kelviny Posted August 24, 2004 Share Posted August 24, 2004 Hi everyone, I just get my new 05 Legacy GT only 2 days, but I have a problem on air condition, I turn on air condition with auto temperature control enable, I found the air compresser turn off and on itself, sometime, it turn it off suddenly, and so obvious that you feel the warm air come out, and then it turn on again with cool air, and very fast it suddenly come out the warm air again. The problem also happen even though I turn on air condition without auto temperature control, I feel sudden it have cool, and then sudden come out the warm air, then for little while it come out the cool air again, and this status keep going on when the car is moving and when it is in parking mode. I really upset, and don't know what's going on, this is my first subaru, does anyone have any idea, please give me some advise or idea, thank You very much. Link to comment Share on other sites More sharing options...
Xaqtly Posted August 24, 2004 Share Posted August 24, 2004 Something like that happened to me when I first got my Legacy. I took it back to the dealer and they hooked it up to the A/C machine, and after that it worked fine, like the system just needed to be primed. So if I were you I would make an appointment with your dealer's service department as soon as possible to get that looked at. FYI, I haven't heard of this happening to anybody else, so it's apparently an extremely rare occurance. Link to comment Share on other sites More sharing options...
SUBE_MN Posted August 24, 2004 Share Posted August 24, 2004 I am not sure how rare this is. I am having a problem with my AC, too, and I recall someone else posting with an issue. My car has been at the dealer getting the bumpers repainted, and they are checking out the AC at the same time. Unfortunately, the weather has been cool, so they have not recreated the issue. They are in agreement with me that I should not pick up my car until they have recreated the issue and attempted to solve it. They have been nice enough to give me a new Forester as a free loaner. The only bad this is, I am starting to miss my car... My AC issue sounds a little different in that it is very consistent. When initially turned on the system blows cold air, but after 5-10 minutes the cold air stops, and only warm/hot air is blown. The cold air will not restart until the inside of the car is cooled down using other means (e.g. open windows, park in garage, etc.). This does not happen when the ambient temperature is not too high or if the car has been parked in the garage overnight. Others on this board have suggested that the refrigerant level may be too high, and the system has a pressure sensor that causes it to turn the compressor off when the pressure gets too high because it is working too hard. If this is the case, it should be an easy fix. Link to comment Share on other sites More sharing options...
SoCalGT Posted August 24, 2004 Share Posted August 24, 2004 I am not sure how rare this is. I am having a problem with my AC, too, and I recall someone else posting with an issue. My car has been at the dealer getting the bumpers repainted, and they are checking out the AC at the same time. Unfortunately, the weather has been cool, so they have not recreated the issue. They are in agreement with me that I should not pick up my car until they have recreated the issue and attempted to solve it. They have been nice enough to give me a new Forester as a free loaner. The only bad this is, I am starting to miss my car... My AC issue sounds a little different in that it is very consistent. When initially turned on the system blows cold air, but after 5-10 minutes the cold air stops, and only warm/hot air is blown. The cold air will not restart until the inside of the car is cooled down using other means (e.g. open windows, park in garage, etc.). This does not happen when the ambient temperature is not too high or if the car has been parked in the garage overnight. Others on this board have suggested that the refrigerant level may be too high, and the system has a pressure sensor that causes it to turn the compressor off when the pressure gets too high because it is working too hard. If this is the case, it should be an easy fix.Almost sounds like your A/C compressor is overheating and shutting itself down. Link to comment Share on other sites More sharing options...
Nick Posted August 24, 2004 Share Posted August 24, 2004 My car does the same thing, cycling the compressor on and off, but I attribute it to the thermostat regulating the interior temp. -Nick Link to comment Share on other sites More sharing options...
eamiller Posted August 24, 2004 Share Posted August 24, 2004 I believe we discussed this in a previous thread. The compressor cycles to prevent icing of the condensor coil. As the ambient temperature changes, the cycling rate changes as well. Link to comment Share on other sites More sharing options...
SUBE_MN Posted August 24, 2004 Share Posted August 24, 2004 Right. From what I am understanding, kelviny's situation is normal, provided the car interior is being maintained at a comfortable temperature. Mine is different. Once the cold air stops, it never comes back whether I use auto or manual controls. The inside temp could go to 95, but the cold air will never start again. Link to comment Share on other sites More sharing options...
eamiller Posted August 24, 2004 Share Posted August 24, 2004 Sorry Sube... I was referring to kelviny.. Yea, your's sounds like a definate malfunction.. Perhaps you developed a leak or low pressure condition which causes compressor overheating.. Hopefully the dealer gets it figured out.. Link to comment Share on other sites More sharing options...
Tide Posted August 24, 2004 Share Posted August 24, 2004 moved to warranty issues & problems. cheers. :) Link to comment Share on other sites More sharing options...
Nick Posted August 24, 2004 Share Posted August 24, 2004 To clarify my post as well, I was referring to kelviny's observations. SUBE_MN, you definitely have an issue that needs dealer attention. -Nick Link to comment Share on other sites More sharing options...
kelviny Posted August 25, 2004 Author Share Posted August 25, 2004 Thank you everyone give me some idea, and advice, now I try to make appointment first to fix it from dealer, I hope this problem will be little problem, and easy to fix. I Love this car, however, this is my first time to drive this brand name, I have no experience on it specially on the Turbo Model. If I have any good news, I will post it on, thank you helping! If I have any question, please help me again, thanks. Link to comment Share on other sites More sharing options...
SUBE_MN Posted August 25, 2004 Share Posted August 25, 2004 The dealer has reported back to me that they found my AC system to be "slightly overcharged." They have brought it into spec. I will report back if I have any more issues after I pick the car up. Link to comment Share on other sites More sharing options...
Sub-attraction Posted September 2, 2004 Share Posted September 2, 2004 I just test drove a GT yesterday and experienced the warm/cold air output fluctuation. I as well as the salemen found it to be very annoying and not what one would expect to be Normal characteristics of a climate control system. 5 seconds it would be cool, then 5 seconds warm, then it would get really cold and back to warm. ARGH!! It sounds like it is happening to several people some of which are writing it off to normal behavior and others like me who find it offensive. I've had climate control in my current car for 3 years and it never behaved this way in the least. Hopefully it is the A/C overcharge thing and it can be corrected. Seems like SIA would be doing these things right to begin with. Sorry for the rant. I really want to get this car and it makes me mad that issues like this can kill the deal. Link to comment Share on other sites More sharing options...
knester Posted September 19, 2004 Share Posted September 19, 2004 I also have this problem on my new 2005 2.5 XT. Same symptoms as you describe. It is very annoying. What did your dealer find out? Link to comment Share on other sites More sharing options...
gargleblaster Posted September 22, 2004 Share Posted September 22, 2004 I noticed the same cold/hot cycle when on a test drive in a turbo Outback. It's almost like the climate control is chasing itself to maintain the temp in the cabin. Founder - The Harry F. Johnson Memorial Fund Link to comment Share on other sites More sharing options...
John M Posted September 28, 2004 Share Posted September 28, 2004 Any updates on this? My new car is doing it and it had 8 miles on it when I picked it up. I hope it's the AC overcharging issue. Has anybody else had this fix the problem? Link to comment Share on other sites More sharing options...
RoundBoy Posted September 29, 2004 Share Posted September 29, 2004 Just to be sure... because I finally figured out the mystery of the HVAC system.. are you guys using the defrost option? This is on the right knob, top button. This supposedly turns on the compressor but does not blow cold air.. you must also make sure both knobs are turned to 65 for max cooling. Also check around your internal temp sensors... it may be confused as to your internal temp... it might think the car is colder then it really is, and therefore lessening the cold air.. Link to comment Share on other sites More sharing options...
knester Posted September 29, 2004 Share Posted September 29, 2004 I had the master mechanic at my dealer in Houston evaluate this issue yesturday. He observed the issue and checked all of the A/C levels and pressures. The system was not overcharged or under spec. He said the compresser and several of the system componets are new for 2005 so there is not alot of history. His plan was to discuss the problem with Subaru tech line (a tech hotline for their mechanics I guess) and then come back to me. Since it is getting cooler here it's not a killer concern but I of course want it resolved. I have a friend that just bought a new Legacy GT (2.5+turbo same as my Outback) and he does not have the issue. I will update when I know more. Link to comment Share on other sites More sharing options...
John M Posted September 29, 2004 Share Posted September 29, 2004 I have several ideas on the cause of this. I'll work on it this weekend and report what I come up with. Link to comment Share on other sites More sharing options...
Baddogi Posted May 10, 2010 Share Posted May 10, 2010 I just bought a 2005 legacy outback and I am having the same issue. The A/C blows very cold for 5 seconds, then it blows warmer air for 5 seconds and then back to cold for 5 seocnds and keeps repeating. This is very annoying as I have to replace some other things as well. Hopefully I didn't get a lemon. Please let me know what you find out, I'd really like to get this fixed and don't want to pay the dealer all the money they want. Link to comment Share on other sites More sharing options...
diverrick Posted August 30, 2019 Share Posted August 30, 2019 Any closure on this issue? I know it is an older thread but I'd like to know what fixed it, because I have the same issue now and no one can figure it out. Three Comprssors, new freon charge new orings, new condenser, new receiver dryer, basically everything firewall forard has been replaced at least once and it still is not working. Link to comment Share on other sites More sharing options...
