Vacuum leak
OK so this is driving me a little crazy and I can't find any posts of anyone having the same issue.
My tuner suggested that i might have a inlet leak so I made a boost leak tester.
I pressurized the inlet and sprayed soapy water. I'm finding that the pcv valve to inlet connection is leaking(white connector) Both pcv valve and inlet are new installed a month ago.
I cannot get this connection to stop leaking and I'm only pressurizing the system at 3 psi so far. Anyone ever had this issue?
