Edo fall seasons specials!!!!!!!!!
EDO Performance
http://www.edoperformance.com/ForumImages/forumbanner.jpg
Fall is upon us and winter is just beyond the horizon! The rain is coming! Make sure your ride is in tip top condition and ready for battle with an EDO multipoint vehicle inspection, free with every service!
Oil Changes
- Mobil 1 5W-30 Synthetic Motor Oil with Zero/Sports Oil Filter WAS $68 NOW $60
- Motul 5W-30 Synthetic Motor Oil with Zero/Sports Oil Filter WAS $75 NOW $70
- Motul 300V 5W-30 Synthetic Oil with Zero/Sports Oil Filter WAS $99 NOW $90
Transmission and Differential Fluid Changes
- Transmission: Motul 75W-90 Synthetic Gear Oil WAS $110 NOW $100
- Differentials: Motul 75W-90 Synthetic Gear Oil WAS $70 NOW $65
- COMBO Trans and Diff: Motul 75W-90 Synthetic Gear Oil WAS $175 NOW $150
Brake Services
- *Motul Brake Fluid is used on EVERY Brake Service!
- **Add an additional $7 for Motul RBF600 Fluid!
- Zero/Sports Stainless Steel Brake Lines (Front and Rear) $240 INSTALLED!
- Zero/Sports Front "Street" Brake Pads $175 INSTALLED
- Zero/Sports Front "Sport" Brake Pads $225 INSTALLED
- Zero/Sports Front "Circuit" Brake Pads $255 INSTALLED
- Zero/Sports Rear "Street" Brake Pads $165 INSTALLED
- Zero/Sports Rear "Sport" Brake Pads $215 INSTALLED
- Zero/Sports Rear "Circuit" Brake Pads $245 INSTALLED
- COMBO Front and Rear Pad Packages available! Please PM for pricing!
Clutch and Flywheel Installations
Clutch/Flywheel Install $500*
* Motul Gear Oil will be used to refill your transmission. ;)
Factory Mileage Maintenance Services
30,000 Mileage Service
- Inspection of drive belts and camshaft belts
- Inspection of fuel system, lines, and connections
- Inspection of air filter (replaced with Zero/Sports N1 Filter if necessary)
- Inspection of brake pads, linings, and lines
- Inspection of ATF/Power Steering Fluid
- Inspection of front and rear axle boots and axle shaft joints
- Inspection of clutch, steering, and suspension systems
- Inspection of tires (and rotation if permitted)
- Engine oil replacement with Motul 5W-30 Synthetic Motor Oil
- Engine oil filter replacement with Zero/Sports Oil Filter
- Engine coolant replacement and system/hose inspection for cracks/leaks
- Transmission and Differential fluids replaced with Motul 75W-90 Synthetic Gear Oil
- Brake fluid replaced with Motul Brake Fluid**
- WAS *$480! NOW $470
60,000 Mileage Service
- 30,000 Mileage Service is performed
- Fuel Filter replaced
- Spark Plugs replaced
- WAS *$560! NOW $550
90,000 Mileage Service
*Additional fees may be added for automatic transmission vehicles and for replacement of air filter. Customer will be notified of charges in advanced.
**$7 additional fee if Motul RBF600 Brake Fluid is requested
http://www.edoperformance.com/ForumImages/subservice.gif
Stay tuned as I will keep this thread constantly updated with up-to-the-minute sales and installation specials!
We also stock a lot of Motul Fluid
Motul
8100 5W30 Oil - Call/PM for Price!
8100 5W40 Oil - Call/PM for Price!
300V 5W30 Oil - Call/PM for Price!
300V 5W40 Oil - Call/PM for Price!
75W90 Gear Oil - Call/PM for Price!
90PA LSD Oil - Call/PM for Price!
Dextron III ATF - Call/PM for Price!
Inugel Expert Coolant - Call/PM for Price!
MoCool Radiator Additive - Call/PM for Price!
RBF600 Brake Fluid - Call/PM for Price!
  • 2 weeks later...
  • 1 month later...
Do you guys sell slotted brake rotors for our Legacy's? Or how much extra would you change to install if I provided my own?
I want the stainless lines, street front pads and possibly go stage 2 with the rotors. Probably makes sense to go ahead and bleed-out all the fluid and replace with fresh too. I'll pay for the fluid.
  • 3 months later...
just had my 30k service done at EDO. good service. heres my review:
i walked in and was immediately greeted by the receptionist. very friendly. she called Edwin, the manager, and he showed up within a couple minutes of my arrival.
i spoke to him briefly over the phone and when i got there he gave me explained to me everything that they would be performing on my car. then he recommended a few other things but i didnt feel pressured at all.
after that he gave me a tour of the whole facility and introduced me to all of his employees. he also showed me all of the cars they were currently working on, including his R33 skyline.
after the tour we went back into the office, filled out some paperwork, then i gave him my keys and they started on my car right away. here's the service i had performed:
  • 30k maintenance and inspections (listed in first post of this thread)
  • Zero Sports drop in filter
  • Zero Sports intake pipe
  • reflash
all of this service was done in a timely manner. i was in and out in just under 3 hours. they had no problems with me observing the work if i wanted to. they also have complimentary WiFi.
after the service, i test drove the car. everything was good, finalized the paperwork, then i was on my way. before i left, edwin gave me some literature on some of the other work they offer in case i decide to make any other modifications to my car. he also gave me a small gift for choosing them.
that night, i was driving my car and while accelerating, i felt a small jolt and the check engine light came on. so the next day i went back. edwin was on the phone but after he got off the phone he came out to my car and checked for errors. apparently he upped the boost too much since my car is mostly stock. so he reflashed again. and now 3 days later everything is running smooth.
i had a good experience overall. i would recommend them to friends and plan and returning for more service.
