Max Capacity Posted March 21, 2021 Share Posted March 21, 2021 (edited) https://www.clipsandfasteners.com/default.asp Just got that from a Ford truck site, where I bought female electrical terminals for my 1986 F150. I see they have a line of Subaru products too. Looking through that site, I found this, https://www.clipsandfasteners.com/126-Piece-Subaru-Fender-Rocker-Moulding-Retainer-p/pas8190.htm $50.00 Edited March 21, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted March 29, 2021 Share Posted March 29, 2021 Got this from Zephrant's post. This is the one: SCITOO Radiator 2778 fit 2005-2009 S-ubaru Legacy GT H4 2.5L https://www.amazon.com/dp/B076MXYF59 post #33 here, https://legacygt.com/forums/showthread.php/230k-miles-hg-leaking-284837.html?p=6025403#post6025403 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted April 19, 2021 Share Posted April 19, 2021 https://www.maxjax.com/ Saw the commercial so I looked into it. Not a bad deal at all, 2500 for a portable lift kit that goes 4ft, not a bad price. going to see if I can clear out my garage this summer, might get one next year. You just need to drill like 10 holes in the floor, 5 each side for the recessed anchors. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2021 Share Posted April 25, 2021 (edited) In case someone needs. Got it from outback.org https://www.carparts.com/search?q=steering_knuckle&vehicle[cylinders]=4&vehicle[liter]=2%2E5&vehicle[submodel]=GT&vehicle[model]=Legacy&vehicle[make]=Subaru&vehicle[year]=2005 Here's the thread from here where we discuss this, https://legacygt.com/forums/showthread.php/steering-knuckle-43-00-285913.html Edited April 29, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted May 4, 2021 Share Posted May 4, 2021 Got this from B-GTLimited in post #4729 https://legacygt.com/forums/showthread.php/did-you-do-your-4th-gen-legacy-todayi-vol-10-278883p119.html for more info, scrol down a few post. https://caswellplating.com/caswell-science-plating-kit-zinc-plating.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Smithcraft Posted May 7, 2021 Share Posted May 7, 2021 Got this from B-GTLimited in post #4729 https://legacygt.com/forums/showthread.php/did-you-do-your-4th-gen-legacy-todayi-vol-10-278883p119.html for more info, scrol down a few post. https://caswellplating.com/caswell-science-plating-kit-zinc-plating.html I think this is the link that you want, but you can also link directly to the post by clicking on the post number. Page - https://legacygt.com/forums/showthread.php/did-you-do-your-4th-gen-legacy-todayi-vol-10-278883p316.html Post - https://legacygt.com/forums/showpost.php?p=6016854&postcount=4727 SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
boxkita Posted July 19, 2021 Share Posted July 19, 2021 https://computer-solutions.co.uk/info/Embedded_tutorials/can_tutorial.htm a can tutorial. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 16, 2021 Author Share Posted September 16, 2021 Thanks from csaari: Actually, I believe that 72131AG24A is the vent mode actuator for the 2006-2009 cars. 72131AG27A should be the driver's blend actuator for 2006-2009. There have been discussions about why there are actuators listed for the 2005 cars, and then different ones for 2006-2009, and nobody's ever confirmed or denied that they are interchangeable. Well, I just found a thread on another forum where someone used 72131AG27A in place of 72131AG12A on an '05 Outback successfully. https://www.subaruoutback.org/thread...tuator.501527/ And also thanks to jaylew: I can confirm that it works. I put 72131AG27A in my '05 about 3 weeks ago. Temp changes as expected and best of all...quietly The 2 actuators that are "easy" to get to are the passenger temp and the mode actuator. The outside air/ inside air and driver temp require dash out. Taking the dash out honestly isn't hard Link to comment Share on other sites More sharing options...
Febreze Mee Posted September 16, 2021 Share Posted September 16, 2021 I did my passenger side several months ago. Will probably need to do the others. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted December 17, 2021 Share Posted December 17, 2021 (edited) https://www.designengineering.com/stainless-steel-pipe-shield-4-5-x-8-5/ I just ordered one of these. I saw it in a post the other day. Finally got around to install this, I had to get a longer clamp for the upper set of brackets to go around the top of the Invidia Catted Dp. I was able to use the clamp that came with it, on the lower end of heat shield. I think it was a 4 1/2" clamp that I had in the basement for the top end. Think cloths dryer vent kit, for the home owners. Edited January 23, 2022 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Enlight Posted January 6, 2022 Share Posted January 6, 2022 (edited) Corsa Technic has a large offering of OEM connectors that you can navigate by the number of "ways" (pins). I was able to buy a radio connector in order to merge my different harnesses (STi gauge, aftermarket radio). More sources: I buy everything from 1 of 4 places: Eastern Beaver Cycle Terminal Corsa Technic Ballenger Motorsports Edited January 25, 2022 by Enlight added title 1 muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
k00laid83 Posted February 3, 2022 Share Posted February 3, 2022 I'm taking Max Capacity's suggestion from the post he made on my thread. So I'm making a post on here to see if the community would be interested in these? I've built my prototype harness for my car and I've already sourced the connectors. I use 20-gauge American-made primary TXL wiring and DERAY V25 heat shrink in my harnesses. This should help out the community if they decide to piece together their own fuel pressure sensor kit. The idea would be to piece together your own kit and save money. I know my tuner wants one of these for his personal car and has mentioned how well it's been working with my Accessport. The nice thing is you can use a Honeywell, AEM, Autometer, or a cheap pressure sensor from Amazon. Personally, I'm using one from amazon that people use to replace the Autometer sensor when it goes out. It's great because it doesn't break the bank. I might upgrade to a Honeywell pressure sensor at some point but will do so if my current pressure sensor goes out. Fuel Pressure Sensor: https://www.amazon.com/gp/product/B00NIK9E10/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 1 Link to comment Share on other sites More sharing options...
Tehnation Posted February 3, 2022 Share Posted February 3, 2022 How do you connect it? Are you using a tgv port or something? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 3, 2022 Share Posted February 3, 2022 How do you connect it? Are you using a tgv port or something? Is it possible to have this question answered in the post "k00laid63" posted that in so we don't fill this thread with answers ? Just post the link to the post# in k00laids" thread. I'm not a MOD, but just figure this thread is getting long and a lot to look through to find things. Here is the thread, https://legacygt.com/forums/showthread.php/thinking-making-3-pin-tgv-oil-fuel-pressure-sensor-harnesses-287540.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
k00laid83 Posted February 4, 2022 Share Posted February 4, 2022 How do you connect it? Are you using a tgv port or something? Yes it would be connected to the unused TGV connector. Is it possible to have this question answered in the post "k00laid63" posted that in so we don't fill this thread with answers ? Just post the link to the post# in k00laids" thread. I'm not a MOD, but just figure this thread is getting long and a lot to look through to find things. Here is the thread, https://legacygt.com/forums/showthread.php/thinking-making-3-pin-tgv-oil-fuel-pressure-sensor-harnesses-287540.html I totally agree with Max Capacity. We don't want to to much on here besides provide the actual parts. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 26, 2022 Share Posted August 26, 2022 Ball joint removal tool. Got the link from a member here, apexi, he's seems to be pretty good with fixing these cars. https://www.amazon.com/Astro-Pneumatic-Tool-78620-Subaru/dp/B01JBJFK3C 1 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted January 6, 2023 Share Posted January 6, 2023 Alternator and starters and parts, https://www.maniacelectricmotors.com/subaru.html 1 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted January 27, 2023 Share Posted January 27, 2023 Amazon has gallon jugs of Rotella T6 5w40 for 25 bucks! https://www.amazon.com/Shell-Rotella-Synthetic-1-Gallon-Single-Pack/dp/B01LH7L0KS Link to comment Share on other sites More sharing options...
seanyb505 Posted February 17, 2023 Share Posted February 17, 2023 (edited) Edit - that time when you're pming someone and it posts to the thread you're talking about Edited February 17, 2023 by seanyb505 Link to comment Share on other sites More sharing options...
Enlight Posted June 6, 2023 Share Posted June 6, 2023 Confirming that part no. 45124AG010 is an exact replacement for 45124AG00A upper radiator supports. Installed them yesterday. The two part numbers are about $50 apart (each). 2 1 muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
