Kevin622 Posted August 25, 2013 Share Posted August 25, 2013 Well i have been smelling fuel from my car. I looked under to see if i was leaking because the smell was getting very strong. I have the car parked in my garage and i go in to my garage one morning and it wreaked of gas. I pulled the rear seat out today and took off the cover to where the top of the fuel tank/pump side are and noticed fuel was leaking out. I tightened everything down, cleaned it and im going to see if it stops leaking if not its probably going to need the new gasket.. has anyone else had this happen? http://i140.photobucket.com/albums/r6/ehhockeystar44/LegacyGT/IMG_1649_zps53e7286a.jpg http://i140.photobucket.com/albums/r6/ehhockeystar44/LegacyGT/IMG_1648_zps944265a1.jpg Link to comment Share on other sites More sharing options...
Kevin622 Posted August 28, 2013 Author Share Posted August 28, 2013 im guessing no one had this happen.. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 29, 2013 Share Posted August 29, 2013 im guessing no one had this happen.. I'm thinking your right. I don't recall this in the years I've been here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jp233 Posted August 29, 2013 Share Posted August 29, 2013 So are you sure it's the gasket/seal there for the pump mounting into the tank, because it could be one of the lines there. Either the quick-connectors, or the rubber hose. Since in a rusty environment, it could be one of several things. Link to comment Share on other sites More sharing options...
Kevin622 Posted August 29, 2013 Author Share Posted August 29, 2013 well i pulled the seat and cover to where the pump is and went to fill it up cleaned it off and i saw its leaking right where i put the red arrow. Any way to fix these? The piece feels loose and its leaking under the round part of it.. sorry this is the same picture as before! http://i140.photobucket.com/albums/r6/ehhockeystar44/LegacyGT/e60326b1-c06a-4e3e-93f2-2be5dfdfadd4_zps3453c3f8.jpg Link to comment Share on other sites More sharing options...
rum0rz Posted August 30, 2013 Share Posted August 30, 2013 My wagon also suffers from the fuel smell but I haven't really bothered looking for it. I'll report back if I have the same issue as you are with that piece. Link to comment Share on other sites More sharing options...
VermontGT Posted August 31, 2013 Share Posted August 31, 2013 Mine was leaking from the same spot where the plastic fitting comes out. I don't know if you'd be able to repair it or not; I replaced the whole unit. Mine only seemed to be really bad when I had more than 3/4 tank full, but it was running down the side of the tank. Not a safe situation to be in. Get it fixed asap. Link to comment Share on other sites More sharing options...
Kevin622 Posted August 31, 2013 Author Share Posted August 31, 2013 Mine was leaking from the same spot where the plastic fitting comes out. I don't know if you'd be able to repair it or not; I replaced the whole unit. Mine only seemed to be really bad when I had more than 3/4 tank full, but it was running down the side of the tank. Not a safe situation to be in. Get it fixed asap. yeah mines only when its full/ 3/4. Where did you get the whole unit? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 31, 2013 Share Posted August 31, 2013 Contact Mike at http://www.AZPinstalls.com and see what he can do for a upgrade on the fuel pump, while your there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Kevin622 Posted August 31, 2013 Author Share Posted August 31, 2013 Contact Mike at http://www.AZPinstalls.com and see what he can do for a upgrade on the fuel pump, while your there. Will do thanks! Link to comment Share on other sites More sharing options...
VermontGT Posted August 31, 2013 Share Posted August 31, 2013 yeah mines only when its full/ 3/4. Where did you get the whole unit? I bought mine from Bosch directly. Last time I checked they were not stocking the complete assembly anymore which is unfortunate. Link to comment Share on other sites More sharing options...
