legy outback Posted August 18, 2013 Share Posted August 18, 2013 Edit:well I can't spell halves apparently Welp, title kind of says it all, I've got all the bolts out of the block, I've done everything i can thing of besides simply dropping the lump, hammer, chisel, pry bar, you name it. how do i get it apart? Link to comment Share on other sites More sharing options...
monkeyposeur Posted August 18, 2013 Share Posted August 18, 2013 You probably have a bolt still attached. Double and triple check. There is a little bolt that is an inch or so above where the oil pan bolts on towards the front that is easy to miss. Did you remove the pistons yet? If not do so. Get a rubber mallet and smack it good. Or you can remove the piston wrist pin access holes (don't mess up the threads) and shove a couple long rods in there and turn the crank. The rods will split the block apart. Good thread from NASIOC: http://forums.nasioc.com/forums/showthread.php?t=1294884 Link to comment Share on other sites More sharing options...
legy outback Posted August 18, 2013 Author Share Posted August 18, 2013 alrighty, triple checked on the bolts and they are all gone. the problem that presents itself now is that we can not get the pistons out because either the crank is frozen in there or something of the like, and therefore we can't turn it to get the pistons out of the little access holes they provide Link to comment Share on other sites More sharing options...
johnegg Posted August 18, 2013 Share Posted August 18, 2013 splitting the block is not going to get the pistons out either. you will still need to line the wrist pins up with the access hole. and if the crank is seized why are you messing with it in the first place? it is way cheaper to buy an engine with a busted timing belt and swap your heads onto the block. Link to comment Share on other sites More sharing options...
