Zues Marine Posted April 9, 2015 Share Posted April 9, 2015 in pretty much every year except the '95... there is a rubber pop-out grommet Link to comment Share on other sites More sharing options...
DoDoBird77 Posted December 3, 2015 Share Posted December 3, 2015 Ive been reading several forums regarding hybrid/frankenmotor, figured I'd give it a try. I have a 1998 Legacy GT Shwagon EJ25D AT the motor runs fine but has a slight piston slap when cold (just let it warm up before driving) however its time to consider a rebuild. My plan is to use the 98 EJ25 short block, 95 2.2 single cam heads w EGR, and 97 or newer 2.2 intake manifold. I understand what gaskets and timing belt to use. My other option is A 96 2.2 block with the 25D heads and intake slap a TD04 on the stock 98 EJ25D ECU at 10psi. Will either of these setups work? keep in mind I'm on a budget Link to comment Share on other sites More sharing options...
93ej22 Posted July 29, 2016 Share Posted July 29, 2016 (edited) Hey guys i have the black sheep 95 obd2 legacy with the dual port heads and just want to confirm that my chambers are the same size as the 96+ single port heads before i go source a 25d shortblock. Dont want to wind up with wild compression from smaller chambers Thinking i can pull a shortblock and rebuild it before i swap it in since my heads were done 10k ago Edited July 29, 2016 by 93ej22 Link to comment Share on other sites More sharing options...
93ej22 Posted August 1, 2016 Share Posted August 1, 2016 Found my answer Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted December 13, 2016 Author Share Posted December 13, 2016 Hey guys i have the black sheep 95 obd2 legacy with the dual port heads and just want to confirm that my chambers are the same size as the 96+ single port heads before i go source a 25d shortblock. Dont want to wind up with wild compression from smaller chambers Thinking i can pull a shortblock and rebuild it before i swap it in since my heads were done 10k ago Yes, they are the same. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted December 13, 2016 Author Share Posted December 13, 2016 Updated data to the first post describing the basic technical detail of the engines. Link to comment Share on other sites More sharing options...
94 legacy Posted January 3, 2017 Share Posted January 3, 2017 Hello im new to this so here goes i have a 1994 legacy with the ej22t its no good oky i was givin a 2000 forester with the ej25 can i put the 2.5 in my legacy and splice the one connector thats is diffrent any thoughts would be helpfull thank u Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted January 3, 2017 Author Share Posted January 3, 2017 (edited) Hello im new to this so here goes i have a 1994 legacy with the ej22t its no good oky i was givin a 2000 forester with the ej25 can i put the 2.5 in my legacy and splice the one connector thats is diffrent any thoughts would be helpfull thank u You cannot. The Forester that engine came from has completely different wiring, cam triggers, and ECU. And it would be ill-advised to put your cylinder heads on the Forester bottom end without a fair bit of head work so the engine doesn't grenade. What you CAN do is find 97-99 EJ25D heads, pull your wiring, sensors, IACV, and crank gear off your bad engine, and put all of the aforementioned on the EJ25D heads, in turn, putting the 25D heads and crank gear on the Forester bottom end to have a nice engine with plenty of power all over the rpm range. Edited January 3, 2017 by DOHCEJ22E1 Link to comment Share on other sites More sharing options...
94 legacy Posted January 3, 2017 Share Posted January 3, 2017 Omy thank you iv been dealling with a great deal of wiring this help alot thank u again Link to comment Share on other sites More sharing options...
94 legacy Posted January 3, 2017 Share Posted January 3, 2017 What is the diffrence between the 2000 ej25 and the 97-99 ej25D heads Link to comment Share on other sites More sharing options...
twisty Posted January 4, 2017 Share Posted January 4, 2017 ej253 is sohc and the ej25d is dohc for one, along with the parts he listed for you above that are different. beyond that, im not really sure what else is different. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 31, 2017 Author Share Posted October 31, 2017 Update: Any 1997-1999 EJ25D head/E2221/2/3 block hybrid MUST be run on 89 octane unless using an EJ22T head gasket, in which case, running 87 is perfectly fine. Any 1997-1999 EJ25D head/EJ221/2/3 block must be run on 89+ unless using stock Ej25D head gasket, in which case, running 87 is perfectly fine. Link to comment Share on other sites More sharing options...
Jdubgt530 Posted March 10, 2018 Share Posted March 10, 2018 My question is taking a ej251 and slapping 96 ej25d heads on them. I have a lead on a ej251 shortblock in great shape and have 96 ej25d heads out of a 97 Gt that I have laying around. I heard the ej251 have better bottom ends just not sure if the heads will work or not Link to comment Share on other sites More sharing options...
94Legacy2.2 Posted March 21, 2018 Share Posted March 21, 2018 As far as engine swaps go does anyone have an idea of what can just be dropped in without significant modifying? I have a 94 Legacy L and want more power. Link to comment Share on other sites More sharing options...
aquazulu Posted April 28, 2018 Share Posted April 28, 2018 Hello folks, Thanks for allowing me to join the forum. Asking about a timing belt fit. Please someone tell me if the timing belt used on the 2.0 JDM compatible with that used on the American domestic version. 2.2 or 2.5. I have this in my ebay cart. Timing Belt Water Pump Kit For Subaru Legacy 1997-1999 2.5L 2458CC H4 GAS DOHC Thanks. Link to comment Share on other sites More sharing options...
twisty Posted May 1, 2018 Share Posted May 1, 2018 IIRC the ej20 and ej25 share the same timing belt size. Link to comment Share on other sites More sharing options...
