Limeydriver Posted March 13, 2005 Share Posted March 13, 2005 Ok Kids:) , I decided to try the install of the JDM rear swaybar today. IT FITS. The JDM bar and stock bar are exactly the same shape and length. Subaru lengthened the mounting bracket to enable them to use the same swaybar. Install was pretty straight forward. You have to unbolt the rear mufflers to get the bars out and in. I went out for a good run after the install including my local interstate on and off ramp. The difference is noticable. The stock Outback has a floaty rear end. The car when pushed hard fells a little unstable, not anymore. The front and rear are now in perfect harmony. The cornering is much more poised. The ride is not noticably harsher. This is a great mod for the Outback. It probably makes more difference than the GT due to our smaller stock rear bar. Link to comment Share on other sites More sharing options...
firedawgs Posted March 13, 2005 Share Posted March 13, 2005 I just installed my rear swaybar last weekend. Did not have to take the rear muffler off. I did have to take off one of the wheels though. I think it is one of the best upgrade possible. Cant go fast unless you can go fast around corners. Updated my vBGarage: Link to comment Share on other sites More sharing options...
sduford Posted March 13, 2005 Share Posted March 13, 2005 Thanks for the update, that is great news! So did you use the stock end-links? Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
Limeydriver Posted March 13, 2005 Author Share Posted March 13, 2005 Yes. Stock endlinks. Link to comment Share on other sites More sharing options...
03Indigo Posted March 13, 2005 Share Posted March 13, 2005 OK, guess that means I am ok to start ordering suspension stuff for the car. Thanks for the update. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 13, 2005 Share Posted March 13, 2005 Nice! Did you reuse the bushings? I wouldn't think the stockers would fit the JDM bar. Link to comment Share on other sites More sharing options...
Limeydriver Posted March 13, 2005 Author Share Posted March 13, 2005 Jedi, the swaybar from AVO had new bushings included. Link to comment Share on other sites More sharing options...
apexjapan Posted March 13, 2005 Share Posted March 13, 2005 Great news! It's good to know that it fits, a viable upgrade path for Outback owners, plus it won't stick out too much at the dealership when in for maintenance and such. We always include bushings in the stabilizer bar orders, because they are necessary for fitment. Cheers, Paul Hansen http://www.avoturboworld.com Link to comment Share on other sites More sharing options...
gt_ltd Posted March 13, 2005 Share Posted March 13, 2005 will this void my warranty? This Space For Rent Link to comment Share on other sites More sharing options...
mwiener2 Posted March 13, 2005 Share Posted March 13, 2005 sneezing will void your warranty My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Boostjunkie Posted March 13, 2005 Share Posted March 13, 2005 Also means that the USDM LGT rear sway bar will fit. While not as stiff as the JDM bar, it will increase roll stiffness in the rear, and balance out the handling. I'm not sure why the OB has a 14mm rear bar, while the LGT has a 17mm bar, but for a cheap upgrade, it's something to consider. I say cheap, because as more and more LGT owners upgrade to the JDM and aftermarket bars, some will sell their OEM bars. Link to comment Share on other sites More sharing options...
SBT Posted March 13, 2005 Share Posted March 13, 2005 I'm really glad to hear that it fits because if we do get an OBXT for my wife, this will be one thing that I'll want to do to it. OB has just too much roll for me and she notices it much more than your typical non-motor head spouse would notice something like this... which is good. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
dustdr Posted March 13, 2005 Share Posted March 13, 2005 How much was it? Link to comment Share on other sites More sharing options...
Limeydriver Posted March 13, 2005 Author Share Posted March 13, 2005 $190 including shipping from www.avoturboworld.com. Took 10 days from order to get to me from Japan - impressive. Link to comment Share on other sites More sharing options...
drewster Posted March 13, 2005 Share Posted March 13, 2005 just sort of thinking out loud...if you go with a thicker rear bar, will it compromise the "independent-ness" of the rear wheel travel? Say you're on a unpaved road and only one rear tire drops into a deep rut, will a thicker bar compromise off-road handling and traction? Link to comment Share on other sites More sharing options...
SBT Posted March 13, 2005 Share Posted March 13, 2005 Excellent point! That is probably THE single reason for the smaller sway bar on the OBXT. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
gtguy Posted March 13, 2005 Share Posted March 13, 2005 just sort of thinking out loud...if you go with a thicker rear bar, will it compromise the "independent-ness" of the rear wheel travel? Say you're on a unpaved road and only one rear tire drops into a deep rut, will a thicker bar compromise off-road handling and traction? Of necessity, yes, but not to a significant degree. The JDM bar is still within numbers that are reasonable. When people start strapping on 25mm bars, etc, then it becomes problematic. As regards the warranty question, technically yes, a swaybar will void the warranty of affected parts. So if you break a swaybar mount with a larger swaybar, the repair would be on your own dime. Conversely, if your "check engine" light came on, the swaybar would have nothing to do with it. Note also that you would have to patronize a pretty cranky dealer to have anything be affected by a swaybar. I went to my dealer (with my WRX) with DMS coilovers, stainless lines/Subaru 4-pots, different swaybar, wheels and tires and other stuff going on, and nobody said a word. Kevin Link to comment Share on other sites More sharing options...
firedawgs Posted March 13, 2005 Share Posted March 13, 2005 Jedi, the swaybar from AVO had new bushings included. poly bushings too. Updated my vBGarage: Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 13, 2005 Share Posted March 13, 2005 Before I order, let me be clear- this is the JDM Legacy bar right? I remember the JDM OB bar being not much bigger than the US one. Link to comment Share on other sites More sharing options...
Limeydriver Posted March 13, 2005 Author Share Posted March 13, 2005 Yes Jedi you need the Legacy GT JDM bar 20mm. So if you are ordering from AVO it is under Legacy BL/BP in the international section. The part no is BLBP-RSTABI Of necessity, yes, but not to a significant degree. The JDM bar is still within numbers that are reasonable. When people start strapping on 25mm bars, etc, then it becomes problematic. I agree 20mm is about as far as I would go on an Outback. Anymore and you are going to get a lot of rear bias in the handling which with the increased ground clearance would not be fun. There is a reason that stock rear bars tend to be smaller than stock front bars - more foregiving handling. Link to comment Share on other sites More sharing options...
rc0032 Posted March 13, 2005 Share Posted March 13, 2005 Im glad you are happy Limey Good driving!! Link to comment Share on other sites More sharing options...
Limeydriver Posted March 13, 2005 Author Share Posted March 13, 2005 Thanks for your help on this one Mr Clark. Link to comment Share on other sites More sharing options...
firedawgs Posted March 13, 2005 Share Posted March 13, 2005 17mm to the JDM 20mm bar = 35% stiffer. Updated my vBGarage: Link to comment Share on other sites More sharing options...
Limeydriver Posted March 13, 2005 Author Share Posted March 13, 2005 It's even better than that the stock Outback XT rear sway is 15mm. Link to comment Share on other sites More sharing options...
dustdr Posted March 15, 2005 Share Posted March 15, 2005 Thanks for all the info. Will all the AZ twisty's to drive, this looks like the way to go! Link to comment Share on other sites More sharing options...
