TD05 Big 16G for 05LGT?
Posted
I've found a couple td05 big 16g turbochargers for reasonable prices. I'm just curious if they would actually "bolt-on", and if I'm going to need to replace any injectors or any other parts to work with the turbo. Thanks!
Posted
What's the mounting flange look like, will it mate to your up pipe flange?
BNR16g can run stock fueling. Same as my vf52. But will need a tune.
Engine Build - Click Here
Posted
It looks very similar, but I'll have to do some more research. My plan is to get this 16g and then the Cobb v3 access-port.
The only other parts I have installed is a Perrin short ram intake and full catless exhaust w/ ELH. Think that would work?
Posted
It should, but the short ram is useless at this hp. The stock intake is the best up to 400whp. Sorry.
If the turbo will bolt you the up pipe/dn pipe and inlet and "new" oil drian hose, a tuner can work with it.
