devenh Posted August 27, 2013 Share Posted August 27, 2013 I'm trying to figure out what the tire load rating was for the original tires, 215/45R17's. The manual does not list the load rating for this size. If you can provide a link to the source of the info, that would be appreciated. Deven Link to comment Share on other sites More sharing options...
jp233 Posted August 27, 2013 Share Posted August 27, 2013 Z-rated tires do not carry a load index with them... the GT tires were 215/45ZR17 http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=35 But, if you look at the other optional tire sizes for the similar weight vehicle, you can get an idea on a number. For instance, the 2005 Legacy 2.5i carries a P205/55/16 89H (so 1,279 lbs) The 05-06 Outback had either a 95 or 97 load index (so 1521-1609 lbs) So somewhere in between 89 and 95 would be my guess, probably something like 91 should be great if you are trying to buy tires that are not Z-rated. Link to comment Share on other sites More sharing options...
stanjk3 Posted August 28, 2013 Share Posted August 28, 2013 After a quick look on Tirerack, most grand touring AS have a load rating of 87 or 91. Most UHPAS are 91 or XL. http://www.tirerack.com/tires/TireSearchResults.jsp?filtering=true&width=215/&ratio=45&diameter=17&autoMake=Subaru&autoYear=2005&autoModel=Legacy%20Wagon%202.5%20GT&autoModClar=Limited&sortCode=49500&tireIndex=0&wtpackage=false Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
