StkmltS Posted January 8, 2019 Share Posted January 8, 2019 Perfect timing as I'm revisiting the (total crap) design and execution of my diy smoker. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 20, 2019 Author Share Posted January 20, 2019 (edited) Thanks to Robburns201 for posting this. Excellent video on how to replace PS blend door motors for heat/AC/defrost Also shows good access to change blower motor and cabin filter. It looks like he has several other videos on Subaru parts replacement as well. Worth checking out. Edited January 20, 2019 by JmP6889928 Link to comment Share on other sites More sharing options...
SBT Posted January 22, 2019 Share Posted January 22, 2019 A nice, simple (brilliant) smoke test machine by the same YT member [ame=http://www.youtube.com/watch?v=2U5kFib1WxE]DIY Smoke Test Machine for under $20 EVAP System - YouTube[/ame] - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 25, 2019 Author Share Posted January 25, 2019 Thanks to cmaje72 for finding these and to Max Capacity for alerting me to the posting. These look to be quite good and if you're having rust problems, we all know where they are. This looks like a solid alternative if you're handy with a torch and do your own body work, but even if not, they look like something you would want to alert a body shop to. https://www.subiesavers.com/product-page/03-09-legacy-iv-bl-bp-rear-wheel-arch-panel-right-side?fbclid=IwAR02PavKzzZA5t4VE7VG7XJFpXl36p7ixBh07gqgu60LpFNka3wWuKferjs Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 6, 2019 Author Share Posted February 6, 2019 (edited) Thanks apexi for finding these numbers: MT https://parts.subaru.com/a/Subaru_2005_Legacy-25L-TURBO-5MT-4WD-GT-Limited-Wagon/_80160_6027732/MT--TRANSMISSION-CASE-FITTING/B13-113-02.html AT (I think?) https://parts.subaru.com/a/Subaru_2005_Legacy-25L-TURBO-5AT-4WD-GT-Wagon/_80159_6021879/AT--TORQUE-CONVERTER--CONVERTER-CASE-CONVERTER-CASE/B13-156-03.html Links fixed. Edited February 6, 2019 by JmP6889928 Link to comment Share on other sites More sharing options...
madrig Posted February 6, 2019 Share Posted February 6, 2019 https://www.subi-performance.com/shop Link to comment Share on other sites More sharing options...
Max Capacity Posted February 7, 2019 Share Posted February 7, 2019 (edited) apexi found this site, IMO good prices. https://www.autorimshop.com/ Here's the thread, I got this from, https://legacygt.com/forums/showthread.php/wheel-color-code-277609.html Link still works Feb 12 2021 Edited February 12, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 12, 2019 Author Share Posted February 12, 2019 Thanks Byron (Max Capacity) for these: AEM # 50-1215 FP KIT IN TANK ALC 320LPHW/HKS Bar code 8 40879 02445 1 Link to comment Share on other sites More sharing options...
SBT Posted March 1, 2019 Share Posted March 1, 2019 Subaru OEM brake caliper rebuild kits for 4th Gen LGT/OBXT (and some 2.5i). Link here - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 2, 2019 Author Share Posted March 2, 2019 (edited) https://avojdm.com/dual-zone-av-panel-set-h6217ag911/ Installation here: https://legacygt.com/forums/showthread.php/dual-hvac-double-din-kit-completed-install-thread-153099.html I would have no idea on shipping charges. You would have to contact AVO to find out. Edited March 2, 2019 by JmP6889928 Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 2, 2019 Author Share Posted March 2, 2019 An excellent source for used Subaru Parts: https://subierecycler.com/ Thanks to AwfulWaffle for posting Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 3, 2019 Author Share Posted March 3, 2019 https://www.hfqpdb.com/browse Thanks to Sparkey for finding this extremely useful site. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 15, 2019 Author Share Posted March 15, 2019 (edited) Thanks to Boxkita for finding and forwarding this to me: Saw this on an recent east coaster who's doing a complete updating of his car. https://legacygt.com/forums/showthread.php/month-project-tunred-winter-project-276834.html He posted this link to the a/c unit rebuild -https://legacygt.com/forums/showthread.php/sound-inside-dash-turn-off-car-190728p8.html?t=190728&page=8 I think this is fixed now. Sorry about that hadvw. Edited March 15, 2019 by JmP6889928 Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 15, 2019 Author Share Posted March 15, 2019 https://www.amazon.com/dp/B01I40ZQWE?tag=viglink20901-20 Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 15, 2019 Author Share Posted March 15, 2019 https://www.toolsid.com/oem-tools/block-tester-mpn-27145.html?view=422545&gclid=EAIaIQobChMIscq5756F4QIVBg5pCh0DigZsEAkYBSABEgL-hPD_BwE Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 18, 2019 Author Share Posted March 18, 2019 Just replaced the Shift Gate light on my friends 2001 Subaru legacy L sedan with the 2.5l engine. The bulb size is 2723. I had tried a 37 as that's what kept coming up in certain places but the 37 is a little bigger and the base is slightly wider. The 2723 was a perfect fit. Getting to it is the same as mentioned earlier in this thread, unscrew the shift knob ( just twists off, no set screws), pull the trim piece around the shifter off and then use a flathead screwdriver to very gently pry up the four tabs of the shifter bezel. Directly underneath that to the left of the shifter is the black plastic holder with the lightbulb in the middle. The plastic piece pulls away from the shifter but the wires are very short so it doesn't move far. The bulb socket turns 1/4 turn out of the black plastic holder and then installation is the reverse once bulb replaced. Just wanted to add this in case anyone on the Internet was having as hard a time as I was looking for this bulb size. Thanks to CloudX27 for posting this. Link to comment Share on other sites More sharing options...
rapture Posted March 18, 2019 Share Posted March 18, 2019 Those subi savers thoo!!!!! Thats awesome !! Great find!! Thank yous!!!!! Link to comment Share on other sites More sharing options...
madrig Posted March 21, 2019 Share Posted March 21, 2019 http://www.hardrace.com/index.asp all about bushing ! Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 22, 2019 Author Share Posted March 22, 2019 Thanks to Ryans1000 for finding and posting these Order the two passenger side valve cover vent/equalization hoses on older cars as they are likely to break. both of mine on my 05' GT were corroded on and broke during removal and were not in stock at subaru. the extra heat of the turbo wears down hoses and gaskets. My 2005 gt part numbers were 99071AC010 $10.22 (front) and 99071AC020 $41.22 (rear/firewall/longer hose) Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 25, 2019 Author Share Posted March 25, 2019 (edited) Thanks to Cone Killer originally for finding this and then Sparkey for resurrecting it and re-posting it. https://legacygt.com/forums/showthread.php/sc-power-steering-pump-rebuild-o-rings-239955.html This is not the OE part numbers, however, there are photos and you can see the labels on the source for the o-rings. I would suggest you google the company on the labels (The o-ring store, LLC) and use the part numbers as he has them to purchase these. Perhaps anyone interested could do the same and put together small kits for sale that would make everyone's life a lot easier. Edited March 25, 2019 by JmP6889928 Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 29, 2019 Author Share Posted March 29, 2019 https://www.iwireservices.com/3-pin-plugs Link to comment Share on other sites More sharing options...
madrig Posted March 29, 2019 Share Posted March 29, 2019 https://www.iwireservices.com/3-pin-plugs excellent ! Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 1, 2019 Author Share Posted April 1, 2019 I sent an email to this website asking if they would be willing to make these same caps with LGT on top. No answer as of yet, but these are very cool. https://www.etsy.com/ca/shop/SubieCapsLTD?ref=search_shop_redirect&fbclid=IwAR3S88M5q_D-zAcTjJGV0HmkgxWqSQqHQx2nOoB4HUiaFf2t2v7CCdhlWfE Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 1, 2019 Author Share Posted April 1, 2019 Lifetime warranty $58.37 https://www.ebay.com/itm/Radiator-For-Subaru-Legacy-Impreza-Outback-Forester-2-5-13092/261871846419?fits=Year%3A2005%7CModel%3ALegacy%7CSubmodel%3AGT%7CMake%3ASubaru&epid=1357754824&hash=item3cf8c74413:g:juMAAOSwC5RcXJt8:sc:ShippingMethodStandard!49024!US!-1 Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 6, 2019 Author Share Posted April 6, 2019 Thanks Infosecdad for finding these: 2005 LGT Stock side-feed injectors: 9263K776 Chemical-Resistant Viton Fluoroelastomer O-Ring, 3.5 mm Wide, 20 mm ID, packs of 10 9263K124 Chemical-Resistant Viton Fluoroelastomer O-Ring, 2.5 mm Wide, 8 mm ID, packs of 10 Ordered a pack of ten of each from McMaster, should be here Tue. Then I can be sure, they are good; thought I would leave this here in case someone needed the sizes. The ones I carefully removed to measure are quite dry and cracked. Link to comment Share on other sites More sharing options...
