obd2 port not working (not a fause issue)
Posted
so my obd2 port wont connect. it has good power and good ground which i check with a volt ohm meater so its not that. both scan tools and ecuflash all said it would not connect. does anyone know what the problem is?
Posted
Sorry its 2005. I check the wires from the port to the ecu and they are good. My brother suggested the security system or trying my other key so thats the next step
Posted
There's a fuse for that. Had the same problem when I tried using a cheap scanner, it blows the fuse but if I I use a snapon no problem. Twice it has happen to me.
Posted
Like i said it wasnt the fuse... But i figured it out, both my dads scantools didnt like the car and my buddys cheap matco one worked fine and it went through inspection. A guy that i know that worked at our subaru dealer said that happens sometimes when they get tuned
