rs_two_five Posted March 30, 2008 Share Posted March 30, 2008 ok, so I tried searching, maybe my keywords were off, but I tried, so maybe someone out there might be able to help out. Anyways, can you fit the 06-07 WRX 4/2 piston brakes under the 06-07 OEM Spec B wheels? or do you require spacers to make them fit? Link to comment Share on other sites More sharing options...
jomamma Posted March 30, 2008 Share Posted March 30, 2008 ok, so I tried searching, maybe my keywords were off, but I tried, so maybe someone out there might be able to help out. Anyways, can you fit the 06-07 WRX 4/2 piston brakes under the 06-07 OEM Spec B wheels? or do you require spacers to make them fit? it's a waste of time and $. it's been tried and the results suck. the lgt brakes out perform hands down. the oem 4pots are considered a down grade. they have smaller rotors. save your $ Link to comment Share on other sites More sharing options...
jomamma Posted March 30, 2008 Share Posted March 30, 2008 and try wrx 4pot for your search Link to comment Share on other sites More sharing options...
rs_two_five Posted March 30, 2008 Author Share Posted March 30, 2008 the reason why I ask is I've got a 07 WRX that came factory with the subaru 4/2 piston brakes.. and I'm looking to install some Spec B wheels on it. So, I'm making sure that the wheels would fit. Yes, I know this is on a Legacy specific forum, hense why i was asking if anyone has installed those brakes on their legacy and were able to still use the stock wheels. Link to comment Share on other sites More sharing options...
biz77 Posted March 30, 2008 Share Posted March 30, 2008 the reason why I ask is I've got a 07 WRX that came factory with the subaru 4/2 piston brakes.. and I'm looking to install some Spec B wheels on it. So, I'm making sure that the wheels would fit. Yes, I know this is on a Legacy specific forum, hense why i was asking if anyone has installed those brakes on their legacy and were able to still use the stock wheels. In that case, yes you should have no problem fitting the Spec. B wheels over the OEM 06/07 WRX system. As stated they are smaller than the LGT/Spec. B brakes. Link to comment Share on other sites More sharing options...
