bolts
    14
Everything posted by bolts
  1. https://www.ebay.ca/itm/182990551646?ul_noapp=true Subaru Legacy BP5 Outback 2.0L DOHC Turbo Manual ECU 8A 22611AH111 JDM EJ20Y ECU I got confirmation from the seller that it would work for my EJ20x Would I still need a tune for the different turbo? I'm using a VF38
  2. 22611AH111 22611AK221 Any idea what the difference is between the 2? 1st is EJ20Y and the latter is EJ20X
  3. https://www.ebay.com/itm/Subaru-Legacy-BP5-Outback-2-0L-DOHC-Turbo-Manual-ECU-8A-22611AH111-JDM-EJ20Y-ECU/182990551646?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3D489a4966ef224187ba17cff4c6f84cd8%26pid%3D100290%26rk%3D1%26rkt%3D4%26sd%3D182990551646%26itm%3D182990551646&_trksid=p2060778.c100290.m3507 This one ?
  4. Super... thanks It was stated in the discussion above that the engines are not that picky as far as ECUs go... does it alll come down to that model alone or might there be other options?... You are the 2nd person to confirm that particular ECU model... unless that's you yagga.... then you would be one and the same ;o) Thanks again it's much appreciated..
  5. Can anyone confirm if this ECU might work or not in a 2005 M/T outback XT with a swapped ej20x? https://www.ebay.com/itm/JDM-SUBARU-LEGACY-BH9-EJ254-EJ25-AVCS-DOHC-M-T-2-5L-ECU-ECM-22611-AF371/282340746959?hash=item41bcd1e6cf:g:NT4AAOSw-0xYi6G-&vxp=mtr
  6. Well thats great... do you know of any vendors that would have one that would solve this? Any versions/models in particular that I should be on the lookout for? It's kind of a broad spectrum and I'm having a hard time tracking one down Any help would be greatly appreciated bolts
  7. Accessories and cluster might be different.. even within outbacks the year of the ecu has to match exactly ...unless I am mistaken? Would a 2006 outback xt ecu work with a 2005 for example? If it does that would be great news
  8. Is there a JDM version ecu for an outback XT 2005?
  9. How involved is that if the engine is already on the car? Considering all options at this point Also what downpipe are you using? bolts
  10. I just received a vag cable last week and looking into getting a used laptop now. I know my ecu is locked so I also ordered one on ebay and got that as well So yeah no idea how much boost as of yet... i've got a tune on it at the moment thats locked and no clue what can be done with that Are the wires piggy backed to wires on the ecu harness?...or to empty pins? Can you see how high you're boosting with your EJ20X?
  11. Hello I've been following this thread for awhile now and I've recently come into possession of a jdm swapped outback XT with a VF38 turbo Running without the avcs and looking into getting that done Has anyone figured out how to wire that up? (anyone willing to share that is) Thanks in advance ... will figure it out eventually and post feedback when or if I do but any help would be appreciated
