LGBlades Posted January 22, 2014 Share Posted January 22, 2014 About 3 weeks ago I put in an alternate grounding kit, when I started the car it idled down and died. The second start it ran but when I had the car out of gear and my foot on the break it would cause the idle to drop almost killing the car. I went back to the old grounds, changed out my TPS and I am still having the problem does any one have an idea what it could be? Link to comment Share on other sites More sharing options...
Osei Posted January 23, 2014 Share Posted January 23, 2014 Check to make sure you did not dislodge the IAC hose to the intake system. O. Link to comment Share on other sites More sharing options...
LGBlades Posted January 24, 2014 Author Share Posted January 24, 2014 the hose is good but I will check to see if somehow I shorted out the sensor in the valve. thanks and I will let you know if it fixes the problem. Link to comment Share on other sites More sharing options...
