06White2.5I Posted February 16, 2007 Share Posted February 16, 2007 Ended up getting all of these codes this morning on my way home. Anyone have any idea on what it could be related to? Check Engine, ABS, Flashing Cruise, and and Err 55 on the Odometer. Have Camera...Will Travel ~2007 LegacyGT.com Calendar (October)~ Link to comment Share on other sites More sharing options...
robinlsb Posted February 16, 2007 Share Posted February 16, 2007 Ended up getting all of these codes this morning on my way home. Anyone have any idea on what it could be related to? Check Engine, ABS, Flashing Cruise, and and Err 55 on the Odometer. Tighten gas cap "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
06White2.5I Posted February 16, 2007 Author Share Posted February 16, 2007 It's not the gas cap, I always tighten it when i fill up and it has been fine since tuesday when i last put gas in it. Have Camera...Will Travel ~2007 LegacyGT.com Calendar (October)~ Link to comment Share on other sites More sharing options...
Jon in CT Posted February 16, 2007 Share Posted February 16, 2007 Your odo is actually displaying Er SS which indicates the ABS/VDC system detected a problem with the data from one of the wheel Speed Sensors. This ususally prompts the OBD computer to set a P0500 trouble code, which turns on the CEL and disables cruise control. This problem is usually the result of getting stuck in snow and one of the wheels spins much faster than the others. It should all go away after about 3 driving cycles if that's the case. Link to comment Share on other sites More sharing options...
Xenonk Posted February 17, 2007 Share Posted February 17, 2007 it'll recalibrate itself.. if it doesnt, just disconnect the battery, pump the brakes, and then hook up the battery. That should clear the code.. Keefe Link to comment Share on other sites More sharing options...
06White2.5I Posted February 18, 2007 Author Share Posted February 18, 2007 thanks everyone, it cleared itself Have Camera...Will Travel ~2007 LegacyGT.com Calendar (October)~ Link to comment Share on other sites More sharing options...
TSiWRX Posted February 18, 2007 Share Posted February 18, 2007 ^ Good to hear. ;1008230']Your odo is actually displaying Er SS which indicates the ABS/VDC system detected a problem with the data from one of the wheel Speed Sensors. This ususally prompts the OBD computer to set a P0500 trouble code' date=' which turns on the CEL and disables cruise control. This problem is usually the result of getting stuck in snow and one of the wheels spins much faster than the others. It should all go away after about 3 driving cycles if that's the case.[/quote'] ^ Precisely. http://www.legacygt.com/forums/showthread.php?t=48611 <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
4wdrift Posted September 8, 2007 Share Posted September 8, 2007 I just got this code today after 4 new tires and a wheel alignment. The ECU is in limp mode and will not allow the engine to rev over ~4200 RPM. Is the ECU thing the norm as well or should I be concerned? Link to comment Share on other sites More sharing options...
muddy02 Posted December 17, 2007 Share Posted December 17, 2007 this thread answered my quesiton great. i got stuck in about 12" of snow, and really had to work it to get it out. Then i got the code. I hope it goes away soon. It's not about speed, it's about acceleration! Link to comment Share on other sites More sharing options...
fineout Posted December 17, 2007 Share Posted December 17, 2007 i just got this today after having my frame cought on a snow bank for an hour..good to hear that its not major Link to comment Share on other sites More sharing options...
jxjjang Posted December 18, 2007 Share Posted December 18, 2007 yeup, happened to me last night. got stuck coming into my driveway, car threw a CEL at me with ER 55(SS?). the error code went away after a few restarts, and i just disconnected the battery to reset the ECU and it cleared the CEL. Link to comment Share on other sites More sharing options...
The Don Posted April 25, 2008 Share Posted April 25, 2008 I just got this code today after 4 new tires and a wheel alignment. The ECU is in limp mode and will not allow the engine to rev over ~4200 RPM. Is the ECU thing the norm as well or should I be concerned? This happend to me today..went to leave parking lot after alignment and engine shut off...min later turned it on and 5 sec later it shut off...couldnt drive it had to bring it to dealer by flatbed..im pissed B/C alignment shop got defensive when i asked if they touched anything..said they never saw the ABS CEL or Cruise nor ER 55 blinking...but the Fans running..."didnt hear them" come on now... Update...ABS senser blew... Link to comment Share on other sites More sharing options...
4wdrift Posted July 9, 2008 Share Posted July 9, 2008 I just got this code today after 4 new tires and a wheel alignment. The ECU is in limp mode and will not allow the engine to rev over ~4200 RPM. Is the ECU thing the norm as well or should I be concerned? Guess I never updated for others benefit. One of the leads to the wheel speed sensor was inadvertently cut by the wrench monkey who did my alignment. Link to comment Share on other sites More sharing options...
