lee07 Posted September 2, 2013 Share Posted September 2, 2013 Believe i had a thermostat stuck closed and had to much pressure that it popped the upper hose off and broke a bit of the neck piece for the hose off Car overheated 3 times after, and stayed at normal temp a few other times I drove it. Must be sticking and opens up when it wants to. Now I need I new radiator, hoses and probably thermostat but not sure if I should go oem or aftermarket. vf52 on e85 and just a dd Link to comment Share on other sites More sharing options...
ibr_adam09 Posted September 2, 2013 Share Posted September 2, 2013 oe is fine. but for not much more, go aftermarket. Get a thermostat Link to comment Share on other sites More sharing options...
jp233 Posted September 3, 2013 Share Posted September 3, 2013 Which part broke, the spout on the radiator, or are you talking about the metal pipe on top of the motor? I'm assuming you mean the plastic radiator part, OEM is fine but there are other radiators out there (mishimoto, etc). Since you're in MN, I wouldn't worry about high temps too much I've always liked using Gates parts for belts and hoses, water pumps and thermostats Just make sure you install the thermostat with the jiggle pin facing upwards Link to comment Share on other sites More sharing options...
lee07 Posted September 3, 2013 Author Share Posted September 3, 2013 The piece that you put over with the hose and where you would put the clamp. Not sure which to get, $270 for an oem and $270 for a mishimoto one. Does the stock fans bolt straight up on the mishimoto one? Link to comment Share on other sites More sharing options...
K2e2vin Posted September 3, 2013 Share Posted September 3, 2013 If you can afford it, go for a metal one. Plastic radiators are more prone to leaking later on. Link to comment Share on other sites More sharing options...
subiestang Posted September 3, 2013 Share Posted September 3, 2013 I got a Gimmick Motorsports aluminum radiator for 195 shipped from Import Image. Link to comment Share on other sites More sharing options...
