Help identify the flywheel (pic)
Hi all!
It's my first post here as the forum is very informative and so far I've found answers to my questions using search.
So - opened up the clutch on my newly bought Eur spec 2006 2.0R Legacy and expected to see a dual mass flywheel, the same as yours. But - from what I gather, this is a single mass? And the friction surface is HIGHER than the bolting surface around it.
Anybody know what is it?? (maybe it is from some older Legacy model as I've heard older combo's can also be used to get rid of the dual mass??)
Many thanks!
So, are you telling us it's a cheaper replacement for the DMFW in the 05-06 and the SMFW in the 07-09 ?
Do you have the correct TOB p/n ?
I guess if you think about the bigger picture, these FW's can't be all that much different.
Engine Build - Click Here
