Fog Lights Not Working?
thanks for the replies guys.
i removed the two bolts holding it in, well i tried haha (the left side ones were rusted and snapped, oops)
found that the left bulb had blown, and the right had not been plugged in properly.
but those are just the projector ones, there are still two more. bulbs are fine, grounding is fine. not too sure what else to check.
i'm not familiar with the wiring, but there has to be a relay.
most of the on / off switches on these cars switch the ground wire.
meaning there should be power at the relay but it does not activate until the ground is connected.
the actual light has no power until the relay is energized.
