sneeky Posted August 23, 2013 Share Posted August 23, 2013 Hello forum, Since I've replaced by turbo I've been extremely paranoid about every little sound or vibration. The turbo blew & was replaced. I have not replaced the oil cooler, lines, & oil pan yet which is why I'm concerned. I've noticed that upon start up the engine is giving me a hard shake every minute or so. Also it seems like the RPM's are a little low when idling. I've attached a video that I uploaded to YouTube. In the video I parked the car after driving for a few minutes and started it up. It seems like the RPM's are really low. [ame=http://m.youtube.com/watch?v=AaUr1KXRHig]2005 Legacy GT - YouTube[/ame] Link to comment Share on other sites More sharing options...
Max Capacity Posted August 23, 2013 Share Posted August 23, 2013 Has the ECU re-learned idle yet ? How much run time has the car had since the turbo install ? How bad was the old turbo, for shaft play up/down, in/out ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lingling1337 Posted August 23, 2013 Share Posted August 23, 2013 Revs don't seem too low to me? and while I have group n motor mounts I get a little shake too as the rpms surge at idle after startup. Both before and after replacing my turbo which had minimal shaft play. Link to comment Share on other sites More sharing options...
stuck686 Posted August 23, 2013 Share Posted August 23, 2013 oil good coolant good? MAF clean?? radiator cap good and seal isnt old? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2013 Share Posted August 24, 2013 I couldn't really hear anything from the engine. Can you turn up the volume ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
sneeky Posted August 25, 2013 Author Share Posted August 25, 2013 Yes, the ECU should have had enough time to relearn everything... I've put a 1000 miles on the car since the turbo install... As far as shaft play, I did not get to inspect the turbo since the dealer did the install, but I was told there was a little bit of metal fragment in the oil pan... I'm going to flush the oil today and inspect the oil again... I'll repost a video with better sound Link to comment Share on other sites More sharing options...
Rush600 Posted August 25, 2013 Share Posted August 25, 2013 Check the blue "T" under the top mount? Link to comment Share on other sites More sharing options...
BoostOrDie Posted August 26, 2013 Share Posted August 26, 2013 I had the repetitive shudder at idle. I had my fuel injectors cleaned and it mostly went away. Link to comment Share on other sites More sharing options...
sneeky Posted August 30, 2013 Author Share Posted August 30, 2013 Thank you for all that replied. I've searched other threads & my car is acting in the same manner, but no solution or problem was stated. Upon start up the car shudders. When I'm driving and come to a stop it'll shudder. When I'm driving it's fine. Any ideas? Hope this helps. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 30, 2013 Share Posted August 30, 2013 Thank you for all that replied. I've searched other threads & my car is acting in the same manner, but no solution or problem was stated. Upon start up the car shudders. When I'm driving and come to a stop it'll shudder. When I'm driving it's fine. Any ideas? Hope this helps. This idea sounds like a possibility. I had the repetitive shudder at idle. I had my fuel injectors cleaned and it mostly went away. May be try a can of seafoam in the gas tank. Have cleaned the MAF sensor lately ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
