steve118 Posted October 13, 2013 Share Posted October 13, 2013 i have a 1997 subaru legacy gt 5sp manual, but after a few days driving it i noticed that the temp gauge on the dash shoots through the roof after about 10 minutes of driving. is this part of a common fault? any ideas what it could be? any help appreciated, thanks btw, it has done 206k kms on body and 160k kms on engine standard parts Link to comment Share on other sites More sharing options...
derp Posted October 13, 2013 Share Posted October 13, 2013 could be the thermostat. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 13, 2013 Share Posted October 13, 2013 It could be a bad thermostat, air bubbles in the coolant, or failing head gaskets. If the thermostat is not an OEM Subaru thermostat that can cause overheating as well. Purge the air in the system, and get a hydrocarbon test done which will test for exhaust products in the coolant. Check the overflow tank while the car is running and look for bubbles which can indicate failing head gaskets. Is there white smoke in your exhaust? Head gasket failure is almost inevitable on your model at some point. Link to comment Share on other sites More sharing options...
steve118 Posted October 14, 2013 Author Share Posted October 14, 2013 no noticeable white smoke in the exhaust. Where can i find the overflow tank? sorry for sounding dumb, my first subaru. Link to comment Share on other sites More sharing options...
IrishLt Posted October 14, 2013 Share Posted October 14, 2013 Hopefully that showed up right. I like pictures when explaining things. Takes the guess work out of stuff. Here's hoping it's a T-stat. Good luck -LT PS- Try not to run it as is and let it overheat. The factory headgaskets are finicky enough on the 2.5s. Link to comment Share on other sites More sharing options...
