lisaquinn530 Posted June 28, 2013 Share Posted June 28, 2013 My 93 Subaru legacy makes a loud whining noise when I let off of the gas pedal. Does anyone have a clue to why? Lisa Link to comment Share on other sites More sharing options...
Stang70Fastback Posted July 3, 2013 Share Posted July 3, 2013 Are you sure it's not just typical drive-train whine from an older vehicle? You're much more likely to hear it while coasting. EDIT: Also, you've provided about as little information as possible for us to help you in your diagnoses. There are 100 different things that can whine in a car. You need to at least attempt to describe more precisely what it sounds like, where in the car it appears to be coming from, and any other details that could help us narrow down the field... Link to comment Share on other sites More sharing options...
lisaquinn530 Posted July 4, 2013 Author Share Posted July 4, 2013 I believe it is coming from the transmission or differentials. It is definitely coming from the drive train. It is definitely not a heat shield rattling and it is not coming from the motor. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted July 5, 2013 Share Posted July 5, 2013 Yeah, I'm willing to bet it's just typical older-car drive-train noise. Especially if it's a high-pitched wine. You can always check your trans and diff fluids just to be safe though. Link to comment Share on other sites More sharing options...
