#436:
07-04-2006, 10:42 AM
Car: Silver Legacy GT Limited Sedan, MT
Originally Posted by dshap13
Just did this. 2 stainless steel washers (3/8"). Gap was about 3/32's of an inch in between teh two halves of the flange. Sound is great inside the car, maybe a bit loud at a stand still from outside the car. Exhaust does come out of the tailpipe at idle. No droning at highway speeds as previously mentioned on this string. I'll have to drive it around a bit for an extended period of time to see if dropping one side to one set of washers is the way to go. Sounds great though!
Just went to 1.5...A little more subdued to fit my taste, but can still hear the boxer rumble. One washer on the driver side with two on the passenger.
#437:
07-04-2006, 11:33 AM
Car: 2005 LGT LTD 5MT, Garnet Red Pearl
I just went from stage 2 to stage 8! (Stage 8 being a single strand of #8 solid copper conducter) The sound is not noticeably different to my ears, but does seem to be a little more mellow, yet still gives that feedback to the driver.
#438:
07-04-2006, 04:36 PM
Title: Level 48 Hunter
Car: Rocketback
Originally Posted by hogmeat
my right, your right, the cars right, or the from the cars behind right?
car's right
(Updated 1/21/10) I've only snapped 1 axle
#439:
07-05-2006, 08:35 PM
Will the Hogzaust void my warranty???
Title: Gifted!
Car: 05LGTLTDSDN5MT
 OK, so my LGT went to the shop today for an oil change, and a check-up on my rear wheel bearings (both are bad, of course) and I also asked the tech to check the torque on the lower strut bolts and swaybar links and brackets - even told him I'd pay a 1/2 hour labor, if necessary. I installed a set of iON springs last week and every once in awhile get some creaking sounds from the suspension. Not a clunk like when my endlink was loose - it's more subtle than that. Anyway, I wasn't entirely sure that I put everything back together properly so I asked him to check it out. When I went to pick up my car, the guy said that the sounds I'm hearing were from exhaust leaks I've got at both mufflers, and that I messed up the gaskets when I unbolted the mufflers to do my suspension!! Um, no. I didn't really know how to try and explain the beauty of the Hogzaust system to the guy, so I just told him don't worry about the exhaust, and by the way, were all the suspension bits torqued properly??
"Well, I didn't check those because what you are hearing is an exhaust leak."
DOH!!!
#440:
07-05-2006, 09:46 PM
Title: i'm here for the gangbang
Car: 09 xterra se
07-06-2006, 12:11 PM
Title: I'm tardcore!!!
Car: 2001 Ford F150
DOH!!!
#442:
07-06-2006, 05:09 PM
Car: Rocketback
"I noticed you accidently replaced your gaskets with washers...silly mistake, anyone could've done it"
#443:
07-06-2006, 09:17 PM
Title: Gifted!
Car: 05LGTLTDSDN5MT
It was even more confusing than that, as I went with the custom fit 12-gage copper wire method. I can imagine them going, "WTF???" Funniest part was that the dealer was thoughtful enough to actually provided me a written estimate for the replacement parts I'd need to 'fix' it:
QTY 2 - Gasket R/M(?) - 44011AE01A - $5.84ea
QTY 4 - Bolt - 901660014 - $2.84ea
QTY 4 - Nut - 902350001 - $4.05ea
Grand total in parts: $41.59. No labor was quoted. I'm just amused because in the time it took them to type up this quote that I didn't want, they could have actually torqued the suspension bolts like I'd asked them to. Oh well.
Anyway - there's the gasket part number if anyone wants to replace theirs or go with the Hogzaust Premier edition, by snipping away some of the OEM gasket. I checked Subaruparts.com, and they've got them listed at $2.22ea + $1.99 shipping.
#444:
07-06-2006, 10:30 PM
Car: Rocketback
damn...cheap bolts.
the bolts on the UP and DP are $8.43 each
#445:
07-06-2006, 10:44 PM
Title: 50% air
Car: 05 GT w/cow and hole in roof
Originally Posted by mwiener2
damn...cheap bolts.
Yeah, well if you put the $3 bolt on your DP and UP they will break.
#446:
07-07-2006, 09:14 PM
Title: Contributing V.P.
Car: 05 SWP LegacyGT Vf39"hellaslow"/02 S2K
i just got around to tyin this out today and when i took it for a test drive after i wuz goin 15 down my street and sum old bitch told me to slow down i even stopped and told her i waz jus doin 15 LOL  then she even threatend to call tha cops. So a big thumbs up for this mod.
#447:
07-08-2006, 11:40 AM
Car: SWP 5MT Legacy GT Lmtd
How many washers did you use?
#448:
07-08-2006, 02:55 PM
Car: 2005 legacy 2.5i
Indeed this will work and sound smooth with n/a. My "i" came to audible life on my lunch break or I should say a quarter of it(15 min project and clean-up.)
**Would going hog on one side and staying stock on the other cause any issues??
#449:
07-08-2006, 03:51 PM
Car: Rocketback
yeah, it'll be half as loud
#450:
07-08-2006, 04:12 PM
i went with stage 3
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
