Brake issue - 07 Spec B - Squishy Brakes
psulemon
Basic information
07 Spec B, StopTech Pads, Centric Rotors and stock lines (because we discovered one line had a stripped bolt so I couldn't do my stoptech lines.
Anyways, we got the brakes and rotors changed without an issue. We saw a thread on the gravity method (to include using the turkey baster to extra from the reservoir) of bleeding the brakes, so we tried that. Once we finished up, I noticed the pedal wasn't firm and sunk right to the floor. Ok, no problem... so I decided to go old fashion and used each other to bleed the brakes. After that, the pedal felt pretty firm until I turned on the car. So when the car is off, the pedal is very firm and doesn't move, but as soon as I turn the car on, which I assume the ABS sensor is begin activated, it gets really soft.
Anyone have this issue?
Side note, we did go through an entire bottle of Motul 5.1 (yes, I realize this is overkill but my buddy got a great deal on it). The reservoir is full, so I am a bit perplexed.
That's how stock lines feel, soft/squishy. Put on the braided lines and there will be a good improvement.
SS lines do very little for our brakes unless your lines are totally degraded. If the fluid was black then a line replacement will help since that's the inner walls of your lines in the fluid.
I did brakes in this order to determine what did and did not offer better pedal feel:
1. Grimmspeed Master Cyllinder Brace - this was a huge improvement alone (with all else being stock), because it takes the soft firewall flex out of the equation.
2. New Pads and rotors - I was due and went Stoptech. After bedding brakes were really good.
3. Fluid flush and refill and bleed with SS lines - My Stoptech kit came with lines so it was just to do as preventative and see what kind of improvement I would get. It made no difference in pedal feel, just freshened up the equipment. My OEM lines were fine - YMMV.
Sounds like you need to bleed the brakes again since you have some air in the lines.
You either still have air trapped in the system somewhere (maybe even the ABS sensor...) or you blew out the seals in your MC if you stepped on the brake too hard while the lines/bleeders were open.
Sounds like you still have air in the lines somewhere.
-Mike Paisan
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Now we have an Online Catalog where you can purchase Parts! AZPParts.com
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
