Xenonk Posted August 31, 2005 Share Posted August 31, 2005 Here you all go: 245/40/18 Falken Azenis RT615s Tires 18"x8" + 51mm offset SSR GT7 Wheels Stack Comparison To Other Tires at 4-stack high: http://img362.imageshack.us/img362/6048/img00155sb.jpg Near to Far: 235/45/17 Yokohama Advan A046 (Stock Evo Tires) 225/45/17 Dunlop Super Sport (R Compound Tires) 225/40/18 Yokohama Advan A048 (R Compound Tires) 225/45/17 Falken Azenis RT215 (mounted on SSR Comps) 245/40/17 Yokohama Advan A032s (R Compound Tires) 245/40/18 Falken Azenis RT615s (mounted on SSR GT7s) http://img390.imageshack.us/img390/644/img00168vh.jpg Near to Far: 245/40/18 Falken Azenis RT615s (mounted on SSR GT7s) 245/40/17 Yokohama Advan A032s (R Compound Tires) 225/40/18 Yokohama Advan A048 (R Compound Tires) 225/45/17 Dunlop Super Sport (R Compound Tires) 235/45/17 Yokohama Advan A046 (Stock Evo Tires) http://img390.imageshack.us/img390/2585/img00179ev.jpg Height (width really) differences http://img390.imageshack.us/img390/9944/img00182xs.jpg http://img390.imageshack.us/img390/8697/img00195yg.jpg 245/40/17 Yokohama Advan A032s (R Compound Tires) vs. 245/40/18 Falken Azenis RT615s ("Street Tires".. yea right.. "street" is an understatement for these tires) Keefe Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted August 31, 2005 Author Share Posted August 31, 2005 http://img352.imageshack.us/img352/1460/img00410av.jpg Mounted SSR GT7 with Zero Degrees of Camber http://img352.imageshack.us/img352/441/img00428nc.jpg Rear SSR GT7 with -1.5 Degrees of Camber http://img352.imageshack.us/img352/2958/img00432rb.jpg Non-Rolled Rear Fender (will need to roll to avoid any rubbing) http://img352.imageshack.us/img352/5589/img00440wk.jpg Front SSR GT7 With -1.5 Degrees of Camber Keefe Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted August 31, 2005 Author Share Posted August 31, 2005 http://img352.imageshack.us/img352/3259/img00372km.jpg Rear Inside Tire Clearance (very close to rubbing the stock fender liner) http://img352.imageshack.us/img352/9610/img00351wy.jpg Front Inside Tire Clearance (very close to rubbing the front Zeal Coilover) http://img352.imageshack.us/img352/1075/img00365qg.jpg http://img352.imageshack.us/img352/4091/img00380an.jpg Less Than 6mm Worth of Clearance (I could barely squeeze my finger between the tire and coilover) Keefe Keefe Link to comment Share on other sites More sharing options...
BrownBoy Posted August 31, 2005 Share Posted August 31, 2005 whoa! crazy close clearance. Gotta give ya props for putting those on. Too bad you couldnt run those 255s. But even these are a lil too close for comfort in my opinion. How do you think it'll fair as far as rubbing on the inside? The fenders can always be rolled, but the inside, different story. The reason I'd like to know is cus I was thinking about the same tires in the same size... Link to comment Share on other sites More sharing options...
Xenonk Posted August 31, 2005 Author Share Posted August 31, 2005 it's not rubbing on the inside, it's rubbing on the fender on the outside on the rear. I wouldnt do a 255/40/18 unless you have something like a 8" wide wheel with a +48mm offset AND you would have to get as much camber as possible on ALL 4 corners on top of the fact that you would have to roll your fenders like mad in the rear. Keefe Keefe Link to comment Share on other sites More sharing options...
Nsaglibene Posted August 31, 2005 Share Posted August 31, 2005 Wow, what a sexy collection. Link to comment Share on other sites More sharing options...
Xenonk Posted August 31, 2005 Author Share Posted August 31, 2005 I'll post more pics of the rims on the car tomorrow. It should be great since the tires fill up the ENTIRE wheel gap and basically the car looks like the fenders sit on tires from the profile view. I didnt change the ride height of the car yet (and I dont plan on doing so since I just went for a spirited drive). The rear just rubs a little bit under fast suspension travel but it's doing just fine with my stiffer and shorter suspension travel setup. Keefe Keefe Link to comment Share on other sites More sharing options...
SC GT Posted August 31, 2005 Share Posted August 31, 2005 Keefe, What's causing the rub, the height (i.e., diameter), or the width? SC Link to comment Share on other sites More sharing options...
BrownBoy Posted August 31, 2005 Share Posted August 31, 2005 Good to hear that the inside doesnt rub unless under some spirited driving. Yeah, fender rolling is of course a must. But the set up looks great, and I cant wait to see a profile shot. Sorry if I missed it, but what is the total diameter of the new set up? Does it still fall within tolerances since you stepped down in size? Yet again an addition to the Keefe gallery of wheels. Link to comment Share on other sites More sharing options...
Xenonk Posted August 31, 2005 Author Share Posted August 31, 2005 Keefe, What's causing the rub, the height (i.e., diameter), or the width? SC the tire is wide and the outside rear fender is being rubbed up on the tire when it's hitting harsh fast and deep bumps.. damn Azenis is built like a 255+ tire.. I had to readjust some of the numbers on my FAQ to let people know that anything built like a true 255 wide tire needs fender rolling, especially when you combine it with the offset ranges I have given to compensate for the worse case scenario. The diameter isn't an issue and it's very doable to cram in a 25.5" tall tire in the car and not have it rub up on anything (as well as stock shocks, but I have yet to verify that). This tire and wheel set up is probably the biggest you can go for the GT. I have pretty maxed out the inside and the outside as well for a modified GT like mine without too much of a fender issue. This is big as it's going to get without too much modding or body work. Any wider and you'll have to get fender work and the suspension realigned and done to fit wider tires and wheels under there. So for those of you who plan to run 9" wide rims with 265+ wide tires, expect to do some fender body work. Keefe Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted August 31, 2005 Author Share Posted August 31, 2005 Good to hear that the inside doesnt rub unless under some spirited driving. Yeah, fender rolling is of course a must. But the set up looks great, and I cant wait to see a profile shot. Sorry if I missed it, but what is the total diameter of the new set up? Does it still fall within tolerances since you stepped down in size? Yet again an addition to the Keefe gallery of wheels. With my particular set up, it's not going to ever rub on the inside, it's the outside that will rub. Here are the specs for the tire: Falken Azenis RT-615 Size: 245/40/18 Load & Speed Rating: 97W (reinforced) Model Number: 28-352-843 Recommended Rim Width: 8.5" Approved Rim Widths: 8.0" to 9.5" Overall Tire Diameter: 25.6" Sectional Width: 9.8" Tread Width: 9.1" Tread Depth: 8/32" Revolutions Per Mile: 803 Shipping Weight: 27.8 lbs Max PSI @ Load Weight: 50 psi @ 1609 lbs The tolerance is beyond 2% of what I have in my FAQ, but I will include this tire size in the mix anyways since it's very close to the tolerance. No one cares to be off by 4mph when traveling 60mph right? Just DRIVE AT THE SPEED LIMIT with these tires Keefe Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted September 1, 2005 Author Share Posted September 1, 2005 some 245/40/18 Falken Azenis RT-615s with 18x8 SSR GT7s http://img162.imageshack.us/img162/4286/img00085eb.jpg http://img69.imageshack.us/img69/8490/img00113ng.jpg http://img69.imageshack.us/img69/142/img00154dl.jpg http://img69.imageshack.us/img69/6039/img00169uy.jpg http://img69.imageshack.us/img69/9125/img00176rf.jpg http://img69.imageshack.us/img69/4438/img00198es.jpg http://img69.imageshack.us/img69/1541/img00203pq1.jpg http://img69.imageshack.us/img69/2082/img00217ym.jpg Keefe Keefe Link to comment Share on other sites More sharing options...
Drift Monkey Posted September 1, 2005 Share Posted September 1, 2005 Cool tires, buy a house. Link to comment Share on other sites More sharing options...
Deer Killer Posted September 1, 2005 Share Posted September 1, 2005 I don't run a tireshop in my garage either lol.. Link to comment Share on other sites More sharing options...
Xenonk Posted September 1, 2005 Author Share Posted September 1, 2005 Cool tires, buy a house. buying a garage is more like it. Keefe Keefe Link to comment Share on other sites More sharing options...
colatkitty Posted September 1, 2005 Share Posted September 1, 2005 Do the fronts rub as well or just the rears? Link to comment Share on other sites More sharing options...
Xenonk Posted September 1, 2005 Author Share Posted September 1, 2005 just the rear from coming down from a harsh tall speed bump too fast.. I cambered in the front -1.5 degrees to make sure they clear. No rubbing from trail-braking, turning or u-turning. Keefe Keefe Link to comment Share on other sites More sharing options...
colatkitty Posted September 1, 2005 Share Posted September 1, 2005 Nice to be able to add - camber with your coilover setup. I don't think the stock setup will allow for that much. Link to comment Share on other sites More sharing options...
Xenonk Posted September 1, 2005 Author Share Posted September 1, 2005 if you lower the car you can get as much as -1.5 degrees of camber if you dial out the stock camber bolts to the max.. Keefe Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted September 11, 2005 Author Share Posted September 11, 2005 Btw, bump for new pics http://img362.imageshack.us/img362/9862/img00019sl.jpghttp://img362.imageshack.us/img362/6703/img00029ay.jpg http://img362.imageshack.us/img362/3290/img00035zy.jpghttp://img362.imageshack.us/img362/8213/img00047rx.jpg Keefe Link to comment Share on other sites More sharing options...
sandwood Posted September 11, 2005 Share Posted September 11, 2005 is that your normal setup -1.5 front and rear? getting out of the legacy game Link to comment Share on other sites More sharing options...
sandwood Posted September 11, 2005 Share Posted September 11, 2005 you should have your own rubber tree plantation... getting out of the legacy game Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted September 25, 2005 Share Posted September 25, 2005 Btw, bump for new pics http://img362.imageshack.us/img362/9862/img00019sl.jpghttp://img362.imageshack.us/img362/6703/img00029ay.jpg http://img362.imageshack.us/img362/3290/img00035zy.jpghttp://img362.imageshack.us/img362/8213/img00047rx.jpg What are the rims fourth from left? Do they have rivets? Link to comment Share on other sites More sharing options...
Xenonk Posted September 25, 2005 Author Share Posted September 25, 2005 They are my R1-Racing GTR-9 rims, no rivets.. they are these: http://img.photobucket.com/albums/v205/xenonk2828/GT-Pitt/Pitt-10.jpg http://img.photobucket.com/albums/v205/xenonk2828/GT-Pitt/Pitt-2.jpg http://img.photobucket.com/albums/v205/xenonk2828/GT-Pitt/Pitt-3.jpg Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted September 25, 2005 Author Share Posted September 25, 2005 is that your normal setup -1.5 front and rear? I run: -0.5 degrees up front for daily -2.0 degrees for autocrossing -3.0 degrees for track days Keefe Link to comment Share on other sites More sharing options...
