TwinkE Posted November 12, 2006 Share Posted November 12, 2006 I've started on my Lidatek install, but this will work for anything that requires a switch. I went to Radio Shack and got a push on-push off switch(275-011A). First, remove the shifter trim and unhook the lighter connector. http://www.twinke.com/Pictures/pushbutton/pushbutton001.jpg Use a 6mm socket to remove the nut from the bottom of the lighter socket. You're left with the white piece and a threaded piece from the inside and a nut and the wires. The lighter socket has a nice hole to run some wires through. http://www.twinke.com/Pictures/pushbutton/pushbutton002.jpg Now to make the switch, cut the head off of the lighter plug. I took off about 3/8". I used one file to open up the hole inside the plug a little bit and used the other to smooth the hole out, it worked pretty well. The switch just screws itself in to the opening. Before - the plug and switch http://www.twinke.com/Pictures/pushbutton/pushbutton003.jpg After - plug assembled http://www.twinke.com/Pictures/pushbutton/pushbutton004.jpg Hope this can help someone. Link to comment Share on other sites More sharing options...
mlrtime Posted November 12, 2006 Share Posted November 12, 2006 ugh... wtf? First. Link to comment Share on other sites More sharing options...
VTsullyman Posted November 12, 2006 Share Posted November 12, 2006 Hawt 2007 DGM LGT 2003 Suzuki SV650S Link to comment Share on other sites More sharing options...
meier motor sports Posted November 12, 2006 Share Posted November 12, 2006 cool button! Link to comment Share on other sites More sharing options...
TwinkE Posted November 12, 2006 Author Share Posted November 12, 2006 Hawt Go Hokies! Link to comment Share on other sites More sharing options...
Brady Posted November 12, 2006 Share Posted November 12, 2006 That's a really cool idea for a nice hidden switch in the car. Nice Work! Link to comment Share on other sites More sharing options...
bstieritz_GT Posted November 12, 2006 Share Posted November 12, 2006 haha....you could have fun with that button and unsuspecting passengers in the car.... NO, DON"T TOUCH THAT BUTTON!!!! Link to comment Share on other sites More sharing options...
TwinkE Posted November 12, 2006 Author Share Posted November 12, 2006 Here's what it looks like installed: http://www.twinke.com/Pictures/pushbutton/pushbutton005.jpg I wanted to use this rocker switch(Radio Shack part: 275-693) but it's the wrong size for the lighter switch. Maybe somewhere else. http://www.twinke.com/Pictures/pushbutton/rockerswitch.jpg Link to comment Share on other sites More sharing options...
Brady Posted November 12, 2006 Share Posted November 12, 2006 wow ... that really looks great! nice stealth install! Link to comment Share on other sites More sharing options...
TwinkE Posted November 12, 2006 Author Share Posted November 12, 2006 Thanks. Any ideas on where to put the rocker button? I'm going to put the led for my lidatek in the blank between the traction control and the fog light buttons. Link to comment Share on other sites More sharing options...
Guest Posted November 13, 2006 Share Posted November 13, 2006 wow ... that really looks great! nice stealth install! I think the V1 remote display could not have been placed worse. It's obviously distracting - forces driver to move his eyes far. I mounted mine on the hump just in front of the gauge cluster. I'll take pic if someone's interested. As for extra buttons, I am gonna reuse the factory VDC and folding button switches (importing JDM switch). I'll hook up the rear fog to one of them when I finally get to installing it. I also want kill switch for V1 and my Blinder - I think I'll put one (push down/up type) under the shifter boot. Will be invisible and easily accessible. A friend had ignition kill switch mounted under the boot - very stealthy! Link to comment Share on other sites More sharing options...
Brady Posted November 13, 2006 Share Posted November 13, 2006 oh, unclemat, i was going to use the the same stealth button placement for my 7,000,000 candlepower foglights with playstation monitors on the floorboard of the driver's footwell. Seriously dude, can you ever just relax??? Link to comment Share on other sites More sharing options...
Guest Posted November 13, 2006 Share Posted November 13, 2006 oh, unclemat, i was going to use the the same stealth button placement for my 7,000,000 candlepower foglights with playstation monitors on the floorboard of the driver's footwell. Seriously dude, can you ever just relax??? What's your problem here? Link to comment Share on other sites More sharing options...
meier motor sports Posted November 13, 2006 Share Posted November 13, 2006 one of you 2 =http://i62.photobucket.com/albums/h99/shawnghart123/SandyVag.gif Link to comment Share on other sites More sharing options...
rtto5588 Posted November 13, 2006 Share Posted November 13, 2006 I think I'm totally missing this? Why would you put this switch/button in? What purpose does it serve? Just curious. Link to comment Share on other sites More sharing options...
whitetiger Posted November 13, 2006 Share Posted November 13, 2006 So you can have a l337 st4rt butt0n Link to comment Share on other sites More sharing options...
TwinkE Posted November 13, 2006 Author Share Posted November 13, 2006 This is just for a concealed general purpose on/off button. I'm using this particular one for my laser detector. Link to comment Share on other sites More sharing options...
sgt Posted November 14, 2006 Share Posted November 14, 2006 I wanted to use this rocker switch(Radio Shack part: 275-693) but it's the wrong size for the lighter switch. Maybe somewhere else. http://www.twinke.com/Pictures/pushbutton/rockerswitch.jpg I mounted this one in the cupholder. Perfect fit and you cant really see it. Link to comment Share on other sites More sharing options...
automaticsti Posted November 14, 2006 Share Posted November 14, 2006 damn thats a quality intall......very nice work Link to comment Share on other sites More sharing options...
VTsullyman Posted November 14, 2006 Share Posted November 14, 2006 Go Hokies! Heck ya. 2007 DGM LGT 2003 Suzuki SV650S Link to comment Share on other sites More sharing options...
Andyjo Posted November 16, 2006 Share Posted November 16, 2006 nice placement! i may have to do that when i fab up a bracket to put my lightforces on the ol obxt... 6.5" dia spot lights... ohhhh yeah.... Link to comment Share on other sites More sharing options...
MikeyXX Posted November 16, 2006 Share Posted November 16, 2006 Nice look. too bad it chews up a power outlet. Link to comment Share on other sites More sharing options...
