virulosity Posted March 29, 2009 Share Posted March 29, 2009 http://i152.photobucket.com/albums/s164/VIRULOSITY/DSCF0301.jpg http://i152.photobucket.com/albums/s164/VIRULOSITY/DSCF0302.jpg http://i152.photobucket.com/albums/s164/VIRULOSITY/DSCF0304.jpg Link to comment Share on other sites More sharing options...
virulosity Posted March 29, 2009 Author Share Posted March 29, 2009 Forgot to add, I have stock suspension and had an alignment done (to factory specs) when I had the tires installed. Link to comment Share on other sites More sharing options...
laz Posted March 29, 2009 Share Posted March 29, 2009 something something camber something. But seriously, camber out of spec? just my guess. X --- Link to comment Share on other sites More sharing options...
laz Posted March 29, 2009 Share Posted March 29, 2009 http://autos.yahoo.com/maintain/repairqa/tires_wheels/ques094_2.html X --- Link to comment Share on other sites More sharing options...
Fraggle Posted March 29, 2009 Share Posted March 29, 2009 I'm curious, have you checked your LCA bushings? See if they are a bit torn... Does the car "wander" a bit before settling into a sweeping curve? Link to comment Share on other sites More sharing options...
virulosity Posted March 29, 2009 Author Share Posted March 29, 2009 My camber is within spec. I had a lowered prelude with a buttload of negative camber and still didn't have wear this localized. Link to comment Share on other sites More sharing options...
RochNY91TSI Posted March 29, 2009 Share Posted March 29, 2009 I think that toe being off is more likely for that type of wear. Camber would have to be very negative for that. If the toe is off like this in the car: \ / \ / The front inside of the tire will get scrubbed coupled with some neg camber Link to comment Share on other sites More sharing options...
laz Posted March 29, 2009 Share Posted March 29, 2009 are both tires the same, or only one side? If one side, which side? X --- Link to comment Share on other sites More sharing options...
mars_volta Posted March 29, 2009 Share Posted March 29, 2009 I had the same problem with my car when I changed the second set of tires at 70k. The tech said the alignment was way off. I also had a rear wheel bearing replaced a while back. http://www.sixthsphere.com/storage2/images/4r1b2s8qieta80wvj9r.jpg Link to comment Share on other sites More sharing options...
CapnJack Posted March 30, 2009 Share Posted March 30, 2009 It may be that your front is aligned and your rear is aligned, but is your front aligned to your rear? (tracking) Is it only on one tire? // \\ Link to comment Share on other sites More sharing options...
virulosity Posted April 1, 2009 Author Share Posted April 1, 2009 It happens on both sides, but more on the drivers side. I had this problem before I put the tires on, so I had it aligned. I suppose it could have lost the alignment from driving, but for the exact same symptoms to come back is suspicious to me. Is an alignment just a scam? It comes with a 6 month guarantee, but you wont notice any wear at all until well after that. Then when I finally have the same problem before the alignment again, they say that its because I have to align the car every 10000 miles? I did check the lower control arm bushings and they look worn (unless they are designed with slits in them, it looks uniform to me?). Are there any other signs that would point to this? The suspension does feel and sound a little "clunky" over bumps. Volta: It is interesting to me that your car has exactly the same problem. I wonder if it is inherent in the suspension design. The tech that aligned my car last said that the caster was out of spec, but that he couldn't fix it because this car has fixed caster. Link to comment Share on other sites More sharing options...
nemo Posted April 1, 2009 Share Posted April 1, 2009 If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
ShadowImg Posted April 1, 2009 Share Posted April 1, 2009 significant under inflation combined with negative camber (within spec even)? Link to comment Share on other sites More sharing options...
elpete77 Posted April 2, 2009 Share Posted April 2, 2009 it's not rubbing on something maybe? Link to comment Share on other sites More sharing options...
trademark Posted April 2, 2009 Share Posted April 2, 2009 You are all retarded.. this is obviously a rubbing issue on the strut housing/Spring perch or possibly the spring. Link to comment Share on other sites More sharing options...
laz Posted April 2, 2009 Share Posted April 2, 2009 Yeah but obviously why is it rubbing Mr. genius? X --- Link to comment Share on other sites More sharing options...
trademark Posted April 2, 2009 Share Posted April 2, 2009 You are all retarded.. this is obviously a rubbing issue on the strut housing/Spring perch or possibly the spring. if It was me I'd would probably be able to find some wear area in the wheel well.. but it isn't and all we get is tire pics.. Link to comment Share on other sites More sharing options...
Opie Posted April 2, 2009 Share Posted April 2, 2009 It would have to be a seriously oversized tire to rub on the spring perch or spring. I'm betting a camber issue combined with a tire pressure issue. ...now the camber may be caused by something else...worn LCA bushing, blown strut, etc. Link to comment Share on other sites More sharing options...
ShadowImg Posted April 2, 2009 Share Posted April 2, 2009 ^ Way to steal my thunder by being logical about it. Link to comment Share on other sites More sharing options...
Opie Posted April 2, 2009 Share Posted April 2, 2009 Link to comment Share on other sites More sharing options...
CapnJack Posted April 2, 2009 Share Posted April 2, 2009 Do you have a print out from the alignment shop of what each reading is? Have you taken it to a different alignment shop? Getting your car aligned every 10k miles? That's a scam... Link to comment Share on other sites More sharing options...
trademark Posted April 3, 2009 Share Posted April 3, 2009 wouldnt the tire wear be more worn if that was camber? Link to comment Share on other sites More sharing options...
virulosity Posted April 4, 2009 Author Share Posted April 4, 2009 In regards to the rubbing, that is a possibility. I didn't see anything obvious when I was changing the brakes though. Also, I wouldn't think the stock suspension would allow this? It is definitely not under inflation. I keep my tires at 36psi and check them every time I put gas in it. Link to comment Share on other sites More sharing options...
outahere Posted April 4, 2009 Share Posted April 4, 2009 Are these aftermarket wheels? Do your wheels have the correct offset? Link to comment Share on other sites More sharing options...
virulosity Posted April 6, 2009 Author Share Posted April 6, 2009 It turned out to be the Lower Control Arm Bushings. Thanks guys! What happened is that with the worn bushings, the tire would rub against the spring perch, causing the wear. Link to comment Share on other sites More sharing options...
