Perrin recirculating Bov ?
Posted
Im looking to buy a perrin recirc bov for my 05 lgt. A buddy of mine is selling me his that he bought for his 02-03 wrx but never ended up using, will it fit on my car ? I know most bov's are universal but i just wanted to make sure it will fit
Posted
So long as you don't run 100% vent-to-atmosphere you will be fine.
Don't know much about those BOVs but I think the perrin one is recirculating only?
If this is the BOV in question I don't think it will fit without any modifications as our recirc lines don't use a flange connection but instead a hose clamp connection.
Here is the perrin BOV for out GTs. the model numbers are different so there might be some key differences. (WRX: PSP-INT-600BK, LGT: PSP-INT-610BK)
  • 2 weeks later...
Posted
Valve wont fit as the TMIC styles are different between the 05-09 LGT and the 02-03 WRX. If the flange is a separate part you could buy a 08+ WRX flange and it will fit. Since it is a recirc valve you wont exp any issues unless the valve is malfunctioning.
