Moderators BarManBean Posted November 13, 2014 Moderators Share Posted November 13, 2014 Took a look at the process west splitter last night--it meets up with the TMIC on my outback, stock spacers still installed. That must mean that although the OBXT engine sits lower, the piece of the splitter that you reuse with the PW splitter is likely larger than the LGT equivalent, thus pushing the splitter farther down so it meets up with the TMIC. Hopefully that makes sense. If you've never pulled the factory splitter apart or really looked at it, it might not make sense. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Rhitter Posted November 13, 2014 Share Posted November 13, 2014 Took a look at the process west splitter last night--it meets up with the TMIC on my outback, stock spacers still installed. That must mean that although the OBXT engine sits lower, the piece of the splitter that you reuse with the PW splitter is likely larger than the LGT equivalent, thus pushing the splitter farther down so it meets up with the TMIC. Hopefully that makes sense. If you've never pulled the factory splitter apart or really looked at it, it might not make sense. Did you run into any of these issues when installing your PW? http://forums.nasioc.com/forums/showpost.php?p=40372595&postcount=38 My OBXT build Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 13, 2014 Moderators Share Posted November 13, 2014 Nope. I have a 6mt, but doubt that matters. Same CMC, different slave I think tho. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
INVNO1 Posted March 30, 2015 Author Share Posted March 30, 2015 My weekend http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150329_104927_zpsaywlxtse.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150329_133836_zpst6la1ten.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150329_150500_zpsadmf4mpw.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150329_150513_zpsifv24iwc.jpg Link to comment Share on other sites More sharing options...
Rhitter Posted March 30, 2015 Share Posted March 30, 2015 Specs? My OBXT build Link to comment Share on other sites More sharing options...
Nightmaresmk Posted March 30, 2015 Share Posted March 30, 2015 Very nice. Link to comment Share on other sites More sharing options...
bikerx500 Posted March 30, 2015 Share Posted March 30, 2015 I hope that your going to be the one exception where that blue timing belt on there wont have problems with the blue backing coming off on the tensioners and messing with timing... Link to comment Share on other sites More sharing options...
Nightmaresmk Posted March 30, 2015 Share Posted March 30, 2015 Mines had the blue for 40k miles. the blue may rub off but no timing issues. Link to comment Share on other sites More sharing options...
INVNO1 Posted March 31, 2015 Author Share Posted March 31, 2015 Specs? EJ257 702 block halves new nitrated sti crank Pauter X-beam rods Manley 100mm pistons ARP head studs V25b 07' sti heads heads ported and blended Supertech valves Supertech valve seals Cosworth valve springs Cosworth retainers Gates blue belt kit New oem sti 11mm oil pump Killer B oil pick up Killer B baffle Killer B oil pan AP equal length header (ceramic coated and wrapped) TGV deletes FIC 1100cc injectors FIC fuel rails ATP/Garrett GT3076r with billet TR3030R compressor wheel AVO 3" turbo inlet Turbo XS uppipe ewg Tial 38mm mvs wastegate Fuelab fpr KS Tech 73mm intake Turbo XS fmic Grimmspeed dp Comp Clutch stage 3 kit Link to comment Share on other sites More sharing options...
Nightmaresmk Posted March 31, 2015 Share Posted March 31, 2015 Be careful with the wrap. it's easy to over do and even the holy header will crack when wrapped wrong. Link to comment Share on other sites More sharing options...
INVNO1 Posted March 31, 2015 Author Share Posted March 31, 2015 Test fitting the turbo and new AVO 3" turbo inlet. http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150330_163016_zpsqglni5ic.jpg I am sending my second set of timing covers out for hydro dipping so please disregard how dirty these ones are. LOL! http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150330_163042_zpsnshmpqlt.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150330_163115_zps7f9lqstq.jpg Link to comment Share on other sites More sharing options...
Nightmaresmk Posted March 31, 2015 Share Posted March 31, 2015 Nice. I wonder how this will spool compared to the spoolinator kit from killer b. Link to comment Share on other sites More sharing options...
eatwagondust Posted June 10, 2015 Share Posted June 10, 2015 nice build. fmic needs more blackness for sleeperness Link to comment Share on other sites More sharing options...
INVNO1 Posted June 16, 2015 Author Share Posted June 16, 2015 nice build. fmic needs more blackness for sleeperness HAHA!! I have been thinking about it, but I still like seeing it up there. Link to comment Share on other sites More sharing options...
INVNO1 Posted June 16, 2015 Author Share Posted June 16, 2015 Pretty big update! No pics yet though! I was able to start the car with the new motor yesterday!!!! I was quite surprised at how good the new engine sounded too. I was expecting more noise from the forged pistons, but it just sounded so smooth! Found one small oil leak at the oil cooler/filter area but that was it. Had to get a new battery because the old one was garbage. Hopefully I should be getting some miles on it in the next week or two. Dyno time coming soon! Link to comment Share on other sites More sharing options...
INVNO1 Posted June 23, 2015 Author Share Posted June 23, 2015 Worked on buttoning up the car today. Got a lot of it completed. While putting my coilovers back on my driver front half shaft just fell apart. LOL! Not sure what that was about but lucky for me one of the parts stores had one in stock. Still need to do some cleaning up of hoses and wires under the hood but the Crawford AOS is just so messy. http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_150010_zpsvqdsz3bz.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145955_zpsdr3z58u0.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145951_zps8fcavaqp.jpg Link to comment Share on other sites More sharing options...
INVNO1 Posted June 23, 2015 Author Share Posted June 23, 2015 After buttoning up the front suspension I wanted to put my new wheels on. I sold my 17x8 +45 gunmetal RPF1 wheels to a buddy so I could go with 17x9 +35 RPF1s. Had to keep with my 5mm spacers up front because of the Wilwood calipers but I think it still works and looks great. Except for the fact that the car hasn't had a bath since early Feb when we started the motor project. http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145848_zps7lk6iyrv.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145853_zpsk1cscvvv.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145858_zpsh2yuenrl.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145901_zps2vq4ltea.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145907_zpsutche2g4.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145911_zpsksp3msib.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145920_zpsyn2ug1bo.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20150622_145923_zps5wyybkot.jpg Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 23, 2015 Share Posted June 23, 2015 very nice. make sure you put zip ties on your blow-off and every vacuum connection. Ask me how i know. lol Link to comment Share on other sites More sharing options...
INVNO1 Posted June 23, 2015 Author Share Posted June 23, 2015 very nice. make sure you put zip ties on your blow-off and every vacuum connection. Ask me how i know. lol Note taken!! Link to comment Share on other sites More sharing options...
Benjamin M Posted June 27, 2015 Share Posted June 27, 2015 Awesome sauce! Really like your wagon and the project overall! If you're ever feeling generous, making some $$$, and have extra time on your hands, I'll ship you my OEM grille to mod like yours Link to comment Share on other sites More sharing options...
INVNO1 Posted June 29, 2015 Author Share Posted June 29, 2015 EVERYTHING is buttoned up! Just waiting on the trailer to take it to get tuned!! Link to comment Share on other sites More sharing options...
MTBwrench Posted June 29, 2015 Share Posted June 29, 2015 So much sleeperness, I love it. Kind of reminds me of a EJ25 USDM version of SuperGramps. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
INVNO1 Posted June 29, 2015 Author Share Posted June 29, 2015 So much sleeperness, I love it. Kind of reminds me of a EJ25 USDM version of SuperGramps. I love watching MCM! I have been watching those guys since that stupid civic they were doing work on like 3-4 years ago. Lol! I couldn't get enough when they started building the first Gramps project! It was kind of funny that their goal was to run 11s because when I started this build that was my goal! Haha!!! Makes it awesome that I have 6 fuel stations within a mile of my house that all have E85 too! Link to comment Share on other sites More sharing options...
INVNO1 Posted October 29, 2015 Author Share Posted October 29, 2015 It's been a while since an update. Had a major mishap with the built motor. Don't really want to get into what happened with it, but the only thing from the shortblock that was reusable were the rods. So, new block halves, pistons, crank, and bearings again and we got it reassembled. Finally got it back to my tuner and he has been working on the street tune this last week. Car was put on the dyno today and a couple boost leaks were found. Those are being addressed tomorrow morning and then tuning continues right afterwards. As of right now, with the boost leaks, and not a full power pull the car is currently at 340whp and 320-330wtq. Fuel is currently 93oct but will be switched to e85 in the spring. I will post some updated pics later tonight or tomorrow and also some dyno pics tomorrow as well. Link to comment Share on other sites More sharing options...
INVNO1 Posted October 29, 2015 Author Share Posted October 29, 2015 http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20151016_135955_zpsrck1olhf.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20151016_140008_zpsgzdevurj.jpg http://i97.photobucket.com/albums/l232/Rubenn27/OBXT/20151016_140128_zps2p3pabtu.jpg Link to comment Share on other sites More sharing options...
