Stevo F Posted September 3, 2013 Share Posted September 3, 2013 I am getting new NGK platinum plugs and am thinking of ordering NGK spark plug cables to go with them. Is this a good choice of spark plug cables? Also, if I decide to go with the MSD coil mod later on, will these wires fit the MSD coil as well as the stock coil? http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_ignition-wire-set-ngk_20500858-p Link to comment Share on other sites More sharing options...
Zues Marine Posted September 3, 2013 Share Posted September 3, 2013 Yes and yes Link to comment Share on other sites More sharing options...
Stevo F Posted September 7, 2013 Author Share Posted September 7, 2013 Got my plugs and wires today. I ended up paying only only $50 shipped for NGK wires & NGK platinums from Rock Auto. Got here in two days. I like how easy the plug change is on the EJ22 (Especially if you take the 2 bolts out of the washer reservoir and move it out of the way. The old plugs weren't too bad looking (NGK regular plugs) and generic aftermarket wires). Actually a couple of the plugs looked like it's running a tad lean. Link to comment Share on other sites More sharing options...
mnstrmech Posted September 7, 2013 Share Posted September 7, 2013 the ngk wires will prolly outlast the car lol.... i have a set on my car. been there for years.... Link to comment Share on other sites More sharing options...
johnegg Posted September 7, 2013 Share Posted September 7, 2013 I like how easy the plug change is on the EJ22 (Especially if you take the 2 bolts out of the washer reservoir and move it out of the way.the spark plug tubes on SOHC engines are angled upward, a bit, making them more accessible. on DOHC engines (ej25D, and H6) they cannot do that so they are absolutely horizontal, and much more difficult. Link to comment Share on other sites More sharing options...
Stevo F Posted September 7, 2013 Author Share Posted September 7, 2013 Yeah I liked the angled up spark plug tubes. I don't change my wires often, so i assue I'll keep these on the car the duration. Since a couple of plugs that I pulled out had very light colored deposits, i wonder if it's running a bit lean. i might recheck for a vacuum leak (being my idle is pretty well set at 650 RPM). Link to comment Share on other sites More sharing options...
