ryu2112 Posted December 12, 2013 Posted December 12, 2013 Just got these codes when I started my car up this morning (30 degree weather). Can anybody show me a picture of the TGV? I've read some posts to clean the electrical connectors, but I can find any pictures showing where this is. Thanks in advance.
JmP6889928 Posted December 12, 2013 Posted December 12, 2013 Directly underneath where the intake manifold bolts to the heads there are what looks like some small spacer/towers between the plastic manifold and the cylinder heads. Those are the TGV's.
Max Capacity Posted December 12, 2013 Posted December 12, 2013 http://i185.photobucket.com/albums/x40/92Si/DSCN4750.jpg In the lower right corner you can see the one connector that is in front of the turbo, on a 2005. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
kzr750r1 Posted December 7, 2016 Posted December 7, 2016 Does TGV delete kit fail emission/smog test? If the tech is looking that deep at the assembly... Possibly. If you have your cover on and everything looks lean likely not. Just so long as there are no codes it should be good.
