NickSJ Posted March 28, 2005 Share Posted March 28, 2005 Hello, new to this forum. Nice reading so far. I've noticed that when the climate control is turned OFF, the vents still bleed air. If I have it set to Defrost, the air will bleed through those vents, when set to Floor, the air bleeds through at the floor vents, etc. So now I am in the habit of switching to defrost, before I turn it off, because that's where it's least noticeable. Anyone else notice this? Thanks, I read the CC sticky and the owner's manual, and didn't find anything. Link to comment Share on other sites More sharing options...
rallispec Posted March 28, 2005 Share Posted March 28, 2005 yes, that happens in most cars. Before you turn off the vents, switch the CC to recirculate cabin air rather than pull in air from outside. Link to comment Share on other sites More sharing options...
NickSJ Posted April 1, 2005 Author Share Posted April 1, 2005 Thanks, I already tried that and still, I get air coming through the vents - seems like there's a door in the CC plenum that allows air from the outside, that's not closing all the way when set to recirc / off, hence the constant air coming thru the vents. Just curious if anyone else had noticed this same behavior, and if it's normal / expected, or if mine is just not functioning properly. Link to comment Share on other sites More sharing options...
joeyjojoe Posted April 1, 2005 Share Posted April 1, 2005 after you turn the CC off, you should hit the vent/recirc button and the recirc icon should pop up. i'm not sure if you're already doing that and still have the problem, if so, just ignore me. Link to comment Share on other sites More sharing options...
meier motor sports Posted April 1, 2005 Share Posted April 1, 2005 all cars do not do that. all cars i ahve driven or owned. if u turn the ac off manual or auto ac it stops blowing. but this car with the ac off there is still air blowing out he vents Link to comment Share on other sites More sharing options...
skubdu Posted April 1, 2005 Share Posted April 1, 2005 after you turn the CC off, you should hit the vent/recirc button and the recirc icon should pop up. i'm not sure if you're already doing that and still have the problem, if so, just ignore me. the only thing that you should see is the recirc image on the display. Link to comment Share on other sites More sharing options...
mmm def Posted April 1, 2005 Share Posted April 1, 2005 try putting the vents to the floor, then you won't notice it as much. Link to comment Share on other sites More sharing options...
Deer Killer Posted April 1, 2005 Share Posted April 1, 2005 AFAIK every car has a minimum blower settting when running, so the occupants don't pass out... Link to comment Share on other sites More sharing options...
centerpunch Posted April 2, 2005 Share Posted April 2, 2005 I would say that if you've had a BMW or Audi, the entire Subaru AC/Ventilation system is not at all in the same league, in any respect. Link to comment Share on other sites More sharing options...
GTWILLY Posted April 12, 2005 Share Posted April 12, 2005 I JUST PUSH OFF, THEN PUSH RECIRC AND I DONT FEEL ANY MORE AIR COMING IN IN MY CAR, BUT IT DOES TAKE A COUPLE SECONDS FOR THE AIR DOORS TO CLOSE AND THE AIR TO STOP. Link to comment Share on other sites More sharing options...
Legasee Posted April 12, 2005 Share Posted April 12, 2005 I JUST PUSH OFF, THEN PUSH RECIRC AND I DONT FEEL ANY MORE AIR COMING IN IN MY CAR, BUT IT DOES TAKE A COUPLE SECONDS FOR THE AIR DOORS TO CLOSE AND THE AIR TO STOP. +1 1. Turn off EVERYTHING so that NOTHING is showing 2. Push the RECIRCULATE (image with a 1/2 loop) 3. No more air coming in (passengers will pass out soon ) In Taiwan now... Link to comment Share on other sites More sharing options...
emorphien Posted August 28, 2005 Share Posted August 28, 2005 Just to necropost, it doesn't seem that my car is actually blowing air when I do this. If the car is stopped I can't feel much but if I turn it off and increase my speeds the volume of air coming through seems to increase. I'll check out the recirc thing after hitting off though. Link to comment Share on other sites More sharing options...
SVXWRX Posted August 28, 2005 Share Posted August 28, 2005 will a mod PLEASE make this a sticky? Link to comment Share on other sites More sharing options...
PhilT Posted August 28, 2005 Share Posted August 28, 2005 Why would you want to close off all ventilation to the cabin ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
emorphien Posted August 28, 2005 Share Posted August 28, 2005 I would think probably because if you open the windows it's a bit weird. Also if you don't set the temp all the way to 65 it'll blow hot air. I've never driven another car that did it. Link to comment Share on other sites More sharing options...
SVXWRX Posted August 28, 2005 Share Posted August 28, 2005 I would think probably because if you open the windows it's a bit weird. Also if you don't set the temp all the way to 65 it'll blow hot air. I've never driven another car that did it. 97' SVX did it, and so does our '02 WRX. i can't remember further back then that. maybe its a Subaru thing? Link to comment Share on other sites More sharing options...
emorphien Posted August 28, 2005 Share Posted August 28, 2005 97' SVX did it, and so does our '02 WRX. i can't remember further back then that. maybe its a Subaru thing? Indeed maybe it is. Link to comment Share on other sites More sharing options...
mlrtime Posted August 28, 2005 Share Posted August 28, 2005 Sad thing is most modern cars come with switches on the individual vents to allow outside air to come directly in. The X5 has this and it is nice to just open the drivers vent to get some quick cool air coming in but yet still keeping the car warm. .02 Link to comment Share on other sites More sharing options...
SVXWRX Posted August 28, 2005 Share Posted August 28, 2005 all this whining now, but when you have hot air very quickly after startup when its freezing out, you'll love it. turbo cars = quick warm air in winter. http://www.subaru-svx.net/photos/files/Landshark/17649.gif Link to comment Share on other sites More sharing options...
