snow states and trunk weight
Posted
Curious to hear from people who live or have lived in states with real snow accumulation. I'm probably moving to new england area ..hopefully Maine..and want to know if I should be throwng sandbags in my trunk to make sure im getting the most out of my grip and awd.
Thanks in advance for input. :spin:
Posted
You're overthinking this !! Get good winter tires and change your driving habits under snowy/slippery conditions and you'll be fine.
Give it some time and you will wish for snowstorms all year long :D
Posted
I put 2, 50lbs. salt bags in the trunk. Sense are cars are noise heavy, IMO give the car little more balance feel in the slick stuff. Plus you have traction aid (Salt) if you need it.
I have driven the car with & without weight in the trunk & I prefer weight in the trunk for my 120 mile round trip to work & back.
Mileage:331487 Retired/Sold
Posted
I actually have less weight in the truck than stock since my spare, jack, and tool tray are out and don't have a problem in PA winters at all.
Posted
Don't use salt - use sand.
If the salt gets out in the car and attracts humidity you have an immediate rust problem on your hands. Salt is bad for cars.
If you get loose sand in your car all you need is a good vacuum cleaner.
But there's no need for any deadweight in AWD cars - they do very well anyway. And if you want deadweight in the car - a towing rope, a shovel and a set of chains are even better. You will probably use the rope more to pull up other cars than to be towed yourself - so get a good rope.
Posted
in my experience, weight all the way at the back of the car can actually make the back end more prone to slide out. w/ awd and decent tires, traction shouldn't be an issue.
Posted
Thanks for all the answers. I can't wait to hit snow in my LGT. Just left -30 temps in Maine and snowbanks 10-20ft high. Good times. Back in TX and it's 70.. blah
Appreciate the exp. in using and not using the weight.
Posted
Where you moving to? I'm in central maine.
With any lucl ill be working out of South Portland and living maybe gray or windham? Family is all from there..just flew home feom there today.
Posted
heh, I'm home visiting my family in scarborough. wish I had my lgt soooo badly.
I feel your pain. Had to drive my dad's little Barbie car. Volvo S80 hard to convertible. Yuck.
Posted
4EAT - FWD which can send power to the rear
5EAT - 45/55 electronic limited slip center and mechanical limited slip rear
5MT - 50/50 viscous center with limited slip rear
So with the exception of the 4EAT, our cars are 3wd and then 2wd if one slips.
It's not 4x4 with lockers, it's AWD.
(Updated 8/22/17)
2005 Outback FMT
Running on Electrons
Posted
And our limited slip rears are viscous not mech like on the STI. This makes a big difference.
