Alpinestars96 Posted August 15, 2006 Share Posted August 15, 2006 Do the 05's need a front one? Or do they just drill in the front? Link to comment Share on other sites More sharing options...
mbacis Posted August 15, 2006 Share Posted August 15, 2006 Not sure. Mine didn't come with anything, but I can see dimples where holes would go. Odd really, considering I need one by law here in CA. I got one warning already, but I still just have both plates stacked in the rear. Link to comment Share on other sites More sharing options...
leftride Posted August 15, 2006 Share Posted August 15, 2006 my '06 obxt was just drilled. *vb gallery* Link to comment Share on other sites More sharing options...
GTTuner Posted August 15, 2006 Share Posted August 15, 2006 No bracket. Holes in da bumper, yup. Link to comment Share on other sites More sharing options...
Opie Posted August 16, 2006 Share Posted August 16, 2006 They actually do make a bracket that is a little better looking than just drilling into the cover...it's shown in the 2006 accessories brochure. Link to comment Share on other sites More sharing options...
some6uy008 Posted August 16, 2006 Share Posted August 16, 2006 Mine's drilled in Link to comment Share on other sites More sharing options...
CreoSTi Posted August 16, 2006 Share Posted August 16, 2006 They actually do make a bracket that is a little better looking than just drilling into the cover... You still need to drill into the bumper, though, as that is how you mount the bracket to the bumper. The bracket itself just moves the plate about .5" off of the bumper, and moves it slightly higher. -Mike- Link to comment Share on other sites More sharing options...
pillboy Posted August 16, 2006 Share Posted August 16, 2006 Attching the plate right to the bumper looks cheap to me. It is cheap too, saved Subaru $0.50. It is still ugly. Link to comment Share on other sites More sharing options...
Faudi Posted August 16, 2006 Share Posted August 16, 2006 Subaru does not put a front plate bracket on because not all states require a front plate. They put two tiny dimples(pilot Holes) for the front plate for those that need to use it. Just Drill right into the little indentations. Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted August 16, 2006 Share Posted August 16, 2006 Then most dealers go ahead and drill them for you, or have already drilled them, and tacked a plastic ad plate directly to the bumper cover. If subaru meant to leave off the plate holder for all states, and have it done by dealers, they should build it in to send those dealers plate holders to install, or tell the dealers to leave their hands off the drill, and leave it to the customer to request it, or do it themselves. Either put a plate holder on, or don't drill. drilling and screwing a plate to the bumper is a half-assed choice, and the plates will likely scratch the hell out of Subaru's soft paint. Link to comment Share on other sites More sharing options...
BrownBoy Posted August 16, 2006 Share Posted August 16, 2006 Either put a plate holder on, or don't drill. drilling and screwing a plate to the bumper is a half-assed choice, and the plates will likely scratch the hell out of Subaru's soft paint. Yup. My front plate came off b/c it was scratching up my clearcoat really bad. The dealer put my license plate on for me...and they put it on TIGHT. Link to comment Share on other sites More sharing options...
pillboy Posted August 17, 2006 Share Posted August 17, 2006 My solution: It is still ugly. Link to comment Share on other sites More sharing options...
d3v3u5 Posted August 17, 2006 Share Posted August 17, 2006 ^^ interesting... Link to comment Share on other sites More sharing options...
hateitorloveit Posted August 17, 2006 Share Posted August 17, 2006 My solution: hi I saw "you're solution" for the legacy front plate problem. I already ordered and received the bracket, but where did you get that clear cover and screws? Also, how much did you have to dremel the holes because they are not lining up with the ones the dealer drilled. Link to comment Share on other sites More sharing options...
TSiWRX Posted August 17, 2006 Share Posted August 17, 2006 Do the 05's need a front one? Or do they just drill in the front? ^ My was just drilled, fellow Clevelander. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
d3v3u5 Posted August 17, 2006 Share Posted August 17, 2006 pillboy - Where did you get this solution...? -mark Link to comment Share on other sites More sharing options...
pillboy Posted August 18, 2006 Share Posted August 18, 2006 It's a new bracket for a '92-'94 Camry. I have a '94 and the fit is almost perfect...just a little Dremel work. If the bracket comes off the bumper there are now 4 holes in the bumper...the attachment screws for the bracket do not line up with the license plate holes the dealer put in the bumper. Clear plate cover and lower nylon bolts are from just about any auto parts store. The upper bolts holding the plate to the bracket are stainless steel. Toyota Parts Cheap.com It is still ugly. Link to comment Share on other sites More sharing options...
TRS Posted August 18, 2006 Share Posted August 18, 2006 You can try this. It's cheap, no additional holes in the bumper and opens up the lower intake to the radiator a bit. http://i23.photobucket.com/albums/b380/TRS60586/Riverside%20Townes%20Legacy/DSCN04402.jpg Link to comment Share on other sites More sharing options...
