Tehnation Posted April 22, 2016 Share Posted April 22, 2016 CV Joint Banding Tool, for boots and bulletproof tmic mod. Lisle 30950 is the cheaper one and the better one is OTC 4623 Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 26, 2016 Author Share Posted April 26, 2016 (edited) Replacement plug ends for spark plug coil and fuel injectors http://www.bmotorsports.com/shop/product_info.php/products_id/3177 http://www.ebay.com/itm/4-Denso-Female-Fuel-Injector-Connector-Electrical-Plug-Clip-Pigtail-/301659770848?fits=Year%3A2005%7CMake%3ASubaru&hash=item463c52cfe0:g:YkYAAOSweW5VfIac&vxp=mtr Edited April 26, 2016 by JmP6889928 Link to comment Share on other sites More sharing options...
quick4dr Posted April 29, 2016 Share Posted April 29, 2016 Raxles.com all Subaru axles, OEM build Quailty ask for Marty. $189.95/ axle plus shipping. does not pre-charge CORE Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 5, 2016 Author Share Posted May 5, 2016 Complete genuine Subaru nuts/bolts/studs for mounting turbo for a VERY good price. http://www.ebay.com/itm/Genuine-Subaru-Exhaust-Manifold-Stud-Nut-Kit-WRX-STI-Legacy-Impreza-Forester-/131565600317?hash=item1ea1ebbe3d:g:v9AAAOSwstxVTU-q&vxp=mtr Link to comment Share on other sites More sharing options...
relative4 Posted May 5, 2016 Share Posted May 5, 2016 Dorman 65236 [ame=http://www.amazon.com/Dorman-65236-AutoGrade-Drain-Plug/dp/B000C10EVM/ref=sr_1_1?ie=UTF8&qid=1462449598&sr=8-1&keywords=Dorman+65236]Amazon.com: Dorman 65236 AutoGrade Oil Drain Plug: Automotive[/ame] Available from Advance Auto Parts, etc. For some reason, some aftermarket up-pipes have an M12-1.5 bung, although the OEM bung is M12-1.25. This bolt is 1.5. It's about 5mm too long; rather than grind it down, you can sandwich a steel flat washer between 2 copper or aluminum crush washers for a quick & easy seal. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 5, 2016 Share Posted May 5, 2016 Complete genuine Subaru nuts/bolts/studs for mounting turbo for a VERY good price. http://www.ebay.com/itm/Genuine-Subaru-Exhaust-Manifold-Stud-Nut-Kit-WRX-STI-Legacy-Impreza-Forester-/131565600317?hash=item1ea1ebbe3d:g:v9AAAOSwstxVTU-q&vxp=mtr FWIW, at least one of us finds it easier to bolt the turbo to the up pipe using OEM bolts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted May 5, 2016 Share Posted May 5, 2016 Complete genuine Subaru nuts/bolts/studs for mounting turbo for a VERY good price. http://www.ebay.com/itm/Genuine-Subaru-Exhaust-Manifold-Stud-Nut-Kit-WRX-STI-Legacy-Impreza-Forester-/131565600317?hash=item1ea1ebbe3d:g:v9AAAOSwstxVTU-q&vxp=mtr For those only needing one or two the stud part number 800910550 the nut part number 902370029 About 2 bucks each at dealership if you need it now!! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 22, 2016 Share Posted May 22, 2016 (edited) I'm thinking this is the bolt I used to bolt the turbo to the up pipe. https://www.belmetric.com/bf10x125x25-flange-bolt-109-p-414.html?zenid=3jh0go1ljton99gishi2rid8a7&cPath=2_1047_69 Just make sure you order the correct length Link still works, Feb 12 2021 Edited February 12, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 27, 2016 Author Share Posted June 27, 2016 http://www.raxles.com/ Link to comment Share on other sites More sharing options...
JmP6889928 Posted July 11, 2016 Author Share Posted July 11, 2016 Company in Traverse City Michigan. Says they offer warranty and will ship anywhere in the USA. Take a look and I make no guarantees or implications of quality. http://grandrapids.craigslist.org/pts/5635178408.html Link to comment Share on other sites More sharing options...
rapture Posted July 26, 2016 Share Posted July 26, 2016 Hey everyone So i recently came to this thread to source pn's For the viton power steering o-ring thats better and doesnt leak My question is Is that the owm part listed on page 1 Or is the oem diff, less quality Thanks Link to comment Share on other sites More sharing options...
JmP6889928 Posted October 8, 2016 Author Share Posted October 8, 2016 Special thanks to wileycoyote0022 for compiling this list If you do have numbers that are listed as ????, please let me know and I can insert them so we have them all in a single post. Thanks much, JMP After the second time I turned a wrench on my car, I couldn't stand it any longer. So I finally compose the list of nuts, bolts, and washers that see get the most weathering; suspension, chassis, motor mounts, transmission mounts, and a few others. The description is just to give you an idea of the location, cause I'm sure its not "technically" correct. There were a couple part numbers/prices I couldn't find. Description_____________Part Number____Qty Transmission Bolt & Washer Bell House (2 L, 2 R)_____800510080______4 Bolt & Washer Bell House (top L & R)____800510060______2 Bell House Nut (lower L & R)___________802010080______2 Bell House Washer (lower L & R) _______803010120______2 Mounts and Drivetrain Dynamic Damper Bolt (CM)____________010006350______2 Cross member Bolt (center) ___________20540FC110 ____2 Transmission Mount Bolt______________ 901120096______6 Transmission Mount Nut_______________?????___________4 Cross member Bolt (rear)______________901030002_____6 Cross Member Bolt (rear plate)_________?????__________2 Engine Mount Washer_________________903100168______2 Engine Mount Nut____________________902370028______2 Engine Mount Bolt____________________901120096______6 Brakes/Hub/Shock Front Brake Flange Bolt_______________901000316______4 Front Hub Flange Bolt_________________901000238______8 Rear Brake Flange Bolt________________26273AC001____4 Rear Hub Flang Bolt__________________901000258______8 Suspension Rear Rear Nut (lateral Links)_______________902350022______10 Rear Cam Bolt_______________________901700122______2 Rear Cam washer____________________903100171______2 Rear Toe Washer ____________________20560AA011_____2 Rear Lateral Bolts____________________901000110______6 Rear Lateral Bolts (outter)_____________901000244______4 Rear Trailing Arm Bolt________________901000175______2 Rear Trailing Arm Bracket Bolt_________901000178______8 Rear (lower) Strut Bolt________________901000177______2 Rear (lower) Strut Washer_____________900335062______2 Rear (lower) Strut Nut________________902350021______2 Rear Sub Frame Bolt__________________901000252_____8 Rear End Link Nut Upper_______________902370029_____2 Rear End Link Nut Lower_______________902370046_____2 Front Front Strut Bolt______________________20540AA100_____2 Front Strut Cam Bolt__________________20540AA090_____2 Front Strut Nut_______________________20550AA010____4 Front Strut Washer___________________20560AA040_____2 Ball Joint Bolt________________________901000060_____2 Transverse Link Plate Nut______________902350023______2 Transverse Link Plate Bolt_____________901030007 ______4 Transverse Link/Cross Member Bolt_____901000264______2 Transverse Link/Cross Member Nut______902350006______2 Support Arm/Cross Member Bolt________????___________6 Support Arm/Cross Member Nut_________????___________2 Crossmember Bolt/Body_______________901000242_____4 Front Endlink Nut_____________________902350001______4 Front Top Hat Nut____________________902350013______6 __________________________________________________164 Total Cost: $323.43 including shipping I used opposedforces.com/parts , to look up part numbers. I know there are alot of subaru oem online part stores, but I liked this one the best IMO, easiest site to navigate. Second site was http://www.subarupartsdepot.com . They had the best prices all around that I could find. I hope this helps someone. Link to comment Share on other sites More sharing options...
JmP6889928 Posted October 18, 2016 Author Share Posted October 18, 2016 Courtesy of Battelready. He has these on his car and they look great. http://www.gtcovers.com/ Link to comment Share on other sites More sharing options...
careercadaver Posted October 20, 2016 Share Posted October 20, 2016 Wow John... Link to comment Share on other sites More sharing options...
Max Capacity Posted October 20, 2016 Share Posted October 20, 2016 Ref, post 188, For more nuts and bolts, see post #128. I would also think, McMaster-Carr would carry the same selection of flange nuts and bolts. They have a thick catalog that I have been ordering items out for years here at work. I think that is where I got the brass "T" fitting I use to T the fuel pressure Regulator into the small vacuum hose off the blow off valve for a me constant signal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Holla Posted November 23, 2016 Share Posted November 23, 2016 https://www.amazon.com/Vf52-Turbo-Charger-Subaru-Legacy/dp/B00K60YA96/ref=sr_1_1?ie=UTF8&qid=1479752762&sr=8-1&keywords=vf52+turbo Thought some one might find this useful... I paid over $1100 for mine back in 2011. Wtf? Me too! I may buy one and shelf it. Link to comment Share on other sites More sharing options...
gkinslow Posted November 23, 2016 Share Posted November 23, 2016 That link is for a JM vf52 not an IHI vf52. Known issues with boost creep on the JM model if I remember correctly. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 2, 2016 Share Posted December 2, 2016 May be John can chime in a tell us something about them ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 22, 2016 Author Share Posted December 22, 2016 To answer your questions about the JM VF52, I don't have any experience with that particular model but I can say that the inconsistencies of most of the "ChinaChargers" make them a bit of a dangerous option. I've rebuilt a few of them and once redone, they are OK but usually the turbine/shaft assembly is out of balance and some of the connectors are pretty cheap. I could probably turn one into a good turbo if I had one, but I don't have one now to work with. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 26, 2017 Share Posted March 26, 2017 (edited) Here are the Dorman shafts with replaceable U joints. Dorman 936-955 is the 5mt driveshaft. 936-954 is the 5eat's. Found them for about $315.00 on Rock Auto Update; I would call and talk to someone to make sure this fits your car. I see they are around $425.00 now Feb 2020. I see there are different OEM p/n's, https://parts.subaruonlineparts.com/search?search_str=propeller+shaft Make sure you order the correct one. Just checked, Feb 12 2021 that Dorman will work, I also found The Driveshaft Store in CA is a great place to get these, I bought one of theirs July 2020 Edited February 12, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted March 30, 2017 Share Posted March 30, 2017 I thought this is an interesting use of a useless port after TGV deletes. http://legacygt.com/forums/showthread.php/logging-wideband-o2-via-tgv-sensor-input-243134.html?t=243134 post 12 has more info to get started. I didn't read all 157 posts, however its still being worked on... Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 22, 2017 Author Share Posted April 22, 2017 http://www.subaruperformanceengines.com/imagepages/image20.html Link to comment Share on other sites More sharing options...
MTBwrench Posted April 22, 2017 Share Posted April 22, 2017 http://www.subaruperformanceengines.com/imagepages/image20.html Wow... is this real? It seems like it can't be! Sent from my iPhone using Tapatalk MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 3, 2017 Author Share Posted June 3, 2017 Source for inexpensive JDM HID http://legacygt.com/forums/showthread.php/source-super-cheap-jdm-hids-05-07-262595.html Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 4, 2017 Author Share Posted June 4, 2017 RockAuto.com has cheaper stock grilles ($65): RockAuto Grille http://www.rockauto.com/en/moreinfo.php?pk=1007009&cc=1430733&jsn=361 One could also opt for the C-Mod Grille for $140: C-Mod Grille http://cmodgrilles.auctivacommerce.com/Subaru-Legacy-2005-2007-Mesh-Grille-P121837.aspx Link to comment Share on other sites More sharing options...
