stage 2 questions
Today I installed a 2007 STI uppipe and invidia catless dp into my 2006 LGT 5EAT. I'm 17 years old, it took about 7 hours doing it alone on axle stands lol. I have Cobb v3 to go along with it, and when I reflashed to stage 2 and drove it (no problems, smoke, leaks etc.) It seemed faster than stage 1, but not as much as I was expecting. My question is: does the ecu take time to get used to and adjust to the new mods?
Not really, as with any time you reset the ECU it will start with an IAM (ignition advance multiplier) of 0.5-0.75 then after a bit of driving it will rise to 1. So there is a slight difference in ignition advance until the multiplier reaches 1.
Also any time you reset the ECU the computer will relearn the fuel trim adjustments. Unless you've got something wrong with your intake then these will be minor adjustments (+ or - 1%) and unnoticeable.
The map that is flashed on by the AP is used by the ECU immediately to control the engine, so the IAM and fuel trims are the only part that the ECU will adjust to.
A dyno/e-tune will always be better (in terms of power and reliability) than the off the shelf cobb maps as they're tailored for your specific car and engine. That might get you a bit more power but nothing amazing.
TL;DR - No the ECU doesn't really need to adjust. Stage 2 isn't hugely powerful (although compared to stock it is a big improvement), it is just a retune of your stock parts + new DP
Thanks a ton, I'll definitely consider a professional tune...but who knows, maybe a vf39 is in my future
aren't the 39,48 and 52 essentially the same turbo? 52 is the latest revision so more reliable, have heard of waste gate cracking issues with the 39
The 39 in the 48 are sti fitment. The 52 is for the 09 and newer WRX which has the same basic intercooler/bpv configuration as the 4th gen LGT
Sent from my SAMSUNG-SGH-I747 using Tapatalk now Free
The difference from bone stock with no tune at all to Stage 2 with a tune should be a pretty good jump. If you're saying it didn't feel that much faster, either
1) you're used to faster cars
2) your sense of speed is out of wack
3) something is wrong
How much boost are you making according to the AP? Better yet, pull a datalog.
I could feel a significant difference from stock to stage 2...it's stage 1 to stage 2 that I'm referring to. Don't get me wrong though, I definitely feel and hear a difference, it just wasn't as big of a power jump that I felt from stock to stage one...and let's definitely keep this turbo conversation going haha would the vf52 be a direct bolt on swap followed by a pro tune?
Stock to stage 1 isn't really a power upgrade. It's more of a driveability upgrade. Stage 2 should've been a bigger jump from stage 1 as far as feel goes. You really should pull that datalog to be on the safe side.
This. Stage 1 was only noticeable to me since I drive it everyday. Stage 2 should feel substantially different.
