#1:
09-05-2004, 03:40 AM
There's a Borla exhaust for the Legacy GT!!
Title: Banned
Car: 05 LGT-L Silver Sedan 5MT
By the way, I looked at a new Legacy GT with a dealer installed Borla exhaust system. It was from at least in front of the cat.
I couldn't fully see, but it without a doubt had a different rear cat, instead of the large rectangular looking one that's stock it was cylindrical.
The tips were oval shaped and stuck out a bit further than stock.
It had a VERY nice burble to it. It wasn't intrusive at all but gave the LGT a more aggressive growl.
They did not change the intake at all.
And honestly, I didn't notice much performance gain from it.
It felt just like the stock LGT I drove just sounded a bit meaner.
Without any additional air coming in, via an aftermarket intake, I know some cars gain very little if any power from just an exhaust. I don't think the stock exhaust on the LGT is that restrictive, so maybe in the case of the LGT, the Borla exhaust did very little other than give it it's great sound. It might of given the car an extra couple of hp but again, nothing I could really tell. But I'd be curious to know if Borla dynoed a stock LGT and then dynoed it again immediately following installation of their exhaust.
But ohh that sound!!
I'm going to check out the Borla website to see what they say.
The dealer added $995 to the price of the car for that exhaust.
#2:
09-05-2004, 03:44 AM
Title: Site Admin
Rank: Admin
Car: spec.B #380
Moved to powertrain. Cheers.
#3:
09-05-2004, 03:48 AM
Title: Banned
Thanks.
Well, the Borla website doesn't list the 05 LGT yet.
But it was a Borla, said so on the mufflers, said so on the exhaust tips.
#4:
09-05-2004, 03:55 AM
Title: Site Admin
Rank: Admin
Car: spec.B #380
$995 for a hi flow cat + cat back exhaust dual tip seems about right installed. I would imagine a full turbo back would run about 1300-1500.
#5:
09-05-2004, 04:00 AM
Title: Banned
yeah, and the sales guy seemed to think they'd deal a bit on that $995 price.
I pick up my LGT Limited sedan from that very dealer on Sept. 20th.
If the Borla proves to be a bit of a power improvement, I may consider seeing what kind of a deal they'd do for me on that system. Heck the sound of it alone is worth $500.
I know a few other manufacturers are working on exhaust systems for the LGT, but I don't know price and don't know what power gains they've gotten from just an exhaust either.
#6:
09-05-2004, 04:06 AM
Title: OSecu
Car: 2005 LGT
So at idle and/or cruising speeds it seemed not much different than stock? Then livened up at full-throttle? How would you describe it in those regards?
I'd be interested in for no other reason that a bit more exhaust noise when really on it, but I don't want it to impact cruising noise too much.
#7:
09-05-2004, 04:18 AM
Title: Vendor II
Car: Some dodgy eurotrash
I noticed that when I drove the STi part equipped Legacy (the prototype for the WR) that had the STi exhaust on. Sounds great, possibly a bit better flow, but the problem was that it just made the a/f ratios a bit richer, which doesn't really do that much for power. With a high flow intake fitted it may lean the system out to compensate, but it isn't something I would comfortably want to do with out some basic engine management to keep a/f ratios clean and safe.
The intake system on the Legacy is the strong and the weak point. It is rather well optimized for response and power in the mid-range, but it does that at the expense of flow at the top end. It also is rather fine-tuned to the stock boost levels, and the turbo has a hard time producing any more boost without opening up the intake one way or the other.
Cheers,
Paul Hansen
www.apexjapan.com
#8:
09-05-2004, 04:29 AM
Title: Banned
Paul, thanks for you insights. That's kind of what I thought. I drove this Borla equipped car and couldn't tell any differences in power over the stock.
I know on large V8 trucks (and cars) for that matter, just changing the exhaust can give you 10-15 hp.
But I think, even if this Borla exhaust system from (which appeared to be in front of the cat, but probably keeping the stock downpipe) gained even 5 hp I would of felt it had a bit more power. But I didn't. It just sounder cooler, no power gains.
Your most likely totally correct, as I suspected, without an intake system and a retune of the ECU, there would be NO noticeable power gains. It might gain 1 hp, but without if it's a bit more restrictive ( I doubt) it could even take 1-2 hp away (again, I doubt Borla would make an exhaust that did that though).
Racerdave,
you asked, "So at idle and/or cruising speeds it seemed not much different than stock? Then livened up at full-throttle? How would you describe it in those regards?"
I noticed the exhaust sound the second I turned the key. It fired up with a bit of a 350Z snarl. I didn't even know the car had the aftermarket exhaust when I went to start it up. But after hearing it, I asked the sales guy, "does this car have an exhaust, the other LGT I drove, I couldn't even HEAR the exhaust." he said, "yeah"
I jumped right out to look at it (after I turned the key off though.
yes, at cruising speeds it settled right in to a barely audible burble. Maybe a couple decibels above stock.
It in NO way was intrusive at ANY time.
Heck, just turning on the stereo to moderate levels would drown out the sound completely.
It was a GREAT sounding exhaust. Just what I'd want...enough to give the LGT some nice sounds, but not intrusive. The sales guy bought a WRX STI 3 weeks ago, and he said this Borla exhaust on the LGT was still quieter than his stock exhaust on the STI.
#9:
09-05-2004, 01:22 PM
Title: OSecu
Car: 2005 LGT
Cool... thanks for the input... sounds nice!
#10:
09-05-2004, 01:41 PM
Title: GRP > *
Car: 2005 Garnet Red Legacy GT Sedan, 5MT
Awesome. Sounds like a nice solution. I agree that it probably won't yield much for a performance gain, since with dual mufflers, the stock Legacy GT already has a good amount of flow after the catalytic converter. You didn't get around to taking any pics by chance, did you?
#11:
09-05-2004, 02:20 PM
Title: Banned
No sorry, had I know, I would of taken my digital camera.
I might head back up there in the next couple days.
If the car is still there, I'll take the pictures.
I think I mentioned they stick out a bit further than the stockers. The stock mufflers are tucked back a bit under the bumper. These Borlas fill the half circle cut outs in the rear bumper and are basically flush, instead of being tucked in.
They are also slightly oval shaped. But just slightly.
The actually diameter of the pipes looks to be maybe 1/2" larger too. Not drastic. To most and especially those who don't know, they'd think they were the stock mufflers.
Heck I walked around the car two or three times myself and didn't notice them. It's no "ricer" coffee can look, but rather classy and clean, but muscular.
#12:
09-05-2004, 04:15 PM
Title: HighIntensityDenial
Car: '05 Legacy GT Wagon 5MT
If you are primarily after some improvement in sound, wouldn't it be a lot cheaper to simply replace the stock mufflers?
Most people seem to calmly accept the outrageous prices of exhaust systems. Seems to me there is a huge markup on cat back systems. I mean $500-$1000 for what, two mufflers, two tips, and some tubing. A cat back system has got to be one of the most expensive performance enhancements out there, on a dollar per horsepower basis.
#13:
09-05-2004, 05:28 PM
Title: OSecu
Car: 2005 LGT
Yeah, mufflers would do it. And a lot cheaper.
Works for me.
#14:
09-05-2004, 08:24 PM
Title: Megan Racing and KW Pimp
Car: 05 Legacy GT, 06 Tribeca, 07 Outback
The other option is to have a muffler shop fab up a system for you. I had a full turboback exhaust made up for my Merkur XR4Ti and it cost me about $350 installed. I bought all the parts (mandrel bent 3" downpipe, 3" high-flow cat, 3" mandrel bent u-bends and muffler) and paid a shop $100 to section the u-bends and weld it all up. I'll probably do the same when I pick up my LGT, but I'll have to wait till someone comes up with a bolt-on downpipe.
#15:
09-05-2004, 08:35 PM
Title: 50% air
Car: 05 GT w/cow and hole in roof
Yeah, but do they help you out if it doesn't quite fit right and bangs against the heatshield during maneuvers?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
