Speedometer Modification
  • Moderators
Posted
Anyone know how I can get my speedometer to read correct again after switching to LGT-sized tires on my OBXT? A couple things going through my head are the speed sensor (is this in the driver-front wheel area?) and the ECU. Not sure what else would be different on an outback compared to a legacy and also affect the speedometer.
I'd like to start comparing some part numbers, but honestly don't quite know what to even search for.
Not currently in stock :(
  • Moderators
Posted
I did know that our transmissions don't have a speed sensor in them and that it has something to do with the wheel sensor(s). I would imaging that it's only based on *one* wheel sensor though, doesn't seem like it would be helpful to have four signals for the speedometer.
And either way, SOMETHING is different between a legacy vs. an outback that results in the speedometer reading differently--I'm just trying to figure out what that is: wheel sensor, ECU, cluster, all of the above...?
Posted
My guess would be ECU. The ECU may be doing a simple math operation to convert the wheel sensor signal into MPH. It *may* be a simple variable change in the math.
I wonder if you'd get some help over on the romraider forum.
Posted
In that case there's probably a parameter to adjust in the ABS ECU.
And to do that you will at least need the Subaru Select Monitor, or possibly a manufacturer tool unless you actually need a different ABS unit.
  • Moderators
Posted
Best I can tell from opposed forces, the ABS sensors are the same. I'll poke around some more in that direction though, thanks.
