rad rex Posted April 11, 2005 Share Posted April 11, 2005 I recently smelled coolant after I parked the legacy and brought it to the dealership to get it checked out. They told me that there is a seal on the water pump that is leaking and that it will have to be replaced. They are working on it as we speak, I'll keep you folks posted Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted April 11, 2005 Share Posted April 11, 2005 k Link to comment Share on other sites More sharing options...
melayout Posted April 11, 2005 Share Posted April 11, 2005 I recently smelled cooland after I parked the legacy and brought it to the dealership to get it checked out. They told me that there is a seal on the water pump that is leaking and that it will have to be replaced. They are working on it as we speak, I'll keep you folks posted Any mods? I keed I keeed Link to comment Share on other sites More sharing options...
rad rex Posted June 18, 2005 Author Share Posted June 18, 2005 UPDATE......... mostly because I am incredibly pissed at the dealership, PATRIOT SUBARU, who BTW is registered here. I will be having a serious chat with the owner regarding this. I never had problems like this with exeter Subaru. Anyway, now that I've vented a bit, here's the update: I went to check on the coolant level which is slowly going down in the resevior. I noticed it was down and couldn't see any fluid in the resevior anymore....time to add more coolant and give the dealer a call and make another appointment to have it looked at. At the same time I was planning on doing Jedi's intake silencer mod and see how it sounded. Ok.....first lets' take out the...... WHERE THE HELL IS THE PLASTIC AIR INTAKE!!! The intake to the airbox seems to be missing. I can't believe I hadn't noticed it before but it's frigging missing ...because the dealer forgot to put it back in!!! This is after I wait an hour longer than they say they needed the car for when I brought it in to replace the water pump. I will be making some calls monday....aaaargh Link to comment Share on other sites More sharing options...
meier motor sports Posted June 18, 2005 Share Posted June 18, 2005 they knew u wanted to remove the silencer so they either thought they would go one up and remove the air box. or they removed it so you couldnt moddify it jk good luck Link to comment Share on other sites More sharing options...
rad rex Posted July 21, 2005 Author Share Posted July 21, 2005 Finally got back to the dealership and they rplaced the air intake. Hopefully no other big issues will befall me Link to comment Share on other sites More sharing options...
