CovertRussian's 05 LGT Build Thread
2005 Subaru Legacy GT 5MT
"Comfortable Daily" Build
Engine
Lightweight Crank Pulley - GrimmSpeed
Turbo
Big 16g
Steel Braided Turbo Oil Lines
Intake Mods
Custom 3" Inlet
Custom 3" Cold Air Intake
DIY TGV Deletes
Inlet Evap Delete
Intake Tech Posts:
K&N Typhoon Intake Testing & Fine Tuning Results
TGV Open vs Failed Closed Test
Drop In Filter Testing
Intake Depression (Vacuum) Testing
Perrin STI Inlet Pressure Drop Testing
Fueling
Engine Bay Inline Fuel Filter
Tank Fuel Filter Bypass
FPR Vacuum Line Relocation
04-07 STI Fuel Pressure Regulator
Exhaust Mods
Header - GrimmSpeed UEL PNP Header Overview and Install
Crosspipe - GrimmSpeed
Uppipe - GrimmSpeed - Gasket Ported
Downpipe - Grimmspeed 3.0" Catted
Catback - Custom Quiet 3" SS Single Exit w/STI Muffler
Exhaust Tech Posts
Headers:
OEM UEL Header Design Overview
Tomei 193105 Equal Length Header Design Overview
Backpressure Kit & Testing: Downpipe & Catback Backpressure
Manifold BackPressure: Tomei ELH & 16G Backpressure
Removed Mods:
Tomei 193105 Equal Length Header Install
Uppipe - Invidia HS02SW1UPP
Downpipe - 2.5" Stromung Divorced
Inlet: Perrin STI
Minor Engine Mods
Spark Plugs & Sidegaping
Spark Plugs: SILFR6B8
AC Idler Pulley
Gauges
General & Boost Gauge
Wideband - AEM UEGO
Fuel Pressure Gauge
Maintenance
Banjo Filter Removal
MAF Cleaning
PCV Valve
Timing Belt
Cam Seals
Water Pump
Intake Manifold Gasket
Valve Cover Gasket
Throttle Body Gasket
Lower Coolant Crosspipe
OEM Air Filter Replacement
Injectors
AVCS OCV Replacement
Vacuum Leak Hunting
OBD2 Port Loose Connection Fix
Tuning
Closed Loop to Open Loop Delay Disable
Timing Compensation Zeroing
Disabling AF Learning for Open Loop
Max Airflow Learning Restricting
Timing Map Resmoothing
16G Tuning
Bigger Turbo = Less Timing For Better MPG
16G: Testing Optimal WOT Timing with bigger turbo
UEL vs EL Header Tuning
Base Maps
Stage 0 Safety Tunes
MPG Tuning
Suspension
Front
Front Strut Bar: JDM STI BL/BP
Front Lower Control Arm Rearward Bushing: Whiteline KCA334
Front Lower Control Arm Forward Bushing: Whiteline W0506
Ball Joints: Subaru OEM 20206AJ000
Rear
Whiteline 20mm Rear Swaybar
Rear Trailing Arm Bushings: Whiteline W63398
Rear Lower Control Arm & Bushings: STI Arms & Whiteline W63393
Rear Toe Arm Bushings: Whiteline W64494, Whiteline W63395
Rear Upper Control Arm Bushings: Whiteline KCA399, Whiteline W63396
Tires: Cooper RS3-G1 225/45/17
Tech Posts:
Stock Front Suspension Travel & Camber Curve
Removed Mods:
EMUSA WRX Front Endlinks
08 Spec B Bilsteins + 05 AT Wagon Springs
Tires: Cooper Zeon RS3-A 225/45/17
Tires: Falken Azenis Fk450 215/50/17
Brakes
Centric Rotors & StopTech Pads
Caliper Rebuild
Rusty Rear Line Replacement
Front Caliper Replacement
Front Rotors: 2005 vs 2006+ Comparison
Drivetrain
Flywheel: 2007 WRX Single Mass
Clutch: Exedy Stage 1
Clutch Replacement & Single Mass Conversion Post
Rear Diff Inserts - Whiteline KDT927
Kartboy Short Throw Shifter
Shifter Bushing: ES 19.1102G
SS Clutch Line & Clutch Delay Valve Delete
GoodRidge SS Clutch Line Failure 12.5k Miles in!
Front Axle Reboot on Car (Fast and Lazy Way)
Cosmetic
Trunk Lip
Plasti-Dipped Grill
09 Key/Fob Upgrade & Programming
DRL Disable
STI Homelink Mirror
Handbrake Leather Gluing
Headlight Refinish
S204 Lip Installation
Rear Folding Seat Retrofit
Audio
JDM DCC HVAC Conversion
Speakers: Focal 165 A1 & Polk DB651's
Removed:
Headunit Install Part 1 Part 2
General Build Posts
Passenger Front Wheel Bearing, Ball Joint
Right Axle
Transmission Oil, Kartboy STS, Cabin Filter
Brake Bleeding, Diff Fluid Change, Parking Brake Adjustment
Stock Exhaust Size and Aerodynamics
Vac Leak fixing, TMIC, Stock AVCS Testing
Carpet Holder Fixin'
Full Size Spare, Red GrimmSpeed Crank Pulley
PS Hose O-Ring & Cabin Air Filter Replacement
Custom 3" WAI Intake with BPi Flowstack
Turning WAI into CAI
Sparkplugs Overgapped
Spark Plugs Overgapped Again!
Common Issues
Here is a list of common issues found with these cars.
[list]
[*][b]Turbo Failure around 80k miles[/b] - There are two things that can cause this:
1. Subaru used turbo oil feed banjo filters that get clogged and restrict oil flow to the turbo. [url="http://blog.1aauto.com/2012/05/30/got-subaru-turbo-read/"]Failure Example[/url]. Here is [url="http://legacygt.com/forums/showthread.php/remove-all-banjo-filters-222758.html"]how to remove all banjo bolt filters[/url].
2. Subaru used a preturbo catalytic converter that breaks up overtime and gets logged into the turbo. Please note 2007+ LGT no longer have cats in up pipes. [url="http://legacygt.com/forums/showthread.php/shredded-turbo-uppipe-cat-failure-pics-36523.html"]Failure Example[/url]. Here is [url="http://legacygt.com/forums/showthread.php/install-catless-uppipe-invidia-224448.html"]how to install a catless uppipe[/url].
[*][b]Throwout Bearing failure at around 60k miles[/b] - The push type clutches have badly designed throw out bearings that will get stuck on the pressure plate and destroy the input shaft's snout.  There is a [url="http://www.fredbeansparts.com/subaru-legacy-gt-tranquil-tsk3-sleeve-kit.html"]Tranquil TSK3 snout kit[/url], use this if your snout if yours already has damage.  Sadly there is no permanent fix, even TSK3 TOB's will fail at about 60k miles.
[*][b]Fans always stay on[/b] - This on is 5MT specific, the secondary radiator fan relay can damage the ECU causing the fans to always stay on.  [url="http://legacygt.com/forums/showthread.php/cooling-fan-relay-issue-now-recall-campaign-55332.html"]There is an official recall for this[/url].
[*][b]Dual Mass Flywheel[/b] - Dual mass flywheels should be shunned from all cars, they are big & heavy and only lead to problems.  [url="http://www.carmag.co.za/technical/the-truth-about-dual-mass-flywheels/"]More info on DMF[/url]'s.  Luckily you can upgrade to 07+ single mass setup (flywheel + clutch).
[*][b]Wheel Bearings![/b] - As with all Subaru's, be ready to replace all of the wheel bearings. Allwheeldriveauto.com Did a two part series on Subaru bearings: [url="http://allwheeldriveauto.com/subaru-repair-seattle-wheel-bearings-explained-part-1/"]Part 1[/url], [url="http://allwheeldriveauto.com/subaru-wheel-bearings-explained-part-ii/"]Part 2[/url]
[*][b]Dual Climate Control is physical tied to Radio[/b] - This is a major inconvenience (if you want to user aftermarket head unit) and has issues too.  If one fails it takes the other down with him, LCD screens are known to give out on these too. There is a [url="http://legacygt.com/forums/showthread.php/official-dual-hvac-double-din-jdm-kit-thread-113589.html?t=113589"]JDM Console Swap[/url] but it will cost you around $350 for the whole setup.
[*][b]Front O2 Sensor Failure[/b] - Seems like the Front O2 sensors fail rather often, this is probably because of the O2 sensor being in before the turbo, thus is exposed to very high temperatures.
[*][b]Water Pools ontop of Fuel Rail due to Hood Scoop[/b] - Due to hoodscoop design water tends to pool around fuel rail/coolant reservoir after raining, [url="http://legacygt.com/forums/showpost.php?p=4900942&postcount=225"]example pics here[/url].
[*][b]Stock Tune is Lean in Boost[/b] - Due to emissions US models have a closed loop to open loop delay, this causes you to be lean while in boost, this causes burnt valves and makes motor more detonation prone. [url="http://legacygt.com/forums/showpost.php?p=4725760&postcount=87"]Easily fixable with a tune update.[/url]
[*][b]Stock Tune adds too much timing for Cylinder 2 & 4[/b] - For some reason 05-06 LGT's add 2.11* to cylinder 2 & 4 which are already detonation prone, 07+ tunes add 0*, FXT/WRX also isn't as aggressive.  [url="http://legacygt.com/forums/showpost.php?p=4822363&postcount=153"]Easily fixable with a tune update.[/url]
[*][b]Rear Brake lines rust through[/b] - There is a recall, WQK-47, no matter how bad your lines are, if they are not leaking Subaru [url="http://legacygt.com/forums/showpost.php?p=4920327&postcount=283"]will just put some wax on them[/url]...
[*][b]Front Lower Control Arm Bushings[/b] - Rearward specifically, they tend to rip very easily, OEM ones cost around $15 but don't expect them to last.  Whiteline or Avo makes great replacements, plus you can get caster ones.  [url="http://legacygt.com/forums/showthread.php/lowercontrol-arm-rear-bushing-whiteline-kca334-224449.html"]Replacement How To[/url].
[*][b]Crank Pulley Disintegration[/b] - The rubber/glue on the crank pulleys tends to stop holding and the two parts of the [url="http://legacygt.com/forums/showthread.php/f-crank-pulley-229893.html"]crank pulley separate[/url].  Usually destroys a few items while it's at it.
[/list]
Pictures
http://legacygt.com/forums/attachment.php?attachmentid=240697&stc=1&d=1479085399
http://legacygt.com/forums/attachment.php?attachmentid=240696&stc=1&d=1479085046
Edited by covertrussian
05 LGT 16G 14psi 290whp/30mpg
12 OBP Stock 130whp/27mpg@87 Oct
00 G20t GT28r 10psi 250whp/36mpg
Welcome, learn how to check the oil and keep it topped off, never let it get low.
Nice looking cars.
Read on here. all the info you want is here, hint, read the stickys at the top of each and every forum.
Oh here,
http://people.csail.mit.edu/ilh/vacation/
Engine Build - Click Here
Nice looking cars.
Oh here,
Thank you very much, didn't think these cars would be so cared of oil, but definitely good to know.
I've been lurking these forums for quite some time now, even before the purchase about month ago. I take a lot of pictures as I do the mods, thus I wanted to post them in one stop location. I may be moving some of the posts into individual How To's.
I definitely already got a sunburn from the awesome vacation, but I see you have some 09 vacation pics too, will pass it on to a friend!
Alright onto business of posting the currently done progress. Please do keep in mind, these posts posted on a Nissan forum, thus I might have details that we all already know as Subaru owners.
This is the #1 reason Subaru turbos die often, second reason is Uppipe cat that breaks up over time. For some reason Subaru thought it was a great idea to put a fine mesh filter into the turbo and AVCS oil feed lines.
AVCS Filters
AVCS filters are the easiest to get to and check. Some Subaru's will have the mesh filters right before the AVCS, these have a tendency of getting stuck in the AVCS mechanism.
http://legacygt.com/forums/attachment.php?attachmentid=253914&stc=1&d=1502332136
http://legacygt.com/forums/attachment.php?attachmentid=253917&stc=1&d=1502332136
05 LGT bolt didn't seem to have the filter, but my 04 FXT definitely had them and they poped out of the banjo bolts. Dig around in the AVCS oil hole to make sure the filter is not in there, on my FXT, both filters fell out of the banjo bolt and was inside (hard to spot since they are black like the oil).
http://legacygt.com/forums/attachment.php?attachmentid=253915&stc=1&d=1502332136
http://legacygt.com/forums/attachment.php?attachmentid=253916&stc=1&d=1502332136
Turbo Feed/AVCS Feed
This one is the most important one, if this one is clogged it restricts oil flow to the turbo which causes to starve and fail. Most shops will replace the turbo afterwards without fixing the root cause, clogged turbo feed banjo bolt. Because of this most replacement turbos will fail within the next 10k miles.
Remove the bracket that bolts to the up pipe and to the block.
http://legacygt.com/forums/attachment.php?attachmentid=253918&stc=1&d=1502332136
http://legacygt.com/forums/attachment.php?attachmentid=253919&stc=1&d=1502332136
Then you can see the oil feed banjo, use a 17mm ratcheting wrench to make your life easier.
http://legacygt.com/forums/attachment.php?attachmentid=253921&stc=1&d=1502332136
http://legacygt.com/forums/attachment.php?attachmentid=259017&stc=1&d=1511964587
Filter is still in... pull it out and install the bolt without it. The hard lines have a built in restrictor for the turbo.
http://legacygt.com/forums/attachment.php?attachmentid=253922&stc=1&d=1502332136
http://legacygt.com/forums/attachment.php?attachmentid=253923&stc=1&d=1502332136
This filter is definitely clogged, this caused my car's turbo to go out, sadly the previous owner didn't pull it out, thus the replacement turbo might be in a bad shape too.
http://legacygt.com/forums/attachment.php?attachmentid=253924&stc=1&d=1502332213
Driver Side Head AVCS Feed
This one requires the most work to remove, it's best to do it while you are replacing the timing belt and the cam seals.
Here is a pic of how close the Banjo bolt is to the timing cover, there is simply not enough room to remove it on car without damaging the timing cover. If you grind the hump off, you will have more room to get the banjo out.
http://legacygt.com/forums/attachment.php?attachmentid=253925&stc=1&d=1502332213
This plastic cover is in the way and can only be removed with the cam gears removed. You will need to loosen the dip stick tube to get the plastic cover out.
http://legacygt.com/forums/attachment.php?attachmentid=253926&stc=1&d=1502332213
Finally easy access to the bolt
http://legacygt.com/forums/attachment.php?attachmentid=253927&stc=1&d=1502332213
As expected the filter was in place still
http://legacygt.com/forums/attachment.php?attachmentid=253928&stc=1&d=1502332213
And very dirty, if this was on the turbo feed/avcs line the turbo would be dead due to oil starvation.
http://legacygt.com/forums/attachment.php?attachmentid=253929&stc=1&d=1502332213
I removed the whole hard line, notice that the bolt that goes into the AVCS side itself doesn't have a hump. That hump makes it impossible to remove this banjo bolt with the timing cover on.
http://legacygt.com/forums/attachment.php?attachmentid=253930&stc=1&d=1502332213
I'm going to put the humpless bolt on the head, I also shaved one side of the banjo bolt so that I could squeeze it past the timing cover if I ever have to deal with it again. Do yourself a favor and use new seals on the head it self, you can try to reuse the old seals on the AVCS end, they are easy to replace if they leak.
http://legacygt.com/forums/attachment.php?attachmentid=253931&stc=1&d=1502332213
All done and happy!
http://legacygt.com/forums/attachment.php?attachmentid=253932&stc=1&d=1502332213
http://legacygt.com/forums/attachment.php?attachmentid=253933&stc=1&d=1502332213
It all started with me hearing more wobbling noises, naturally I assumed another wheel bearing is on it's way out, this time right front one. Sadly after all of this work, the noise was still there, I rotated the tires and the noise moved. Oh well at least I needed a new axle/axle seal anyway.
Look at that beefy rotor!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/General/CIMG9574.jpg
This thing does indeed have massive brakes, I can see why Outback guys want to upgrade to LGT setups.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/General/CIMG9614.jpg
What's this... runs to FSM... this car has oem camber adjustment, not used to seeing all of this fanciness!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/General/CIMG9584.jpg
Fanciness ended when I saw that they are crash bolts.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/General/CIMG9609.jpg
Front Wheel Bearing
As I now know the wheel bearing was okish, oh well, I needed a new stud anyway, current one was so rusty that the previous owner didn't have a lug nut. I tried to install one and cross threaded a brand new nut.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Wheel%20Bearing/Front/CIMG9575.jpg
It's bolted up in the back of the hub, do notice the ABS/Speed sensor that needs to be removed before you can pull the bearing assembly out.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Wheel%20Bearing/Front/CIMG9577.jpg
All out
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Wheel%20Bearing/Front/CIMG9579.jpg
All in
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Wheel%20Bearing/Front/CIMG9610.jpg
Well that was easy right? Sure until you need to replace the axle too. Which lead to me needing a new ball joint too.
Ball Joint
The fun began when I tried to remove the lower ball joint knuckle bolt so that I could pull the knuckle out and get the axle out.
As you can see Subaru went with the reversed ball joint setup, I hate these with a passion for this exact reason!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9582.jpg
Luckily I had a spare ball joint sitting waiting (actually it was supposed to go into the Forester)
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9597.jpg
Took the knuckle out and started hacking away
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9594.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9598.jpg
The carbide burr helped a ton with getting the shell of the ball joint out
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9599.jpg
Since the ball joint has a dimple for the bolt, rust tends to form inside, so it's a good idea to clean it up on the inside
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9601.jpg
Next stage of fun, drilling the bolt out, I think Subaru used a grade 8.8 bolt, this thing was a little too soft honestly.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9602.jpg
Threads are useless, best route is to use a longer bolt with a nut now.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9604.jpg
Luckily again I had a long enough 10.9 bolt (P11 6 speed leftovers)
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9607.jpg
And done
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9612.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Suspension/Lower%20Ball%20Joint/CIMG9613.jpg
http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html
That's a dirty filter.
05-06 have them on the passenger side head as pictured and on the front of the drivers side head. You can file the top off the bolt, back it out, remove the filter without pulling the timing belt covers.
HAMMERDOWN did it and posted pictures.
I have mine removed when the new short block was assembled at the machine shop.
Right Axle
Finally onto the main reason why I had to do all of this extra work past the wheel bearing, boot was pretty ripped. I was tempted to repair it, but EMPI axles are $67 shipped, hard to beat that.
http://legacygt.com/forums/attachment.php?attachmentid=258394&stc=1&d=1510890945
http://legacygt.com/forums/attachment.php?attachmentid=258396&stc=1&d=1510890945
http://legacygt.com/forums/attachment.php?attachmentid=258395&stc=1&d=1510890945
Another reason to remove the axle was, the car was bleeding smurf blood due to the axle seal being reused by the shop that did the TOB work!
http://legacygt.com/forums/attachment.php?attachmentid=258397&stc=1&d=1510890945
Got a new seal at Subaru, Part # 806735300, they are about $8 a piece. I at first went to Advance auto, not only did I get the wrong seal (wasn't really showing up in their system) it was more expensive then Subaru seal!
http://legacygt.com/forums/attachment.php?attachmentid=258398&stc=1&d=1510890945
I was able to push it in with bare hands, not sure if I'm happy or worried about that part, with Nissan I'm used to dedicated at least an hour just to get the stupid seals in, this guy went in within 5 minutes!
http://legacygt.com/forums/attachment.php?attachmentid=258399&stc=1&d=1510890945
New axle was a breeze to install too, I gotta say this was the fastest axle/seal job I've ever done.
http://legacygt.com/forums/attachment.php?attachmentid=258400&stc=1&d=1510890945
I gotta do my timing belt sometime this summer (at 98k miles right now), thus I plan on pulling the passenger side filter at that point. Since it's only affecting the AVCS, I'm not as worried about it. But definitely on my to do list.
I hate timing belts and the replacement dances, I've owned nothing but timing chained cars for the last decade, thus it is an unfriendly change. I'm glad that Subaru finally switched to chains for 2014 models though!
Next tip, use anti sieze compound on every nut and bolt you install.
You seem to have clue how to work on cars. That's great.
Oh I learned that a new spindle is like $114. It's sometimes easier to just replace it when doing ball joints. Thats a common problem on these, that bolt always breaks.
2005-06 Legacy GT's have a catalytic converter inside the up pipe before the turbo, replacing gets you ~10whp and might save your turbo. I think Subaru realized this too and in 07 LGT's came with a catless same as STI up pipe, instead they introduced an air pump to help the emissions.
GrimmSpeed did some awesome CFM testing of different up pipes. Catted up pipes flow 165 CFM, you can gut the stock one, very involved process and you run the risk left over material going into your turbo, airflow does improve by 50 CFM (216 total), which is still worse then OEM catless uppipe (at 245 CFM). GrimmSpeed's uppipe did 293 CFM, which is almost double the airflow of stock. Now Grimm's up pipe does have a flex pipe, which IMO are not needed and add turbulence, that plus the price is why I went with the Invidia uppipe.
Up pipe is install is not hard, but is also not easy as the downpipe install. It's just a very involved process where you have to remove the headers and the downpipe.
Gain access to the turbo and downpipe.
http://legacygt.com/forums/attachment.php?attachmentid=256715&stc=1&d=1507959986
http://legacygt.com/forums/attachment.php?attachmentid=256716&stc=1&d=1507959986
Remove the EGT sensor if you can, it will help you more easily pull out the up pipe. Mine was stuck thus I had to remove the uppipe as is, it was still doable, just bent the sensor.
http://legacygt.com/forums/attachment.php?attachmentid=256717&stc=1&d=1507959986
Mine was so stuck I couldn't get it off even with MAP heat while it was off the car.
http://legacygt.com/forums/attachment.php?attachmentid=256726&d=1507960024
Downpipe has a bolt that holds it under the car, but there is also a little bracket that catches it. This was a pain to work with, I ended up cutting the lip off so that I can push down the downpipe more.
http://legacygt.com/forums/attachment.php?attachmentid=256718&stc=1&d=1507960261
Remove the downpipe bolts. There is one downpipe bolt (one on the intercooler side) which was nearly impossible to break loose, just not enough room for a breaker bar and a wrench cuts your hands. Use a screw driver to force the downpipe off the turbo. This all is much easier if you just remove the downpipe all together and replace it with a new one. I don't know why Subaru thought it is a great idea to put two bolts right under the downpipe.
http://legacygt.com/forums/attachment.php?attachmentid=256719&stc=1&d=1507959986
Next is removing the header, first you need to drop the diaper and start removing the super rusty heat shields, to gain access to the nuts on the heads.
Unplug and unhook the O2 sensor from the engine! O2 sensors are very sensitive on these cars, I damaged mine by leaving the exhaust manifold hang on the O2 sensor wires!
http://legacygt.com/forums/attachment.php?attachmentid=256720&stc=1&d=1507959986
http://legacygt.com/forums/attachment.php?attachmentid=256721&stc=1&d=1507959986
Don't forget to unbolt the up pipe from the header too.
http://legacygt.com/forums/attachment.php?attachmentid=256722&stc=1&d=1507959986
Up Pipe removed:
http://legacygt.com/forums/attachment.php?attachmentid=256723&stc=1&d=1507959986
Grab it and pull it out
http://legacygt.com/forums/attachment.php?attachmentid=256724&stc=1&d=1507959986
Invidia vs OEM catted up pipe header end:
http://legacygt.com/forums/attachment.php?attachmentid=256725&stc=1&d=1507959986
OEM LGT uppipe entry is about 40mm
http://legacygt.com/forums/attachment.php?attachmentid=256728&stc=1&d=1507959986
STI Uppipe is not much abetter at about 43mm
http://legacygt.com/forums/attachment.php?attachmentid=256729&stc=1&d=1507959986
It should be well over 50mm to not be a flow wall, this is the exact reason why I like the Invidia Uppipe.
2016 Edit: I recently discovered that OEM gaskets are much bigger then the ID of the uppipe, this is why the black ring is there, it's not from stock up pipe being that much smaller then the head exit.
http://legacygt.com/forums/attachment.php?attachmentid=256727&stc=1&d=1507959986
Invidia vs OEM catted turbo end:
http://legacygt.com/forums/attachment.php?attachmentid=256730&stc=1&d=1507961159
Invidia has smooth transitions inside the pipe, it does also have not an ideal taper on header end.
http://legacygt.com/forums/attachment.php?attachmentid=256733&stc=1&d=1507961159
http://legacygt.com/forums/attachment.php?attachmentid=256734&stc=1&d=1507961159
Compare that to the OEM uppipe, it's like it was purposefully designed to suck and reduce power.
http://legacygt.com/forums/attachment.php?attachmentid=256735&stc=1&d=1507961159
Turbo end shows the cat and EGT, notice how poor the transitions are.
http://legacygt.com/forums/attachment.php?attachmentid=256736&stc=1&d=1507961159
Invidia uppie has a bung for the OEM EGT, but oem EGT is meant for checking the health of the cat only, it's too far away to give accurate EGT, plus it can break and kill your turbo and finally I'm hearing they burn up faster without the cat. You will need a hard to find M12x1.25 bolt, parts stores do sell drain plugs in that size for around $5. I was able to find a plain bolt at local hardware store and cut it to fit.
http://legacygt.com/forums/attachment.php?attachmentid=256731&stc=1&d=1507961159
http://legacygt.com/forums/attachment.php?attachmentid=256732&stc=1&d=1507961159
Gaskets, now is the time to replace those 10 year old gaskets...
http://legacygt.com/forums/attachment.php?attachmentid=256737&stc=1&d=1507961159
Getting the uppipe was not hard, but trying to hold it and bolt a bolt up did get tricky, not enough hand room.
http://legacygt.com/forums/attachment.php?attachmentid=256738&stc=1&d=1507961159
http://legacygt.com/forums/attachment.php?attachmentid=256740&stc=1&d=1507961159
I personally tightened the the turbo bolts before getting the header attached, if you keep them loose it might make it slightly easier to get the header installed.
http://legacygt.com/forums/attachment.php?attachmentid=256739&stc=1&d=1507961159
http://legacygt.com/forums/attachment.php?attachmentid=256745&stc=1&d=1507961159
Get new gaskets on the header, and bolt everything up.
http://legacygt.com/forums/attachment.php?attachmentid=256741&stc=1&d=1507961159
http://legacygt.com/forums/attachment.php?attachmentid=256742&stc=1&d=1507961159
http://legacygt.com/forums/attachment.php?attachmentid=256743&stc=1&d=1507961159
http://legacygt.com/forums/attachment.php?attachmentid=256744&stc=1&d=1507961159
Now I didn't realize this until I started looking for exhaust leaks do to a whiny O2 sensor code. Apparently I put the second gasket ontop of the stock one, fitment is perfect and I see no leaks, thus I think this up pipe might actually be a little short, if it prevents cracks I'm all up for it too!
http://legacygt.com/forums/attachment.php?attachmentid=256748&stc=1&d=1507961159
All of this took about 4 hours, rusty parts and stuck bolts is the main reason for why it took so long. I'll do some Virtual Dyno runs in the next few days and will see how it did powerwise, also will see if MPG improves.
Results
Finally did a virtual dyno, I rest the ECU for both runs, and drove the car until IAM hit 1.0 that way timing would be identical for both runs. Waited for another warm day in November and did another run, compensating for temperature, pressure and fuel/toolbox weight. 7whp/10wtq peak gains!
http://legacygt.com/forums/attachment.php?attachmentid=256749&stc=1&d=1507961159
Do notice the AFR dip, this is a stock sensor thus it only reads to 11.1 and even then it's not accurate. I'll have my MTX-L hooked up after I get rid of the P11. Also please note that this is not necessarily the best road for peak WHP (slight up hill), but it's very easy for me to do repeat runs on this specific road. On a straighter road the car is making 213whp.
CEL Fixing
Removing the EGT sensor will cause a CEL, thus you have to either reflash the ecu with codes off (best method), or use a resistor patch (will work, but I've had some issues after some time).
Disabling the CEL's through reflash
Disabled these codes in your tune:
P0420 - Catalyst System Efficiency Below Threshold
P0545 - Exhaust Gas Temperature Sensor Circuit Low
P0546 - Exhaust Gas Temperature Sensor Circuit High
P1301 - Misfire Detected (High Temperature Exhaust Gas)
P1312 - Exhaust Gas Temperature Sensor Malfunction
P1544 - Exhaust Gas Temperature Too High
Resistor
I highly suggest using the reflash route, resistor patch for me would throw intermittent CEL's and cause cruise control to fail. Since I have re flashed the ECU with resistor disabling CEL's, I've never had this issue happen to me.
Get a 2.2-kohm 1/2-watt Resistor (Radioshack # 2711121), this resistor makes the ECU think the EGT is always at 1292 *F.
http://legacygt.com/forums/attachment.php?attachmentid=256746&stc=1&d=1507961159
Tape it off so it doesn't fall out
http://legacygt.com/forums/attachment.php?attachmentid=256747&stc=1&d=1507961159
Did you use a OEM front O2 sensor. If not, do that next time. Trust me again. the rear O2 can be after market...so far mine is good, but I had to replace the 2 year front with a OEM one last month.
Same with Hubs, front should be OEM, rears can be Moog
Holy shit that's a lot of crap in the bb filter. FWIW I never had more than a fleck or two in mine. I usually check once every 2 years.
Is the car on its original turbo still? I'd pull the DP and check the turbo for shaft play ASAP. A full oil system flush is probably in order too.
Previous owner said the turbo did die on him, probably at around 85-90k miles. He had a shop replace it with another used turbo, problem is, this car ran for probably around 7k miles on the same filters that caused the initial turbo death. I'll check for shaft play when I do a downpipe, but I got a spare VF39 that I was going to use on the FXT, but it might be put on the LGT instead...
I'm beginning to see why myself too, it's the whole causation to correlation. Do these cars rust a lot/and have stuck bolts because the owners buy them for snowy climates or do they rust a lot because Subaru did something.
Good to know on the spindle, I am fairly determined to make something work, even if it takes a few extra hours. Car working is a hobby for me, thus I do everything myself (even mounting and balancing tires if I can get access to the machine).
Oh another hint, save the old OEM axle and rebiuld it for next time...trust me on that one.
Yup already doing so, since it's not clicking, I will rebuild it and use it on passenger side if I have to.
I used Denso 234-9120, which I'm hearing is the oem version of the sensor.
Topping off Transmission Fluid
My transmission oil was a little low, which is probably due to the bad axle seal that I replaced earlier. Subaru decided to be nice to their owners and added dip sticks for manual transmissions too! Locating it can be difficult at first though.
Hidden to the right of the turbo
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Drivetrain/Fluid-Change/CIMG9746.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Drivetrain/Fluid-Change/CIMG9747.jpg
Pull it out and you will be given easy to read lines, why couldn't the oil dip stick be this easy to read Subaru? :confused:
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Drivetrain/Fluid-Change/CIMG9748.jpg
SMURF BLOOD! The previous owner had the car serviced at Andrewtech, which came up with this awesome concussion. 3 quarts of Redline Lightweight Shockproof and 1 quart of Motule 300 to make it more liquid for easier winter shifting. I ordered 1QT from Amazon, thank to prime it was here in no time. Sadly Redline Oils are running $17 per qt nowdays, I remember when it was $7 :(.
Getting the oil in requires a long funnel, I got this guy a long time ago, but never really used it since it's easier to use an oil hand pump on SR20's. Finally it's coming to use, this is the only way to really get the oil in.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Drivetrain/Fluid-Change/CIMG9749.jpg
I added about 1/4 of one quart and it's showing more then full, just something for you to consider when refilling.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Drivetrain/Fluid-Change/CIMG9750.jpg
Kart Boy Short Shifter
Here is one benefit to buying a used car, you are sometimes surprised with little mods like this. I've been very pleased with this car's shifter (short throw and precise), and I thought that was a Legacy GT feature over the Forester's shifter (very long and sloppy).
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Drivetrain/Shifter/CIMG9776.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Drivetrain/Shifter/CIMG9777.jpg
Thank you previous owner X, you saved me $100 that I would have never spent on a shifter, but now I'm highly contemplating on it for the Forester...
Cabin Airfilter Addition
You read that correctly, it would be called replacement if there was a stock filter there to begin with. Apparently in 2005 Subaru didn't think cars could benefit from cabin filters, they added the ability to add one, just didn't add one themselves.
Well since this car wasn't designed with the end user replaceable cabin filter, they didn't make it easy... Yes you have to pull the center console off, I was lazy and got half of it off.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Cabin%20Filter/CIMG9763.jpg
Almost there
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Cabin%20Filter/CIMG9764.jpg
This was anticlimactic for me... I really thought by 2005 ALL cars would have cabin filters
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Cabin%20Filter/CIMG9765.jpg
Got a FRAM carbon cabin filter (I can only trust FRAM for small things like cabin filters)
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Cabin%20Filter/CIMG9766.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Cabin%20Filter/CIMG9767.jpg
I used to hate spoilerless cars, but I actually wanted a spoilerless Legacy. Part of it is because of the super big stock spoiler which I don't care for, another part is because I've started appreciating simple trunk lips.
Luckily now days China (through eBay) is spitting out prepainted lips for $35 shipped! I am amazed that they are able to even paint it for this price (they sell unpainted versions for $27).
http://legacygt.com/forums/attachment.php?attachmentid=258401&stc=1&d=1510891200g
Obviously it wont fit like that, I kept it inside the house to get it to be a little more flexible. Doing this on a hot day would probably yield better results with less effort.
http://legacygt.com/forums/attachment.php?attachmentid=258402&stc=1&d=1510891200g
Just lay it down and start removing the wrap from the double sided tape, do notice the gap, the lip is a little short (not sure if on purpose or because it's an M3 ripoff branded to fit on the Legacy)
http://legacygt.com/forums/attachment.php?attachmentid=258403&stc=1&d=1510891200
http://legacygt.com/forums/attachment.php?attachmentid=258404&stc=1&d=1510891200
http://legacygt.com/forums/attachment.php?attachmentid=258406&stc=1&d=1510891200
http://legacygt.com/forums/attachment.php?attachmentid=258405&stc=1&d=1510891200
Paint seems to blend in well, the lip itself is very low key and looks oem.
http://legacygt.com/forums/attachment.php?attachmentid=258407&stc=1&d=1510891200
http://legacygt.com/forums/attachment.php?attachmentid=258408&stc=1&d=1510891200
  • I Donated
2001 Nissan Sentra SE - JDM SR20DET + T25 + BC Coilovers/Ton suspension mods
http://images.rvsmods.com/var/albums/Cars/B15/Pics/Events/SR2013-Convention/AMP0333-%28ZF-9054-24764-1-005%29.jpg?m=1372429884
Check my avatar photo. ;) Nice to see you on here. I had a VE'd P10 before I got into LGTs.
Yes sir! You're the reason I started looking at the dark side. Being able to put down all the power like you did at the drag strip was just amazing. I should have gotten a ride in your car :).
Here is us going at it at the drag strip. It was a very hot day with not a fully prepped drag strip, hence the high times for both cars.
http://rcresciphoto.zenfolio.com/cdn/pub/4i7tfropdnaf/0/null/mk/nu39jnizjndurjzm9c1x/s9/v91/p1806094835-4.jpg
My B15 Sentra is on the left, was making about 160whp to a 2700lbs car. First gear would not hook at all, if I could hook first, I think I would give your car a better run for your money.
Legacy GT's all came with dual climate control, while it keeps the marriage be in harmony on long trips, Subaru decided to marry the climate control into the radio. That means it's one giant unit, and you try to take out out you loose the other. Now you can get a JDM dual climate control unit that is separate thus giving you a double din area, but the cost of them alone is around $350, then add on the cost of stereo and the wallet starts to cry.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9751.jpg
The idea is to put the radio into the ashtray/cig lighter location. The idea comes from this thread.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9753.jpg
Remove the ashtray and cig lighter
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9757.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9759.jpg
Sadly there is an airbag module with plastic wall in the way, I'm not sure how the guy in the Legacy thread was able to fit his radio in, perhaps it's much shorter then mine? Just can't get that angle in without hitting things.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9761.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9762.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9769.jpg
Pulled the stereo out, look how much space there is being eaten by the stock setup!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9771.jpg
Here is the clunky radio and climate control
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9773.jpg
Started dremeling, still can't get the angle right or enough space to clear the airbag module, thus cut the divider off altogether.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9779.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9780.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9783.jpg
Finally can get the headunit in
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9785.jpg
Now gotta get the shifter bezel comply, cut the tabs to be able to get the head unit closer.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9814.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9817.jpg
As you can see that's still not enough, needs a bigger window
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9821.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9820.jpg
Now it fits better
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9836.jpg
Install to get my dreams crushed by the airbag module not letting me to angle it enough!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9839.jpg
After working on it for a few days, It was snowing, thus I wanted to be done with it until the spring so just found a way to mount it for now.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9843.jpg
Wiring Harness
To be able to maintain climate control, we will need to split power and send it to the headunit still. Thus you will need a Reverse and Forward facing Subaru radio harnesses, plus antenna adapter.
Issue with most aftermarket forward facing harnesses is they are missing Pin #7 which is for illumination an is important! I simply bought two of them and stole a pin from one of them.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9731.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9733.jpg
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9734.jpg
You can test the fitment/resistance of the wires with your two plugs
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9735.jpg
Depin the reverse facing harness, remove speaker wires, antenna etc, leave only power/ground and illumination wires. You don't want to have those wires to be even in there, otherwise you can get a short and kill your factory radio.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9737.jpg
Crimp/solder heat-shrink and your done
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9736.jpg
Back to hooking up the radio, the factory radio has three additional plugs that need to be hooked up along with your reverse facing harness.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9846.jpg
Plug up the aftermarket head unit, you can see the antenna adapter here too
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9848.jpg
After all is in place, checking airbag module clearance
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9849.jpg
Done for now, nice to have USB playback again!
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9855.jpg
And you can make out the radio from drivers view, which is a nice plus.
http://i160.photobucket.com/albums/t188/covertrussian/Cars/05%20LGT/Interior/Radio/CIMG9860.jpg
This ran me up about $30 with all of the harnesses/adapters. I now have good music for some long trips coming up, I may switch to a proper JDM unit in the spring, but I would rather spend the money elsewhere if this lasts.
When you drain the tranny, you need to jack up the back of the car to get all the old stuff out.
That's actually a great tip, I didn't even consider it (FWD you just raise the front up and it's good to go). In this case I was just topping it off so will use this advice on the FXT when I go to change the oil (pesky 1st and 4th gear grind).
Yes, the tranny has a low spot that holds fluid unless you raise up the back.
You didn't say where you live ? Somewher in MD ?
Oh do you plan the change out the leaking valve cover gaskets ? Remember to replace the 1/2 moons too.
