Screamin Posted July 12, 2013 Share Posted July 12, 2013 What is the allen wrench size for the stock shocks/struts? I'll be swapping out for some KYB's this weekend and noticed stock shocks/struts and the KYB's need one to remove/install the nut. I only have a standard size allen wrench set, it's between a 3/16 and a 1/4 which is I believe a 7/32 or whatever metric size falls into that....5 or 6 milimeters I'm guessing? Did a search and came up empty handed. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 12, 2013 Share Posted July 12, 2013 I believe it is definitely metric. Can't remember the size though. But yeah, probably either 5 or 6mm. I can check tonight as I still have my old set of struts. Link to comment Share on other sites More sharing options...
GTTuner Posted July 12, 2013 Share Posted July 12, 2013 6mm is slightly larger than 3/8" Link to comment Share on other sites More sharing options...
Screamin Posted July 12, 2013 Author Share Posted July 12, 2013 I believe it is definitely metric. Can't remember the size though. But yeah, probably either 5 or 6mm. I can check tonight as I still have my old set of struts. Thanks, I appreciate that. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 13, 2013 Share Posted July 13, 2013 Just checked. It was 6mm for my rear struts on an OBXT. Even though the struts are different in length compared to the LGT, the size of the allen key used should be the same. Link to comment Share on other sites More sharing options...
Screamin Posted July 13, 2013 Author Share Posted July 13, 2013 Thanks for checking. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 13, 2013 Share Posted July 13, 2013 No worries man. Link to comment Share on other sites More sharing options...
