Th3Franz Posted December 22, 2013 Posted December 22, 2013 I have mixed feelings about the ACT streetlite flywheel I installed with my 6MT swap. I ran an 06 WRX flywheel with my previous ACT clutch which was great. My main gripe is how the car transitions from cruising to decel when I lift off the throttle. My car engine brakes too well. But, when I do spirited driving I love the flywheel. Pros of the streetlite: Rev matching is quicker and easierCar flies through 1st and 2nd gear at WOTMore direct connection to the car through the throttle pedal Cons of the streetlite: Have to slip the clutch more when starting from a stopWhen I lift off the throttle in traffic, the car immediately engine brakes HARD and the car bucks in the lower gears. I'm trying to tune around this with adding fuel during tip-out and changing the decel overrunSlightly more noise and vibration, but it's not bad. -Franz The end of a Legacy http://www.youtube.com/th3franz
Idrewthe2 Posted December 31, 2013 Posted December 31, 2013 im trying to decide between the act streetlite and an oem single mass flywheel. i have an 05 lgt with the dual mass flywheel and a slipping clutch. i had a fidanza lwfw in my old n/a 2.5rs and i really liked it, but i dont know if it will be a little too much for my "stage 2" lgt.
Brian3676 Posted December 31, 2013 Posted December 31, 2013 I have the street lite flywheel. It's ok, but looking back, I wish I spent the little extra on a oem Subaru one.
AZP Installs Posted January 3, 2014 Posted January 3, 2014 It's a matter of where you drive/conditions. Having just taken a trip up and down the Eastern Seaboard, I can say if you live anywhere Northeast of Richmond, VA stay away from the super-light flywheels if you daily drive your car. The traffic and start-stops are just a royal PITA with a LWFW IMO. SMFW is the way to go if you are in those situations. -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!"
