What are common mechanical failures for 05 legacy gt?
Araiza42
Posted
Im looking to buy a 2005 Legacy GT. I just wanted to know what are common mechanical problems for this car (like a turbo failure) just want to know what im getting into. I was going to get a mechanic to check it out and also a compression test done on the engine. The legacy has 130,000 miles in it. Thank you all for the help
Posted
There are plenty of threads on this already- but a quick wrap-up would include getting both the compression test and leak down done on top of these common failures:
- Turbo due to banjo bolt filters getting clogged
- Oil pickup tube cracking
- AVCS failure from the other banjo bolt filter
- Cylinder 4 cracked ringland from poor factory tune
Plus I'm sure there is some that are missed. Did you get a CarFax? Has it been through multiple owners in quick sucession?
Posted
Im going to buy it. What should i look for when i get it? What should the first thing i check/change?
Mechanical problems with the engine see above ^^^^^^^^^^
Did you drive in very slow circles? My hubby said the torque bind transmission thing can be a problem
Posted
Take it to a shop you trust for a pre-inspection and have a compression test and leak down done first. Probably put you back over a $100 though.
Posted
It might be easier to say what are uncommon failures.
turbos, clutches, head gaskets, wheel bearings, center diffs, axle boots........shall I keep going?
