rao Posted September 29, 2004 Share Posted September 29, 2004 A 10 minute job tops and it works great :D HVAC works and the stereo works perfectly. The only strange thing which I noticed is that the random function turns itself off when you switch to the radio, but at least it is easy to turn on again. I will check the subwoofer output when I get a chance. I had posted pics of the radio here: [url]http://www.legacygt.com/viewtopic.php?t=3538[/url] Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
c_hunter Posted September 29, 2004 Share Posted September 29, 2004 I didn't see any special sub outputs in your pictures -- the back looks the same as the radio on my XT. The factory sub tees off of the rear speaker leads in the main harness. CRaig Link to comment Share on other sites More sharing options...
rao Posted September 29, 2004 Author Share Posted September 29, 2004 Except in the VDC where it goes to the rear harness because there is a factory installed sub in the storage area. One of the black plugs is for the steering wheel controls and the sub (the stock stere has the plug as well). I am guessing that it is just a speaker level output and I have followed it to where it goes to the rear harness but I haven't tested it yet or located it at the back of the car. I don't know if it is crossed over or not so it may make more sense to just use a line out converter on the fronts or rears coming out of the regular stereo connector. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Ninjapimp Posted September 29, 2004 Share Posted September 29, 2004 Nice. As someone asked in the other thread, does it read ID3 tags? Link to comment Share on other sites More sharing options...
recuomo Posted September 30, 2004 Share Posted September 30, 2004 [quote name='rao']Except in the VDC where it goes to the rear harness because there is a factory installed sub in the storage area. One of the black plugs is for the steering wheel controls and the sub (the stock stere has the plug as well). I am guessing that it is just a speaker level output and I have followed it to where it goes to the rear harness but I haven't tested it yet or located it at the back of the car. I don't know if it is crossed over or not so it may make more sense to just use a line out converter on the fronts or rears coming out of the regular stereo connector.[/quote] Does the stock unit have the plug for the steering wheel controls? Link to comment Share on other sites More sharing options...
rao Posted September 30, 2004 Author Share Posted September 30, 2004 It does read ID3 tags. The stock stereo does have the plug for the sttering wheel controls and the car has the wiring in place as well. Also, the subwoofer output does work. I have only traced the wires to the front passenger's kick panel but I haven't found them at the back of the car - yet ;) Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
recuomo Posted September 30, 2004 Share Posted September 30, 2004 [quote name='rao']It does read ID3 tags. The stock stereo does have the plug for the sttering wheel controls and the car has the wiring in place as well. Also, the subwoofer output does work. I have only traced the wires to the front passenger's kick panel but I haven't found them at the back of the car - yet ;)[/quote] Now you really have me excited! The stock GT Ltd has the steering wheel wiring harness installed? Is the harness plugged into the radio? Do you have any details where it terminates under the dash? I want to make up a pod with micro switches to mount behind the wheel but my dealer service told me only the VDC has the harness installed, probably BS. Link to comment Share on other sites More sharing options...
rao Posted September 30, 2004 Author Share Posted September 30, 2004 I don't know about the end at the stering wheel, but the plug at the radio is definately there. The steering wheel controls only use 2 wires. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
recuomo Posted September 30, 2004 Share Posted September 30, 2004 [quote name='rao']I don't know about the end at the stering wheel, but the plug at the radio is definately there. The steering wheel controls only use 2 wires.[/quote] Very interesting. I have the wiring diagram thanks to Jedimaster but it appeared to have more than 2 wires. Thanks for the input. Link to comment Share on other sites More sharing options...
c_hunter Posted September 30, 2004 Share Posted September 30, 2004 I hope you find something, though I will be surprised! When I had my radio out, I did a wire count of those two smaller plugs on the back of the radio/hvac unit. When you take into account all the HVAC functions that each use a wire (fan, temp sensor, numerous duct dampers and valves, AC, etc....) then consider the steering wheel controls (gotta be more than two wires for volume +/-, track +/-, etc... ), it did not seem to me that there would be extra wires for a sub. Some of the other Subaru radios do have a separate sub connector, but they don't tie into HVAC or steering wheel controls. Craig Link to comment Share on other sites More sharing options...
rao Posted September 30, 2004 Author Share Posted September 30, 2004 It is in the wiring diagram. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
c_hunter Posted September 30, 2004 Share Posted September 30, 2004 Cool, well I am anxious to hear if you can trace that wire back. I assume it comes out near the side storage pocket in the passenger side of the hatch area?? That would be pretty cool if we could add a sub back there simply by plugging it in.... Anybody tried to see if the VDC sub assembly can be ordered and the price? I'm sure it would be cheaper to put an aftermarket component sub back there, but then you'd have to integrate and tune it. Of course, you could just wire in something like an Infinity Basslink and be done with it.... Craig Link to comment Share on other sites More sharing options...
rao Posted September 30, 2004 Author Share Posted September 30, 2004 On the wagons it is on the right hand side in the wire that comes under the rear seat - look for a 2 pin plug with a white and red wire. On the sedans it appears that the wire goes to the end of the instrument panel harness but does not continue on to the rear harness :( At least it makes it easy to either tap in a liine out converter or to run the wires to a speaker level input. I hooked up a speaker to it last night and it definately works, all low frequencies and non-fading. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Trent Bates Posted September 30, 2004 Share Posted September 30, 2004 [quote name='rao']The only strange thing which I noticed is that the random function turns itself off when you switch to the radio[/quote] FWIW, I think my stock unit does that too. Glad to seethat it's working for you! Link to comment Share on other sites More sharing options...
c_hunter Posted October 1, 2004 Share Posted October 1, 2004 Seems odd that Subaru still offers the underseat sub when you could just plug into the harness and put a sub in the location the VDC uses. I think I would prefer to have a sub in the back. I will have to check this out and see what I can put back there. Thanks for your research! Craig Link to comment Share on other sites More sharing options...
rao Posted October 1, 2004 Author Share Posted October 1, 2004 Craig, before you get too exited when I tested the sub wires with the stock stereo they were completely dead. I believe that only the VDC stereo has them, that is what the service manual shows as well. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Ken S Posted October 1, 2004 Share Posted October 1, 2004 Craig, I think Subaru must have an oversupply of those blue cables they use to wire the underseat sub! :lol: Ken Link to comment Share on other sites More sharing options...
rao Posted October 7, 2004 Author Share Posted October 7, 2004 The high level sub wires stop at the front to rear harness connector (by the passenger's side kick panel) and do not ontinue to the trunk area. They should in a wagon, but not in the sedans. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
bemani Posted October 7, 2004 Share Posted October 7, 2004 Under $600? Sweet! So does it work with VBR? Manual says it isn't supported, but it still works, right? Reverse engineer that thing, and make a mp3 BIOS upgrade patch for the oem stereo for us!!! :p Link to comment Share on other sites More sharing options...
S4 Posted February 2, 2005 Share Posted February 2, 2005 Does VBR work or not with this guy? If I have to get my stereo replaced, I'm going to see if I can pay the difference to upgrade to the VDC. If it won't do VBR, it's worthless to me though. Link to comment Share on other sites More sharing options...
Deer Killer Posted February 2, 2005 Share Posted February 2, 2005 [quote name='!S4']Does VBR work or not with this guy? If I have to get my stereo replaced, I'm going to see if I can pay the difference to upgrade to the VDC. If it won't do VBR, it's worthless to me though.[/QUOTE] Also being able to get music from my collection in flac, ape, mp3 and ogg would obviously be nice.. I can only dream.. *sigh* Link to comment Share on other sites More sharing options...
rao Posted February 3, 2005 Author Share Posted February 3, 2005 It does play VBR MP3's. I just burned a disk with VBR and it played just fine. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Deer Killer Posted February 3, 2005 Share Posted February 3, 2005 [quote name='rao']It does play VBR MP3's. I just burned a disk with VBR and it played just fine.[/QUOTE] what encoder, what settings? Average bitrate? I'm sorry to be skeptical but the manual says VBR doesn't work. Link to comment Share on other sites More sharing options...
rao Posted February 3, 2005 Author Share Posted February 3, 2005 So skeptical at such a young age :lol: Freerip. High of 160 low of 40. I have no idea what the average was, but I played it back on the computer and wateched the bit rate change every few seconds. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Deer Killer Posted February 3, 2005 Share Posted February 3, 2005 [quote name='rao']So skeptical at such a young age :lol: Freerip. High of 160 low of 40. I have no idea what the average was, but I played it back on the computer and wateched the bit rate change every few seconds.[/QUOTE]Since you're an early adopter, do you mind trying some encodes out? I can send some stuff to you or whatever. Link to comment Share on other sites More sharing options...
