 12, 2015 Author Share Posted November 12, 2015 I guess that's not a bad idea, might do that as well. I always suggest an upgraded pump when the injectors OR turbo are upgraded. Anytime more fuel is going to be needed I would rather see a newer high flow pump in place....you have to figure that some of these cars such as yours are now driving on a 10 year old pump and you will be pushing it as well. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
cryo Posted December 8, 2015 Author Share Posted December 8, 2015 Just figured I would answer a question I get asked quite often. What is the difference between the grimmspeed EBCS and the Cobb EBCS........ And the answer is......nothing. They both use MAC valves that operate the same. This happens to be the same valve used on the AEM controller as well. That means if you like GS go with GS, If you like Cobb, go with cobb. Hope this helps. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
Mike07LGT Posted August 27, 2016 Share Posted August 27, 2016 Great writeup! Thanks for this! 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
cryo Posted August 27, 2016 Author Share Posted August 27, 2016 Glad people are still finding this useful. I still cruise the forums very often, just don't post much unless I have something of benefit that's not easily answered by some of our veteran forum members. Have a great day! Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
NSFW Posted September 29, 2016 Share Posted September 29, 2016 I'm a big fan of the hybrid approach, but it costs an extra hundred or so for a good MBC, and for someone who is paying a tuner the advantages are negligible. But as a DIYer who swapped parts a lot and was constantly tinkering with stuff and checking my work, the hybrid setup was great. The WGDC table becomes trivial. After that I could dial in any boost level I wanted, very repeatably, just by turning the knob. Without any of the PTFB annoyance that comes from using an MBC by itself. So after making a hardware change I'd turn the MBC down to minimum (whatever the wastegate spring provides) and then tune fuel and timing (usually just timing) then turn up the boost a couple psi and tune again, and repeat until I was at max boost. It was nice being able to cover everything from wastegate to max boost one step at a time without ever touching the boost tables. I'll go through the same process again with my new motor once it is ready. I had a post-it note that told me how many turns of the knob gave me what psi and what load. If I got suspicious about knock at some particular rpm/load, I could just turn the knob to hit that load in WOT pulls. I did a wiki page about it at RomRaider, here: http://www.romraider.com/RomRaider/BoostTuningMadeEasy You could do the same things with a BCS alone if you save copies of the WGDC tables for each boost level you want to test/tune, and swap them when you want to test different boost levels, but that's extra hassle. It was a hundred bucks well spent IMO. But for someone who does upgrades, gets tuned, and then just enjoys their car, it'd just be a hundred bucks wasted. Link to comment Share on other sites More sharing options...
JustCallMeNick Posted March 12, 2017 Share Posted March 12, 2017 Very helpful explanation! Thank you. Link to comment Share on other sites More sharing options...
xtea Posted March 13, 2017 Share Posted March 13, 2017 Anyone want to offer thoughts on 3 port vs 4 port? Link to comment Share on other sites More sharing options...
