ajumper Posted October 21, 2013 Share Posted October 21, 2013 I am being told that my Body Intergrated Unit has failed in my 2010 Legacy, The car won't even try to start. The car has about 72,000 miles the mechanic that I normally take it to could not determine what the problem was and had me take it back to the dealership. Dealer says BIU is bad needs to be replaced $1100.00. My mechanic says that should be covered as part of the 8 yr/80000 mile emmision warranty. Has anybody else experienced any issues with a Body Intergrated Unit and if so was it covered under warranty if not how much did it cost? Link to comment Share on other sites More sharing options...
Th3Franz Posted October 21, 2013 Share Posted October 21, 2013 Probably not powertrain or emissions warranty for that item. You may want to try sourcing one from a junk yard. Did the dealer offer to swap the BIU from another car to prove that is the problem? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
ajumper Posted October 24, 2013 Author Share Posted October 24, 2013 No, Dealer did not offer to swap the BIU. Update The BIU came in and it was installed and did not fix the problem. Still no solution. I want them to check the Engine Control Module but they insist that this could no be the problem. Link to comment Share on other sites More sharing options...
Jay12Legacy Posted October 27, 2013 Share Posted October 27, 2013 Cant swap biu cause wont talk with diff ecm dis the replace all keys with the new biu Jay Link to comment Share on other sites More sharing options...
