king26 Posted October 17, 2013 Share Posted October 17, 2013 Its time to do a head job on my 06 2.5i and they need to be machined. I found some heads off of an ej255 that are already rebuilt and am wondering if they would bolt on and what, if any, wiring changes would be involved. Also would I see any performance gains. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 17, 2013 Share Posted October 17, 2013 Yes, they will bolt on. But they are dual cam where your heads are single cam. Do you now see the problem ? Your better off to stick with what you have. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
king26 Posted October 17, 2013 Author Share Posted October 17, 2013 They are complete heads with camshafts if you are talking about my engine being a camshaft short. Other than that I don't know. Hence me asking. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 17, 2013 Share Posted October 17, 2013 They will not work on your engine without major MOD's. Stick with your oem heads. I see your new....so I'll be nice. There are other forums that may be better for you that deal with your 2.5i. Most of the talk here is about Legacy's with turbo's. Mainly the 4th and 5th Gen's. Your last car wasn't a Honda Civic was it ? I know guy's do all kinds of crazy things with D16 engines. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
king26 Posted October 17, 2013 Author Share Posted October 17, 2013 Thanks for your help (I think). If any other members have anything non dickish to add feel free. Link to comment Share on other sites More sharing options...
700watts Posted October 17, 2013 Share Posted October 17, 2013 If you were able to get them to work, I don't think you'll realize any power gain. As with out a turbo you'll be effectively lowering your compression ratio. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 17, 2013 Share Posted October 17, 2013 Thanks for your help (I think). If any other members have anything non dickish to add feel free. To put it in plain English, this is not a good idea. Stay with the heads that came off your 2.5i it will be much simpler. If I really wanted to be a more diskish. I could have. I hope you didn't take offense to the Honda Civic. I happen to have built one for drag racing. So it wasn't meant in a bad way. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
frank_ster Posted October 17, 2013 Share Posted October 17, 2013 the ecm would have to be changed with wireing harness and then intake and and and and .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
PutnamCO Posted October 17, 2013 Share Posted October 17, 2013 Thanks for your help (I think). If any other members have anything non dickish to add feel free. Welcome to the forum. Just make sure you're not being "dickish" to anyone, and people will be happy to help you. Particularly members like Max Capacity who consistently posts informative and helpful answers with great frequency. Link to comment Share on other sites More sharing options...
frank_ster Posted October 17, 2013 Share Posted October 17, 2013 you need the heads and the 4 cam gears the intakes are avcs so they are realy expensive. lgt wiring harness for the cam sensors as they are in different places and work differently lgt ecm and anty theft devices lgt timming cover lgt coil on plugs lgt injectors lgt oil lines to the heads and not sure if the ej253 has the bungs lgt fuel rails lgt intake and tgv's and then you need custom air intake . Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
king26 Posted October 18, 2013 Author Share Posted October 18, 2013 Thanks everyone for the input. This is just my winter car and was hopeing that it would be less expensive to fix since its a friend who has these heads. Looks like I will be taking the 253 heads to the machine shop. Link to comment Share on other sites More sharing options...
king26 Posted October 18, 2013 Author Share Posted October 18, 2013 And sorry max capacity. It felt like you were giving me an attitude with your civic comment. But you are close in your guess. My other car a s2000. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2013 Share Posted October 18, 2013 S2000, nice, my son has a 2004 yellow one. Can you see my avatar ? that was the 9 second single cam, 1.6L 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
